Show me your fenders!
Bikes: Litespeed Obed, Cannondale Scalpel, Spcialized AWOL, Litespeed Solano, Cannondale Synapse
Here is my mt. bike to touring set up so far. I want to install fenders but can't decide what format to use. I will be touring on surfaces ranging from smooth bike path to remote single track. I like the look and function of full "road" type fenders but I worry about the possibility mud clearance issues. What do you recommend? Thanks!
You might look at SKS Velo 55 or 65 fenders. They come in 4 sizes and don't require stays on the front forks or the chainstays. They may work well. I put some on my Hunq and they provide both great clearance and good coverage.
https://www.cyclofiend.com/working/20...clark1008.html
suspension fork was factory modified to accept both racks and mudguards. mudguard strut is bolted to the rack
the rack is mounted on bolts threaded in to the Fork.
Drill press will be better than a hand held drillmotor.
you may get away with just threading the lower casting behind where the front axle is ..
but not cutting into the spring cavity .. then using the arch over the wheel to mount the top of the mudguard.
if there is a hole there?
Steel rigid forks on all my other, bikes I fitted with mudguards..
(No camera, since that one failed)
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I use the Planet Bike Hardcore Fenders I haven't had a chance to ride them in really sloppy off road conditions yet, but think they will do fine. As a general rule I prefer full fenders on most of my bikes.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: Gazelle Playa
I would also recomend an extension to the front mudguard. Ever since I've installed them on our bikes we rarerly have to clean the chains.
It's just a rectangle piece of semi stiff plastic held by a small screw. We've had them for several year and has worked great.
rigid fisher mtb with xtracycle and planet bike fenders. occasionally a rock gets sucked up into the fenders and makes a bad scraping noise but it eventually is ejected. i haven't had much experience with mud but i guess that it would behave similarly
Quoted: 5 Post(s)
I had Planet Bike Hardcore fenders on my Surly Troll for a while, but found I didn't like them when riding off-road - they just seemed to get in the way, and get bashed around too much (once requiring a creative in-the-field repair) when I wiped out. I'd put them back on if I were doing a lengthy on-road tour with the bike, but for riding trails like you plan on doing, I prefer going without them.
However, they are a great deal and a good product so if you really want fenders I could recommend them.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
fenders
Here are some photos of my bikes with Planet Bike Cascadia fenders. I don't have a mountain bike so these shots may or may not be useful to you, but I have been satisfied with the Cascadias. They were easy to install, have built-in mudflaps, and don't make a lot of noise. They are plastic but I consider that a plus because they are lighter than metal fenders and won't dent. They are available in a range of sizes, including 26" wheels.
Quoted: 138 Post(s)
Liked 17 Times
Ok like everything else...I don't follow the crowd. Here my fenders. I got the idea off the web and that was maybe a week or two from now last year. Hence the perfect timing for coming up with the idea. I waited around until Wednesday, November 5th(if I remember the date correctly) and I went out in the evening and went scavenging for election signs that hadn't been taken down yet(NH laws says they have to remove within 24 hours after the election is over or the candidate will be fined...I helped a few people not have to cough up any money). They work great and only the front one rubs occasionally against the tire. Their is a piece of straight chloroplast I have wire tied to the seat tube, you can see the wire ties in the first photo and you can barely notice the piece in the photo as well.
Likes For bikenh:
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
I failed to mention in the original post....I have no eyelets of any kind for mounting!
Quoted: 196 Post(s)
Liked 6 Times
If you don't have eyelets on your frame, you might want to consider SKS Raceblades, which are quick-release (Planet Bike has a similar fender). They come in 700c and 26" sizes as well as black and silver. Although they don't provide as good coverage as full fenders, they have the advantage of being easily attachable and detachable. SKS also has started selling a Raceblade Long version with longer length. I've had some Raceblades for years and they are certainly better than nothing and perhaps the best option for bikes with no eyelets and/or limited clearance for regular fenders. Sorry, but I have no photos of the Raceblades attached to my bikes because I usually remove them as soon as they are no longer needed.
Quoted: 138 Post(s)
Liked 17 Times
My Specialized Allez Comp doesn't have eyelets either, hence one or many reason I use a backpack instead rack and panniers. Hence also why I use coroplast(spelled wrong before big time) homemade fenders. I was trying to redesign the idea but never got around to finishing it off. I want to have them so they Velcro on and off so I pop off the front wheel and Velcro it right in place and put the wheel back on. That would also help to keep the brakes clean. I had the front brake seize up on me last winter...just got the brand new bike in March last year. The rear brake is pretty much toast also but I never use the rear brake so I haven't bothered to replace it.
Quoted: 70 Post(s)
Liked 15 Times
Or people that would rather spend time riding rather than repairing or cleaning...
Aaron
Aaron
Bikes: Nature Boy 853 Disc, Pugsley SS
Quoted: 251 Post(s)
Liked 8 Times
Everyone puts fenders on, and fiddles with them for ages, and replaces them when they break, and buys new sets when they wear out. How many people actually try taking them off and going without them?
Even with full-coverage fenders, I still got sandy and dirty in a rainstorm. So did the bike. Now, I just accept it and plan accordingly, and I can't think of a single deleterious effect.
Quoted: 70 Post(s)
Liked 15 Times
I think it's a case of coming up with a crisis where there is none. I've done three tours and about 4,000 miles with no fenders on my bike. A quick rinse after I get into camp is all I do, and I can hear when my chain needs more lube.
Aaron
Quoted: 251 Post(s)
Liked 8 Times
I ride my bikes in all weather, fenders go a long ways towards keeping the chain, bottom bracket, brakes, pedals, headset and me clean and minimize maintenance. FWIW I also use chain guards and chain cases In nearly 40 years of riding I can only recall having to replace one fender, and that one got broken while the bike was on a car rack. I do have a couple of bikes without fenders, but those are the exception rather than rule. One is an MTB that gets used for aggressive trail riding, the other a go fast road bike.
Aaron
Aaron
Here are mine. They are from Woody's
https://i.imgur.com/UcsdNli.jpg
https://i.imgur.com/Lpb2eJ2.jpg
https://i.imgur.com/yWWMGfr.jpg
https://i.imgur.com/iLwq9Yt.jpg
Fenders are about more then being afraid to get dirty and it seems pretentious of you to suggest that. Being filthy and wet during a long bike tour is hard on bodies and equipment. I don't consider dry feet and a clean chain to be only for people who aren't as strong as you but a smart way to tour. I ride in the mountains where conditions can be extreme. Fenders are a necessity not some kind of light weight luxury.
Quoted: 251 Post(s)
Liked 8 Times
Your attitude seems to be exactly why I posted the alternative mindset. "I use them, so they must be essential." How much riding have you ACTUALLY done without them? Did you burn through chainrings and cranks and downtubes by the dozen before fenders saved you? Unlikely. You put them on because the hivemind told you to, and the lack of maintenance self-fulfilled your decision.
What I have done is broken two sets of fenders through rough roads and impossible attachment mechanisms. No thanks! I'm reformed.
Come on in, the water's fine.
Quoted: 33 Post(s)
As far as trying without, duh. The whole bike scene since the 700s started with people taking the fenders off their bikes to make them more like racing bikes. We all have plenty of bikes that don't have fenders, it is harder to find fenders in NA than the reverse, We also know that in wet climates people tend to prefer them. There is nothing new about touring without them, it is well known they are less needed on touring bikes to the extent that most of us have paniers, racks and clothing that provide some of the protection of fenders. Fenders are just better.
Quoted: 251 Post(s)
Liked 8 Times
That's wackaddodle. I made my fenders but they were secured with standard off-the rack fittings, that I modified slightly. I put them on, adjusted them only slightly for harsh conditions, like first time on mud. Never touch them and they are fine. Your inability to make them work tells us little about them.
You say you don't need to make adjustments, but even you admit you need to fix them in mud. They're not maintenance-free. Ever accidentally hit a branch with plastic fenders on?
This entire thread is amusing. You'd think I just denounced Brooks saddles.
