Rt.611 closed in Delaware Water Gap
Quoted: 18428 Post(s)
Liked 15,582 Times
Randomhead
Liked 3,701 Times
North of Portland. I imagine the rockslides are on the twisty part between the water gap and Delaware Water Gap.
"PennDOT on Jan. 10, 2023, announced Route 611 just north of Portland will be closed for an estimated seven months because of a Dec. 6, 2022, rockslide."
Don't know if it's accessible to bikes.
Liked 15,582 Times
If the closure is lower down, there may be some workarounds. Going north, one might be able to climb Turkey Ridge out of Portland, make a right at the T onto Laurel Hill and then right onto National Park Dr. That will take you back down to 611. However, a relatively short portion is unpaved. And Turkey Ridge is a steep climb.
Fub fact: Portland is the home town of the guy who wrote “All I Want For Christmas is my Two Front Teeth.”
Quoted: 2333 Post(s)
Liked 2,097 Times
I'd probably walk across the footbridge in Portland to NJ and then go to Blairstown, NJ and climb the ridge on Millbrook, rejoining ACA route at Millbrook Village unless one planned to sleep at the church in Water Gap, had one's heart set on that little bakery or needed a dispensary fix before crossing state lines
Liked 15,582 Times
FYI…Even if they are full they will make space for you if you are arriving by human power. Best to call ahead and let them know you are coming.
Bicyclist
Last week we rode thru no problem after going around the concrete barriers. There was no construction going on and no obstructions on the roadway. Met a southbound bicyclist using the AC route map so apparently there has been no addendum added yet. Car free from Portland PA to the DWG is the way it should be,it's much too narrow a road to be sharing it with autos.
Liked 15,582 Times
