Hollowtech II - keep riding after wearing out?
Old 04-03-20, 03:50 PM
wle
wle's Avatar
Bikes: road: 1999 GT road:40Kmi+ // 2001 fuji finest AL:9Kmi+//1991 schwinn paramount ODG:0.1Kmi+
Quoted: 19 Post(s)
Liked 10 Times in 7 Posts
I have a road bike with Hollowtech II. After 3500 miles, I have worn out the bearings. There is play, creaking, noise. This is the 2nd set. My question is, what happens if I just keep using the same ones? Will the BB lock? Will it just be more friction noise and play? Will they seize and break the whole frame.??
3500 miles is TERRIBLE! I got 40,000 from the earlier square taper 2000-era BB on the same bike!
They are famous for short life ( as i found out LATER! ).
I don;t think there are any adjustment options.
BB shell is threaded.
thx wle
wle is offline
Old 04-03-20, 04:10 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
thx wle
Take the crank out and see if the bearing move freely. If the bearing move freely, the bearings aren’t the problem. Play and creaking could be loose cups in the frame. You may also need to tighten the bearing load binder on the nondrive side when you reinstall the crank. That little plastic piece that looks like a huge Torx bolt actually serves a purpose and if it is loose, the crank can move on the spindle.
From personal experience, I’ve never had a problem with the bottom bracket bearing and I have this crank on a number of bikes with lots of mileage on them.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 04-03-20, 04:21 PM
berner
Quoted: 663 Post(s)
Liked 496 Times in 299 Posts
Same as Cyccomute. I've got 24,000 miles on mine with no problem. Take it apart for a look. Maybe you have bad bearings or left and right side are not aligned which screwed up the bearings.
berner is offline
Old 04-03-20, 04:50 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
I wonder if the OP's bottom bracket shell needs facing.
dsbrantjr is offline
Likes For dsbrantjr:
Old 04-03-20, 05:06 PM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
Hollowtech II bearing life can vary greatly due to installation errors. That plastic threaded plug on the non-drive side is for bearing pre-load(really just taking play out of the system) and too much pre-load can destroy the bearings in a very short time. It should only be finger tightened until there is no side play in the crankset. You should get way more than 3500 miles out of a properly installed Hollowtech II.
dsaul is offline
Likes For dsaul:
Old 04-03-20, 05:58 PM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 580 Times in 398 Posts
This ^^. I had play in a bottom bracket cartridge that turned out to be cracks in one of the cups. The bearings were smooth as silk.
sweeks is offline
Old 04-03-20, 09:03 PM
oldbobcat
oldbobcat's Avatar
Quoted: 512 Post(s)
Liked 444 Times in 334 Posts
If you keep riding it without fixing it, though, your spindle is turning directly on the inside race of the bearing. Keep it up long enough and you will polish a groove on the spindle, meaning you'll have a loose fit when you finally install new bearings. Hollowtech II bearings are cheap.and easy to replace.
oldbobcat is offline
Old 04-03-20, 09:09 PM
oldbobcat
oldbobcat's Avatar
Quoted: 512 Post(s)
I hope you still fixed it.
Old 04-03-20, 09:12 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
I've got a BBR-60 with ~16,000 miles on it, still smooth as when it came out of the box. I've only got ~4,600 miles on a BSA30 BB, but it's still good as new, even with wafer-thin bearings.
If you're only getting a few thousand miles out of a Hollowtech BB, something is wrong. Curious as to what model "wore out" so quickly.
DrIsotope is offline
Old 04-03-20, 10:24 PM
cyccommute
cyccommute's Avatar
Yes, the bearing preload shouldn’t be too tight but it shouldn’t be loose either. Unlike the top cap on a threadless headset, it can’t be removed after the pinch bolts are tightened. If it comes loose, the left crank can work off the spindle. That can make the crank loose as well as round out the crank arm.
Stuart Black
Old 04-03-20, 10:33 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
I second this answer.
davidad is offline
Old 04-04-20, 12:53 AM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 532 Post(s)
Liked 312 Times in 236 Posts
As mentioned by others HT2 generally has a pretty reasonable bearing life on the BB; you are experiencing uncommonly short service life. One concern raised by others is that external bearing systems are more sensitive to shell alignment because the alignment of the bearings is determined by it solely, whereas a cartridge BB maintains much of its alignment simply by being manufactured as a single piece. Also replacing a HTII BB takes all of about 10 minutes and they cost $15-30.
cpach is offline
Old 04-04-20, 07:29 AM
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Of course! I sourced a replacement BB. Now solid as a rock.
Drive-side cup with crack (American Classic BB)
Close-up of inside of DS cup.
sweeks is offline
Old 04-04-20, 10:45 AM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
What you have is not a Hollowtech style BB. It's either a square taper or ISIS style old American Classic which as you mentioned had many complaints. What is the crankset you're fitting it to? Almost any price level of Shimano's equivalent BB should last for tens of thousands of miles and can be had for cheap.
Crankycrank is offline
