List of tight tyres and unhelpful rims
Quoted: 1529 Post(s)
Liked 718 Times
Okay, so it struck me that given all the experience floating around here, we could probably make a halfway comprehensive list of tyres and rims to be avoided or at least to avoid combining.
When nominating a tyre for the list, you shouldn't base it on a single experience - if you've had other tyres on the same rim or tried the tyre on other rims, then you have a basis for comparison. And try to mention the size, too - that may have a bearing. To keep it simple, just rate it out of three - hard, damn hard, or nearly impossible (breaking tyre levers, getting a sore throat from swearing at it), although any comments you add will be helpful for folks reading the whole thread.
Any rims that keep getting mentioned will be added to the list, but factors like rim tape confound the data, so I'll allow for a bit of noise there.
Oh, and if you've ever seen someone come along and whip off a tyre in seconds that you've been struggling with, you should probably learn all the tricks before influencing anybody's purchasing decisions.
Liked 718 Times
Come to think of it I won't bother trying to edit all the responses into a list; too much editorialising involved.
I'll let the posts speak for themselves; it'll be more work for anyone to check out, but the accompanying explanations are more relevant.
Liked 718 Times
The Michelin PRO3s are a nice supple folding tyre, but the bead is hella tight, at least on my pair. 1/3.
I'm pretty sure larger Marathons aren't as tough to mount as a 28mm, but I was having a hell of time with a couple I had to mount not because the bead was too tight (just about the opposite) but because the tyres were so stiff they brutally resisted all but the most insistent attempts to seat the bastards. 2/3.
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Rims:
Campagnolo Omega - 3/3
These rims are narrow, with very shallow wells, and in my experience are extremely hard to work with. To change tires on these rims, I had to cut the wire beads of the old tires (Conti gatorskins 622-23) with bolt cutters. New folding bead Paselas (622-28) were impossible to mount by hand when there was cotton rim tape. I was able to install the Paselas by replacing the cotten rim tape with slick packing tape (recommended by somebody on the forums) and dusting liberally with talcum powder, but it was still a struggle.
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
"For a list of ways technology has failed to improve quality of life, press three"
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
2 hardest combinations I've encountered:
1. Michelin PR3 on my paired spoke WH-7700 DA wheelset. That combo was a 2, maybe 3/3. I did break a [plastic] tire iron once. I didn't have as many issues with the PR3 on Open Pros - so some of the blame goes to the rim/wheelset.
2. Challenge Parigi-Roubaix (622/27) on Mavic MA2. Was a 3+/3. The Challenge PR beads are tight & a struggle on many rims, but they play much better with my Sun CR18 rims, now just a 1/3.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Bikes: Cervelo P3 (retired), Habanero Road, Novara Safari, Batavus Personal Delivery Bike
The Matrix branded rims with stock rim tape that came on Trek road bikes in the early 90's. I've broken several leavers on those things, even one of the big yellow pedros leavers. The blue park ones are completely useless on those rims - useless entirely for me in fact since any tire and rim combination loose enough to be separated by those noodles I can change without leavers. 3/3
Collector of Useless Info
I'm lovin' on Mavic rims- all the tires I've tried so far install and remove without tire levers on my Kysrium, Open-pro and A719 rims. Sun CR-18 are pretty good too. Just bend the bead over and presto! But I haven't tried michelin pro race or schwalbe marathon tires yet.
Liked 718 Times
Thanks guys, that's a good start...
But it seemed like a bit of a mission to try and edit the responses into a succinct list, so I'll leave the info just in the replies.
Unless somebody else wants to take it on and compile something; if so I'll edit it into the OP.
