Metal/Sintered AND Resin/Organic
Quoted: 463 Post(s)
Liked 567 Times
Those of you running Metal/Sintered brake pads on one wheel AND Resin/Organic brake pads on the other wheel, which brake pad type are you running on what wheel and why?
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I run metal/sintered brake pads on the left side, and resin/organic pads on the right side. When the bicycle is rolling forward, the angular momentum vectors point toward the left side, so I find the left pads benefit from a longer-wearing material. Also, I am deaf in my left ear, so the added noise doesn't bother me.
Likes For Polaris OBark:
Quoted: 463 Post(s)
Liked 567 Times
Likes For Ron Damon:
Quoted: 878 Post(s)
Liked 726 Times
I recently put new pads in my rain bike -- metal pads for the front and resin for the rear. Metal tends to be stronger and fades less, but is louder with a tendency to squeal when wet. Organic is fine for the rear as I don't want to grab too much rear brake and lose traction.
I tried it out today and ironically the front was silent and the rear was a bit noisy. Albeit this was in dry conditions.
Likes For surak:
Liked 3,443 Times
I thought I had just made it up, and the totally BS justification would have made that clear. (Sorry.)
Have a friend put them in and tell him/her/them/whatever not to tell you whether the metal pads are in the front or back. I am willing to bet you won't know the difference until you look.
Liked 3,443 Times
Spring can't come soon enough.
Quoted: 4414 Post(s)
Liked 4,867 Times
I’m waiting for someone to argue the case for resin front and metal rear 😂
But seriously, there is no reason to be mixing pad types. Sintered pads are harder wearing and more heat resistant (less fade). Organic pads are quieter with better feel/modulation.
So I use organic pads for everything except a trip to the big mountains, where sintered pads are a better option for long technical descents.
Quoted: 463 Post(s)
Liked 567 Times
No, actually, if you search the MTB forums some people do exactly what you suggested earlier. It is real. Turns out reality is more clever than you. In any case, why did you make things up, in your mind, of course?
Liked 3,443 Times
It was 72° F here today, and I had a great ride.
Enjoy playing around with your brake pads.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I want the rear brake stronger because I'm scared of going over the bars in a panic stop?
It's like riding a bicycle
Likes For urbanknight:
Quoted: 463 Post(s)
Liked 567 Times
So, you made up a fictitious answer to a question that wasn't asked? The dark and the isolation of winter really does a number on some people psychologically. Are you hearing voices? Hallucinating too, perhaps? You are clearly unwell. We all hope that Spring does come soon lest you continue to be afflicted by these disturbing psychotic episodes.
Liked 3,443 Times
Liked 3,443 Times
In practice, it appears to make no difference.
Liked 3,443 Times
Liked 3,443 Times
Nope.
Quoted: 3513 Post(s)
Liked 2,927 Times
Never had this quandary with rim brakes.
Just sayin’.
Just sayin’.
Likes For smd4:
Quoted: 4806 Post(s)
Liked 3,932 Times
Quoted: 878 Post(s)
Liked 726 Times
Good for you, but I have had to change from using single to dual compound pads for my tandem because single Kool Stop salmon compound squealed like a mofo on the front. And it still stops like ass compared to with disc brakes.
Just sayin'.
Just sayin'.
Liked 2,927 Times
Just sayin.’
Liked 2,927 Times
Liked 4,867 Times
Likes For PeteHski:
