For the love of English 3 speeds...
Barred @ Velocipedesalon
Another Mystery Raleigh
Here is the bike I got at the same time as the Ladies Sport Tourist. It has the same "AW" hub with no date (appears to be the 1941/42 model); but different fenders, gearcase "window" oriented to top vice front, no "fishtail" cutouts on the head tube lugs, bolt-on seatstays, quadrant shifter, and standard front hub. The pedals and baskets/rack are definitely not original. Serial # AD99185 running parallel to the seat tube on the seat lug. No idea as to the model/year, nor originality of existing components. The right crank has about a 3-4 mm "notch"; either intentionally made to avoid contact with gearcase or worn in from continued contact with same (maybe not from this gearcase as there is not excessive wear to the case itself). Hope the photos help; I'm still trying to find my good camera!
Quoted: 4199 Post(s)
Liked 3,851 Times
Re: reusing a chain link's pin- If the chain is a modern 3/32"/der one then most every current chain has their pins peened over on their ends to better retain the side plates from prying off during the harsh shifting forces that ramps/lift pins/shift gates produce. These pins will punch a larger hole in the side plate when punched out, or almost all the way out like was the practice prior to peened pins. If the chain is a non peened pin one then great. Treat it like chains of old, which it is by design, and re press in that pin. Most all 1/8" chains that I see are not peened on their pin ends. I did this very type of conversion about 40 years ago and that bike has been under a few different riders over the years with no problems. Andy (who someday will get back that Raleigh Twenty [not a DL-20] with it's FW hub and the two SA cogs for an 8 speed)
AndrewRStewart
AndrewRStewart
Quoted: 1299 Post(s)
Liked 103 Times
Inflate Hard
Inflate Hard
Liked 103 Times
Inflate Hard
Inflate Hard
Thanks for keeping the imagery coming Big Chief! I did look at those other pictures. I can't find a reference to this serial number, unless it is shown incorrectly in the database. It would be around 1958 if the "AD" is after the numbers, but there is no listing for a serial number starting with two letters, only ending in them. I hope this is just a mislabeling in the database. I've yet to confirm if the hub has a threaded sprocket or not, but it looks identical to my other example; which begs the question of what year the frame is if the hub is '41-'42, and the frame possibly 1958. Seems unlikely that an older hub would be installed on a newer frame, but I'm pretty much accepting anything as possible at this point. It would seem that this frame was powder coated, and the headbadge (original?) appears to have been "JB Welded" (no rivets) onto the tube; probably doesn't show well in the photo.
Liked 103 Times
This one is a mystery to me. Every Raleigh I've seen has shaped head tube lugs. This does have the Raleigh style rod brake linkage piece that pivots on both sides of the down tube. Most other manufacturers used a single arm on one side. It looks slightly different than the linkage piece on my Raleigh, but that might just be the angle of the photo. That flip top oil port on the bottom bracket was used on Raleighs from the mid 50s to around 1960.
Inflate Hard
Inflate Hard
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Picked up a 1948 Royal Enfield at the ABCE this weekend. Photos soon...
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
USMC 1981-1991 Semper Fi!
Quoted: 359 Post(s)
Liked 265 Times
Those tubular tires were a pain in the rear to install but they paid off for the Gravity Race.
Bikes: Kona Sutra, BMC SLX-01, BMC CX-1, Ridley Fenix, Claud Butler European, '50's Humber Roadster, '53 Rudge Pathfnder, '94 Trek 930, '48 Rochet Super Special, 60's A. Boisis "demi-course"
Quoted: 8 Post(s)
Liked 7 Times
Re: Post 21229 "1950 Superbe Update"
Since I'm a "Newbie" I cannot actually link to the original post, hence the reference above.
Hi,
Beautiful job on the bike!
Re: the shifting issue: if the Indicator rod is set correctly in "normal" N, perhaps your shift cable length is too long. Sturmey Archer normally specified a 17-1/2" outer with a 21-1/2" outer available for special conditions. To quote from the '50's/60's service manual: " the outer cable should allow full movement of the handlebars but otherwise should be kept as short as possible, as it tends to compress in lower gears and any length over 21-1/2 inches may affect the gear adjustment adversely".
Visually, this isn't intuitive obvious, so my experience is that you cut the outer cable to the specified length and adjust the fulcrum and shifters to end-up with a "best fit/relatively smooth" cable run.
Hi,
Last edited by littlevikingca; 09-16-19 at 03:45 PM. Reason: aded post reference, spelling correction
This one is a mystery to me. Every Raleigh I've seen has shaped head tube lugs. This does have the Raleigh style rod brake linkage piece that pivots on both sides oe f the down tube. Most other manufacturers used a single arm on one side. It looks slightly different than the linkage piece on my Raleigh, but that might just be the angle of the photo. That flip top oil port on the bottom bracket was used on Raleighs from the mid 50s to around 1960.
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Quoted: 8 Post(s)
Liked 7 Times
Thanks Clubman,
I'll add the link and share some photos after my 10 posts.
Cheers,
Dave
Cheers,
Dave
Quoted: 515 Post(s)
Liked 167 Times
Quoted: 1607 Post(s)
Liked 2,586 Times
Put this Humber Sports back to together, 70'?
I'm guessing the bracket is for accessories?
Quoted: 8 Post(s)
Liked 7 Times
Hi,
Yes, that is the mount for the headlamp. Suitable head lights will have a bracket that slips over the bracket and can be clamped in place to set the "tilt". It also acts as a "non-rotational" washer for the headset. It has a small tab that engages with a vertical slot in the steerer tube that prevents the locknut from rotating the upper race while tightening.
Cheers,
Dave K
Cheers,
Dave K
Quoted: 331 Post(s)
Liked 332 Times
FW Derailleur Drive Chain
This is a Crimson Star on a 1903 Sunbeam
9
Six Speed Conversion Sh*t Show
What I thought would be a simple project has
been somewhat frustrating but there is a light
at the end of the tunnel....
I set the bike up yesterday and bought a 3/32" 10 speed chain assuming the 1/2" pitch
would be compatible.
It wasn't.
It binds on the chain ring and refused to engage the smaller cog..
I'd had enough and let it be.
Today I added a couple of washers to the derailleur rollers to expand
the width to accept a standard 1/8" chain.
All seemed good.
Until I installed the master link which now
catches on the derailleur cage
I'm not dissuaded. The 3/32" chain was only $15.00 and the
1/8" chain was cobbled together from a couple I had lying around.
Tomorrow's another day......
It wasn't.
All seemed good.
Resilion made these uncaged derailleurs to accommodate the wider links. This is a seven speed Crimson Star.
This one bolts onto the chainstay rather than on a hanger secured by the axle nut.
Liked 103 Times
Nice one. Could be 1970, but could also go back to the late 60s. Check the hub date stamp. It's really nice that it has the traditional Humber chainwheel. One of my favorites. Raleigh gave up on using the stylized brand specific chainrings on their acquired brands and started using their generic chainring around that time.
Inflate Hard
Inflate Hard
Liked 103 Times
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
I'll press on with my project and see if I even
like it.
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Your use of lighting and a small aperture for depth-of-field turns a technical photograph into a work of art. Very nice!
Liked 2,586 Times
Liked 443 Times
As Homer Simpson said:
"Never Try...."
The double cog project is on an indefinite hiatus..
I tried to take it for a spin down the alley
The derailluer travelled too far and broke 3 spokes and popped
the cogs off the hub as well.
The bike has now been restored to it's natural state.
I prefer 3 speeds anyway.
I even put the shifter on it!
The cool one.
On the plus side, tomorrow, I'm delivering the Villager 3 speed project bike
to a deserving friend in Hamilton,
and with the right price coming home with
a 1955 Humber 3 speed.
"Never Try...."
The cool one.
Liked 103 Times
"Never Try...."
The cool one.
"Never Try...."
The cool one.
Inflate Hard
Inflate Hard
Liked 443 Times
