klunk noise
klunk noise
Hi
I have a klunk noise as the left pedal passes 12 o clock - ONLY - when pedalling upbank (under strain etc)
Any of you learned cycle wizz maechanics tell me what the problem s anfd how to fix it
regards
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
What kind of Bike?
What Crank?
Only on the Left?
How old are the components?
What Color is the bike? (just kidding)
Some Possibilities:
Loose Crank Arm
Bad Bottom Bracket
Bad Chain-ring and or Cog
Bad Chain
Cracked Frame
Need more info to be more helpful to you.
What Crank?
Only on the Left?
Some Possibilities:
Loose Crank Arm
Bad Bottom Bracket
Bad Chain
Cracked Frame
a few answers
Hi
Thanx for prompt response
What kind of Bike? emmelle trojan
What Crank? pedal
Only on the Left? yes
How old are the components? 10 year - but rarely used
What Color is the bike? (just kidding) polished aluminium - serious
regaards
Fossil
My click when going slowly uphill turned out to be an extra bearing in one of my rather inexpensive after-market pedals. I retorqued a lot of other things before that came to light.
Haunted
Bikes: brandomly generic 29er
Rejoice and be proud!
Oh, wait... it happens when you're pedalling up to the bank?
Ooooh... that's not so good...
Bank security guards tend to frown on the KLUNK noise, at any time during banking hours.
Better not ride your bike to the bank, I'd say.
Now, if instead, it turns out to be a ''clik" noise, like that one you had back in 2004, well, I'd say you'd better just forget about pedalling altogether.
Hi
It was the chain hitting the cage - there was not the 1-3mm clearance above the largest chainwheel to the cage
Thanks for the help and response
regards
regards
