Benefits of look keo blades over the look keo original shape?
King Hoternot
Bikes: 2015 Cannondale Evo Hi mod
Quoted: 127 Post(s)
I have really been interested in the keo blades but dont want to spend the $ if there isn't much beneift. My logic tells me that it is a larger platform for your feet which might be more comfortable?
thanks
thanks
Bikes: Colnago, Cervelo, Scott
Quoted: 191 Post(s)
There isn't much benefit. The blades have a larger platform by a little bit. They are not more comfortable or easier to click into. The only benefits are weight, which is barely reduced on the CrMo models, and a lower profile for a theoretic reduction in pedal strikes during cornering. I personally find the fragile carbon blades to outweigh any of the "advantages".
Super WW
Bikes: A really light one and a really heavy one.
Quoted: 70 Post(s)
Liked 43 Times
There have been issues with the carbon blade - they warranty it, but that's time w/out your pedals. I still tell people to look at the exustar 200 ti model. It's lighter and I've had mine for over 2 years with zero issues (look keo compatible).
I ride Keo Blades on my primary bike and Keo 2 Max Carbon on my backup bike... there is no discernible difference between the two. Silvercivic27 summed it up best, though I don't find the blades to be fragile, nor have I had any warranty issues.
https://www.bikeforums.net/showthread...de-replacement
Forget it if you like durability. Posted my comment there too.
mine after 1.5 month of use
Recusant Iconoclast
Having tried both, I "settled" on the Keo 2 Max Carbon as I couldn't tell the difference except my wallet stayed a little thicker. While there's a real, though insignificant, weight difference, the only tangible benefit is actually an intagible - you get to say, "Yeah, I have the Keo Blades, and it's got that carbon, um, blade thingy."
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times
I would be riding the carbon max if i didnt get the blades for free...weight is the difference. Have the max on my other bike.
People like to see this stuff in action, so free product plus it helps to be able to tell people what your experience has been with the product you have actually used. Imagine that.
Quoted: 67 Post(s)
Liked 7 Times
Not worth the hassle if the blade breaks. If you want lighter pedal get some Keo 2 Max and then some Ti spindles from Ward for $60. https://www.ebay.com/itm/Titanium-Spi...item33778ee159
Note: they say they don't fit Keo 2 Max pedals but they actually do.
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
Liked 5 Times
*actually, all pedals on my cranks (SRAM Rival) will creak like a mofo if they are slightly lose. I've had CB Candy and Eggbeaters prior to the Time pedals and it happens with all of them, after a few dozen hours of riding. I do have the pedal washers installed and the pedals are greased. I've actually tried teflon tape as well! I've resigned myself to tightening the pedals every time I thoroughly clean the drivetrain, it's about the same interval.
