How to make reproduction Vittoria hoods
Quoted: 3015 Post(s)
Liked 3,804 Times
With all of the reproduction hoods on the market, I saw a gap, no Vittorria hoods. Probably because there are about eight people in the world who would want them.
Well I am one of the elite eight. :-p
And this stuff is easy for me, I like doing the process, so I borrowed some original Vittoria hoods from a friend to act as a pattern. The great part of this is that no damage occurs to the original part. And obviously, you can do this with any hood or other parts.
Please note you are seeing the first part off of the mold, which tends to be the worst. Also, I made no attempt to "improve" the original hood and its ugly parting line. Future parts off of the mold can be modified to be "pretty" and serve as a pattern for a new mold.
Vittoria hood, also known as a pattern
Hood 001 by iabisdb, on Flickr
Hood 002 by iabisdb, on Flickr
The Vittoria hood has the great advantage over other brands as its main core shape is a cylinder. I used a 1" diameter PE pipe with the ends eventually filled with Sculpey clay. Sculpey does not react with the silicone mold material whereas an oil-base clay will cause an adverse reaction. The cable routing core is a stainless rod which will also act as the sprue pattern.
Hood 003 by iabisdb, on Flickr
Hood 004 by iabisdb, on Flickr
A simple container made with 0.75" MDF and wood screws. A counter-sunk hole at the bottom receives the stainless rod for the pattern placement in the mold.
Hood 005 by iabisdb, on Flickr
Hood 006 by iabisdb, on Flickr
Silicone rubber and catalyst from Freeman supply. About a 35 Shore A.
Hood 007 by iabisdb, on Flickr
Pattern release from Freeman Supply. Basically an aerosol navel jelly. Using a silicone pattern release with a silicone mold will cause an adverse reaction.
Hood 008 by iabisdb, on Flickr
The vacuum pump on the left is the most expensive part of the process. I recommend a good one, goes fast. The vacuum chamber is just a metal pot, rubber sealing gasket, plexi lid so you can see in and an air hose nipple. Obviously air tight.
Hood 009 by iabisdb, on Flickr
Mixing silicone rubber and catalyst. 10:1 ratio by weight.
Hood 010 by iabisdb, on Flickr
Quoted: 18378 Post(s)
Liked 4,512 Times
Wow, that looks like an ambitious project. I can't wait to see the finished product.
If it turns out... perhaps throw some up on E-Bay.
Liked 3,804 Times
Mixed silicone. Note volume as when degassing, the volume will double.
Hood 011 by iabisdb, on Flickr
Degassing the silicone in the vacuum chamber eliminates tiny bubbles in the silicone which will ruin the mold. Note the doubled volume.
Hood 012 by iabisdb, on Flickr
The pattern was sprayed with the pattern release. Silicone was poured to the hood's original parting line.
Hood 013 by iabisdb, on Flickr
Hood 014 by iabisdb, on Flickr
After spraying again with pattern release, the second half of the mold is poured.
Hood 015 by iabisdb, on Flickr
Removing both parts of the mold and the pattern from the container.
Hood 016 by iabisdb, on Flickr
Separating the two sides of the mold. Please note the alignment notches.
Hood 017 by iabisdb, on Flickr
Both halves of the mold with the pattern removed.
Hood 018 by iabisdb, on Flickr
Both halves of the mold with the core in place.
Hood 019 by iabisdb, on Flickr
An illustration of the injection method. The urethane used gels quickly and I don't want it to setup while I am taking a picture.
Hood 020 by iabisdb, on Flickr
Liked 3,804 Times
After injection. Please note the cavity on the left is a tapered vent hole to release air during injection. At the part level, the vent hole diameter is 0.060" to minimize cuts needed to remove the vent material. Also not the rubber bands to clamp the mold together. I used and recommend a 35 Shore A 2-part urethane for this application. It can be purchased at Freeman Supply or any other mold-supply company.
Hood 021 by iabisdb, on Flickr
Removal of the bottom part of the mold. Please note for this part the urethane was not degassed as shown by the micro bubbles. I also only had blue colorant on hand at the time of molding. I used and recommend a 35 Shore A 2-part urethane for this application. It can be purchased at Freeman Supply or any other mold-supply company.
Hood 022 by iabisdb, on Flickr
Both halves of mold removed with the part remaining on the core. Sprue and vent material uncut. Please note for this part the urethane was not degassed as shown by the micro bubbles. I also only had blue colorant on hand at the time of molding. I used and recommend a 35 Shore A 2-part urethane for this application. It can be purchased at Freeman Supply or any other mold-supply company.
Hood 023 by iabisdb, on Flickr
Original and new together. Please note for this part the urethane was not degassed as shown by the micro bubbles. I also only had blue colorant on hand at the time of molding. I used and recommend a 35 Shore A 2-part urethane for this application. It can be purchased at Freeman Supply or any other mold-supply company.
Hood 024 by iabisdb, on Flickr
Hood 025 by iabisdb, on Flickr
Likes For iab:
Quoted: 556 Post(s)
Liked 132 Times
Oh wow! Absolutely super, Iab. This is the most interesting thing I've seen in months. Here or anywhere else.
Very cool. Great job.
Still learning
Amazing Iab. So how many hours of time to produce the molds and then how much time to produce the hoods?
Liked 3,804 Times
My time to make the mold is 8 hours. My time to make a single hood is maybe 15 minutes. It obviously would be faster if I made more molds. But I'm lazy. And silicone is not cheap. And if make 2 sets that should last me a decade or two.
Demolding is 16 hours, both for the mold and a single hood. You can actually do it less than that though. I can get 2 hoods a day if I wanted. But I don't.
For selling. Sure, why not. But I am the worst retailer in the world. The customer can wait when I am good and ready. And if they change their mind, I don't care at all.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Very cool!
So, there's no shrinkage? The reproduction matches the original in size?
I suppose to make a more complicated shape, like a Campagnolo hood, you would need a three piece mold... start by casting a mold from the inside of an original... hmm. Very cool.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 3,804 Times
No shrinkage. The hoods are never in a pool.
A Campy hood would be still two parts. The core would need to be more complex.
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
Ummm wow that was pretty dang impressive! Hilary Stone also sells repop Vittoria hoods but for $50. I'm surprised no one hasn't done gum hoods for Ergopower shifter to go along with the silver Athena group.
Quoted: 1361 Post(s)
Liked 424 Times
~ Blue Ribbon award ~
No need for them but they're so cool! Thanks for the outstanding demonstration and education.
BTW: If anyone is considering a low cost alternative to a vacuum pump, look into an inline vacuum generator + on/off valve that uses a conventional air compressor. The tiny vac. gen is basically a venturi with exhaust port. Handy for small projects like the above or veneer glue downs on wood (along with with bag), etc..
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Damn cool! Now I've gotta find a project to apply this to...
Very Impressive.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Bikes: 1972 Motobecane Le Champion, 1976 Motobecane Grand Record
Quoted: 24 Post(s)
Killer work! I resin and rubber cast by trade myself and I never thought of making hoods! Im gonna do it to the Mafac ones I need since I need a few sets of half hoods.
Quoted: 786 Post(s)
Liked 520 Times
Very impressive. Glad to see folks tackling repro unobtanium hoods. Campy NR/SR from Italy, Mafac half-hoods from Rustines in France, and now these. Well done. I hope somebody takes on Shimano 600 EX 6209 hoods.
Quoted: 834 Post(s)
Liked 2,128 Times
Dia-Compe replacement hoods are available at Velo-Orange in a variety of colors. Less than $20 and work fine. Sure, maybe a little loose, but who cares except the period-correct police. Just kidding! Awesome and impressive work! I never knew I wanted Vittoria brakes.
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Dia-Compe RGC Aeros next! Nobody makes them.
Liked 4,512 Times
Hmmm,
Apparently not completely impossible to source.
Hilary Stone Spare Parts Brakes
Repro, Only £32
Repro, Only £32
Great work!
How necessary do you think the vacuum chamber is? I've made a ton of polyurethane rubber molds for concrete work without one and with good results, but I can see the detail in that hood might be hard to get otherwise.
I really love seeing people remake stuff that's NLA. As 3D printing plastics and metals continues to improve and go down in cost, NLA won't be so much of an issue in the future, and that's pretty cool. Thanks for sharing your process.
as well as 'rubber' cable bands
David, an excellent photo essay. Hopefully it will inspire others to add to the otherwise difficult to source items.
Quoted: 378 Post(s)
Liked 1,410 Times
Well, we've seen bikes built around cranksets, shifters, wheelsets, calipers, and now, hoods......
Any excuse, any excuse.
Chicago 'hoods. I've heard of them.
