Increased ability to burn fat instead of carbs = increased FTP?
Quoted: 28 Post(s)
I could have sworn I read something like this in an article or a book, but I can't remember where it is from.
Does anyone have a citation for this factoid?
I think it means that if you increase the power at which you can burn fat instead of carbs, your FTP will also go up.
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
I think he is saying it right.
If you look at FTP as wHr of power, increasing mitochondrial density and ability to metabolize fat with O2 means you can produce more watts for the hour. Don't think there's a way to really increase liver glycogen or glycogen burn rate.
@echappist should set us all straight.
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Base training (those long, lower intensity rides just at/under aerobic threshold aka ventilatory threshold 1) increases mitochondrial density. More mitochondria = more fat burning capacity. But the mitochondria are also key to lactate clearance, which has a big effect on FTP/MLSS. I first read about this in Thomas Chapple's Base Building for Cyclists, but I'm sure it's been discussed elsewhere.
I can definitely say that long steady Z2 rides during the base season have helped increase my FTP.
Quoted: 28 Post(s)
Should you not do much too Z2 base after some point (build period?)?
Quoted: 28 Post(s)
Killing Rabbits
Quoted: 278 Post(s)
Liked 217 Times
https://en.wikipedia.org/wiki/Respir...exchange_ratio
https://en.wikipedia.org/wiki/Respiratory_quotient
High FatMax improves long endurance much more than FTP.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
The only thing that's increased my ftp is stuff above ftp.
Last year I built up to doing 3 hours of sweetspot at 89% ftp and that didn't help, but doing 5-6 min repeats at 115-118% helped tremendously.
Could be highly dependent on each person and their previous training, however. And there's typically more than one way to do many things.
I very rarely do any type of z2 rides over an hour, so the traditional "base" of 3-5 hours at z2 is a total waste for me, and boring as hell anyway, so no way I even bother with it at this point in my life.
Quoted: 28 Post(s)
No, fats require more oxygen - but unless you are near VO2max oxygen delivery isn't really limiting.
Quoted: 28 Post(s)
I could have sworn that cranking up the difficulty of my Zwift workouts, which put me at higher percentages of FTP, had almost overnight results.
Quoted: 1975 Post(s)
Liked 232 Times
I think the answer depends on how you go about increasing the fat adaption, if you are using diet for say keto or carb depletion then the fat adaption likely comes at the expense of glycogen dependant power production. If you are increasing fat adaption using long base or intermittent fasting rides during base then the % contribution of fat could potential increase your FTP, the percentage contribution at FTP is likely <10% so its probably not going to make much of difference, where it makes a bigger difference is in glycogen sparing in the Z2 range.
Quoted: 160 Post(s)
Quoted: 28 Post(s)
I have a copy of the 4th edition but I have found it kind of hard to read.... plus it's really thick.
It seems to me that most of the book is about peaking and periodiziation, which isn't relevant to me since I don't race yet (still in training, trying to learn how to suffer).
What parts are most useful if you just want to get fast as fast as possible?
As an example, a sweet spot workout might be 4 x 12 minutes at 95-98% FTP, whereas a VO2 max workout might be 6 x 3 minutes @ 120% FTP. A well trained athlete should find both interval sessions equally challenging.
If you lack muscle endurance, you'll find the sweet spot workouts to be more challenging. If you lack the lungs, you'll find the VO2 max workout to be more challenging.
Forget get the book,.....your quickest way of learning how to suffer is entering a race. Do 3 crits and then pop open the book, it will make more sense and give you a better understanding of what your homework needs to be.
Bikes: bikes
Liked 1,429 Times
I'd say it's more likely an issue of doing something until it doesnt work anymore, and then doing something different. Alternate the stimulus to force the body to keep adapting. Same principles apply to cat 5s, too.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
Quoted: 28 Post(s)
OTOH, there were no ability level groups, and there were collegiate racers there, so it was the equivalent of doing a Cat 1/2/3 race as Cat 5.....with 70 pounds of excess weight.
I weigh less now.... but I'm going to try something flat first.
Quoted: 28 Post(s)
Will do.... still need to lose 40 pounds though.
Man, I wish there were shortcuts for this stuff!! Let me know if you find any.
What I mean is going from couch potato (2.0 watts/kg) to 3.5+ watts\kg as quickly as possible, not going from 4.0 to 5.0 LOL
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,568 Times
Some of you guys need an account over on the Slowtwitch triathlon forums. This would go over well over there.
Andy Coggan frequents the forums along with a few other brainiac types.
Out of curiosity, are you a good 40K TT rider?
I can imagine that a CAT1 who can hold 100% FTP for nearly an hour will find subthreshold intervals to be much easier than, say, someone like myself.
¯\_(ツ)_/¯
Quoted: 967 Post(s)
no.
hurt is hurt. that phrase "it never get's easier you just get faster" is a lot of bull**** in regards to racing, but it's spot on for intervals.
