GB Bars - Vintage and Model ..?
Quoted: 1372 Post(s)
Liked 1,752 Times
Does anyone know the approximate vintage and model of this GB handlebar? I am hoping to fit it to my Torpado which came with Ambrosia Champion bars but they are way too narrow for me. Anyway, what vintage and model...
Quoted: 3814 Post(s)
Liked 3,345 Times
The Ambrosio Champion stem has a clamp diameter of 26.0mm
The GB bar has a centre section diameter of 25.4mm
The Dawes Galaxy it is on looks to be a boomer
Quoted: 981 Post(s)
Liked 1,844 Times
https://www.bikeforums.net/classic-v...de-butler.html
See some of the last posts of this topic. These engraved bars were made for Dawes by GB. That's the general consensus in previous discussions and in most photos of them online. Some of them are even stamped "Dawes," like the example in the topic above.
I know for a fact the engraved bars were provided stock on the Dawes Double Blue model as early as 1958, but they were likely used on various models for quite a while given how many are still floating around today. If they're on a Dawes right now, you can probably bet they're original to the bike.
-Gregory
-Gregory
Quoted: 702 Post(s)
Liked 672 Times
I had the same bars on a early 1970's Falcon
EDIT: mine had GB engraved on them
Liked 1,752 Times
Quoted: 981 Post(s)
Liked 1,844 Times
Like I said, I know the engraved bars were offered with some Dawes models as early as the late 1950s, so you should be good if you only need them to date to the '60s!
-Gregory
-Gregory
Bikes: Herse, Singer, Barra, Pitard, Goeland, Ferrand etc..
Quoted: 11 Post(s)
Liked 11 Times
They look to be 50's-60's to me. They did make this bar for quite a long time before they went bust.
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
I'm confused. your Torpado came to you with aGB/Ambrosio combo and now
you want to fit a GB/GB combo? you want the bars to be the correct era
but are unconcerned with them being the correct brand? just be sure the bars
and stem are the EXACT same size. a cast piece like an alu-alloy stem has
NO elasticity.
NO elasticity.
Liked 1,752 Times
NO elasticity.
NO elasticity.
Likes For randyjawa:
Quoted: 108 Post(s)
Liked 70 Times
the Ambrosio bars will need either an Ambrosio, Fiamme,or 3ttt
stem. the 3T grand prix might be easier to find and cheaper
than the other two
than the other two
Liked 1,752 Times
A fellow just called me and offered me an Olmo for free. Pictures later if it turns out that I am not dreaming.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Bikes: Mike Kowal Aravis Touring bike, 1952 Claud Butler Massed Start, 1959 Dawes Red feather, 1975 Carlton Criterium, 1997 Specialized Rockhopper, Bianchi Merlo MiniVelo
Quoted: 20 Post(s)
Liked 87 Times
Regarding the bars, they are the Dawes Concord bars made by GB (as previously mentioned) which they used on several of their models in the late 50's and 60's. I have a Dawes Red Feather from 1959 that has them.
I'm sure you have seen this from velobase
VeloBase.com - Component: Dawes Concorde
Liked 1,752 Times
@ JohnDThompsan -
Well, I am still learning new things. First set of these entry level Campy drops to ever come my way. Shows what I do know and I don't even know for sure if the bike is an Olmo. I do know that it does not appear to be anything exotic.
As for bars, got another set of GB bars, attached to a Milremo stem the other day. See my tip on removing fossilized handlebar tape. Rather than hours, or days of finger damaging picking and pulling, I put these bars in really hot water and then unwrapped the ribbon as a single piece, with only a wee bit of residue still holding. Residue which came completely off with a light wipe of lacquer thinner...
Those look like the 1010/1 stamped dropouts, used up into the 1970s:
How old are these?
I found them at the bike shop where I worked from '78-'80, they were very old then.
Quoted: 3811 Post(s)
Liked 6,709 Times
^ Commonly found on early 60s Raleigh road bikes, e.g., Gran Sport.
