Need Help Picking Replacement Wheel (long)
Quoted: 1851 Post(s)
Liked 678 Times
SF, going to have to disagree a bit with you. Most LBSes, IME, do not have skilled wheel builders. They rarely even have someone competent enough to fix an out of true wheel.
OP, at your weight, you should be fine on just about any rear wheel. You're not at the extreme end of weight. You should be able to purchase a Shimano or DT Swiss rear wheel for less than $200.
Likes For topflightpro:
Mostly Harmless
That is extremely helpful, Kimmo! I had assumed that the disc to rotor aligment would be different. Also I wasn't sure about rotor thickness and braking surface width.
If so that is especially good, because I am about due for new rotors anyway. Plus, based on what I see for sale, most disc brake road wheels are center lock.
So any 160mm rotor center lock wheel and rotor (for example Shimano 160mm) is compatible with my current 160mm TRP Spyre cable calipers?
I just went through the same process with my bike. Rear wheel cracks at the spokes. Looked all over the internet and just was not sure they would fit. I finally ordered a set through Hunt Wheels. I just sent them the year and model of my bike and they build to fit. Came with skewers and even adaptors to use my 6 bolt rotors on the center lock wheels. (I upgraded to center lock rotors anyways)
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
I missed the part about needing disc rotors in your first post. Sorry!
Quoted: 18883 Post(s)
Liked 10,646 Times
Mostly Harmless
I hope your LBS has a good wheel builder. It's not terribly hard to build a wheel and most shops will do it for you. Anyway, the good thing about this route is you can talk to a human being about how and where you ride your bike, what you're trying to get out of your wheels, etc, and they'll be able to recommend a setup that will be a good match for you.
Centerlock is generally preferable, but it's not a big deal, they both work. The dropouts in your bike are going to limit the skewer you can use.
Liked 10,646 Times
Even still, talk to the mechanic at your LBS; even if you don't have confidence in their ability to build a wheel for you, they might have some insight into what a good wheel for your purposes would be like.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Or just post a thread in the mechanics subforum.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 8261 Post(s)
Liked 8,996 Times
If you'd like to try it yourself get a book called "The Bicycle Wheel" by Jobst Brandt.
bike whisperer
Liked 716 Times
Yeah, it's easier than you think. A rear wheel is a bit trickier, but the main thing is to know the half- dozen or so critical pointers, and then you can just use patience to make up for lack of experience.
In fact, I think its quite possible for someone building their first wheel to do a better job than an experienced builder, since you most likely won't be paying for more than an hour's work; he'll get it to 95% good and call that good enough, while you can keep tweaking away till it's 98% or better. Good idea to have some spare nipples on hand, though.
Liked 10,646 Times
I like having nipples around.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
https://www.merlincycles.com/hope-20...00c-95184.html
Likes For Sy Reene:
Mostly Harmless
An overbuilt option (probably not too lightweight):
Mostly Harmless
Today there is YouTube and written forums, and decades of experience has improved my general DIY skills. But wheel building is a time sink that I don’t want to enter, at least not now.
Likes For Tony_G:
Mostly Harmless
I agree that there are people who build wheels who don't do a good job, I should know, but in my opinion a hand built wheel done by a good builder will be superior to a machine built (factory built) wheel in many cases. My best luck with wheels has always been hand built by local builders.
I’m going with the wheel builder option. A new DT Swiss R 460 rim with all new spokes mated to my current hub. I’m having it done at a small three person shop, but they have been around for a while. It is going to be approximately $55 for the rim, $55 for spokes, and $50 for labor.
The DT Swiss rim is warrantied for 2 years, but no actual warranty on the wheel build. Shop owner said “case by case basis”, which to me translates to zero.
Won’t be ready until Friday the 11th, they had to order the rim.
Another shop I tried came up with a nice Mavic rim paired with a Shimano hub and freewheel, for around $300. They didn’t do wheel builds. They had no warranty info, which I found off putting.
With the wheel build being half the price of a new rear wheel complete, it was a fairly easy decision.
Liked 8,996 Times
Okay, I finally made a decision today.
