Talk me into a smart trainer?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4426 Post(s)
Liked 3,055 Times
(I know that there have been previous threads like this, but not recently it seems....)
I'm thinking about a smart trainer. I don't really need one, but it's kind of like one of the N+1 thoughts.
I have an older dumb Kurt Kinetic trainer. It is 10 years old, but seems to be nearly indestructible. It has the larger flywheel on it.
I get my power numbers from my (Favero Assioma) pedals.
I use an older road bike that is dedicated to the trainer - I don't ever have to mount or dismount the bike from the trainer.
I ride Zwift a fair bit in the winter. Not usually racing (but occasionally). Mostly with the pace partners, a few group rides, and during the late winter/early spring interval workouts.
It is totally adequate. Probably the biggest hassle is during shoulder seasons, when I'm going back and forth between indoors and outdoors, and so I have to swap the pedals between bikes. During the winter, I'm not riding a road bike outside, and so the FA pedals stay on the trainer.
But I'm tempted by testimony that a smart trainer gives a more "realistic" experience. And the Wahoo Kickr Core is now only ~$600.
Regarding intervals, I actually think that the "smart" features could be a hinderance? If I want to maintain constant power through an interval, having the resistance change with the terrane would be a detriment. Would I always have to do my intervals on Tempus Fugit, or do smart trainers allow you to turn off the resistance changes with grade? Or does "erg" mode take care of this?
Folks who have made the switch - particularly those mostly riding in the Zwift universe - how much of a difference has it made to your experience?
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 186 Post(s)
Liked 176 Times
if you are doing a workout the workout controls the resistance. If you are in an event or free ride ERG mode most definitely adjusts resistance based on the games terrain, incline, decline, and surface.
Sir Mark, Knight of Sufferlandria
Quoted: 119 Post(s)
Liked 23 Times
Personally, I like the SIM mode and switch gears. It's far more like being on the road.
Quoted: 119 Post(s)
Liked 23 Times
"Question: which bear is best. False. Black Bear."
Quoted: 317 Post(s)
Liked 685 Times
A smart trainer is definitely worth it over a "classic" trainer, even if you do not use Zwift. There are a number of other platforms you can use too (FulGaz, TrainerRoad, indieVELO, Wahoo SYSTM, etc). They all have their strengths and differences. The smart element of automatically adjusting resistance does make the virtual worlds far more immersive and "enjoyable" to ride indoors.
You can ride in ERG Mode and a smart trainer will lock you into the correct resistance. All you need to do is keep pedalling. You can switch off ERG if you wish and use the terrain to control resistance also, like if you were completing the interval outside.
That is not ERG Mode. That is regular SIM Mode, where the resistance automatically adjusts based in terrain.
ERG Mode is where the trainer locks you into a certain power (and resistance) to match your prescribed interval power number during a workout.
Likes For tempocyclist:
Quoted: 186 Post(s)
Liked 176 Times
Thanks tempocyclist for correcting my errors in terminology. To me the difference between the two is moot. In workouts the app controls the resistance, granted based on power targets, while outside of workouts the app controls the resitance based on terrain. In both cases the app controls the resistance. There are also other settings with a smart trainer, such as level mode.
Likes For Black wallnut:
Habitual User
Quoted: 5043 Post(s)
Liked 8,286 Times
Likes For Eric F:
Liked 3,055 Times
Likes For MinnMan:
Liked 3,055 Times
Thanks for the input folks. I may go for it.
But I might be more confused about ERG mode than I was before I read your posts.
Habitual User
Liked 8,286 Times
ERG mode is based on just watts. In a programmed workout, a segment will be X duration at Y watts. Let's say the work segment of your chosen program is 30sec @ 500W. When you get to the start of that segment, you will need to put that many watts into the pedals to keep the bike moving in the virtual world. Cadence is irrelevant. You can do 500W at 100rpm or 50rpm, as long as it's 500W. Your cadence may even vary during the segment and the computer will adapt to it. (Note - Some programmed workouts have a recommended cadence for each segment). When that segment is over, there will be a new demand for X duration @ Y watts. Once you experience it, it will make total sense.
Quoted: 4537 Post(s)
Liked 5,040 Times
Ignore "False" post #3
Liked 3,055 Times
These explanations help, but I'm still not sure my interval workouts would benefit from a smart trainer.
To do an interval session now, I simply decide that my goal is, say, 3 sets of 5 X 1 minutes at 350 watts. I don't have to program anything, I just watch my power during the intervals and adjust my effort. If during the last interval I can't maintain 350 watts, I do what I can - 340 or 330 or....
In truth, I don't even need zwift for this, but watching the scenery go by is a nice distraction and zwift, transferred to Strava, easily produces a nice record of what I've done that I can go back and examine.
Randomhead
Liked 3,757 Times
Intervals on a smart trainer are nice, because you don't have to do anything to change the power level. I liked not shifting, my trainer bike doesn't exactly have the best drivetrain. The downside is if you fail to hold the power level. I assume that's accommodated by software somehow. Someone that does intervals on zwift can fill us in.
Liked 3,055 Times
Advocatus Diaboli
Quoted: 4760 Post(s)
Liked 1,542 Times
Quoted: 119 Post(s)
Liked 23 Times
To the OP:
If you are tired of switching pedals then it seems like you have one of two choices:
1. get another set of pedals
2. get a new trainer w/a power meter built in
If getting new pedals doesn't excite you, and a smart trainer is actually cheaper, then there really isn't any downside. You can set it up to run like you are now AND you get the added benefit of being able to try Sim mode which, to me at least, is a load of fun.
Therefore, IMO, your question actually is "how tired am I of switching pedals?" Are you $500 tired?
Or if you just need that GAS-induced push to get a new toy -- I will say a Smart trainer is worth it, IMO, exactly for the option of the Sim mode.
edit - one other question - would the new trainer be quite than your old one? Is that something you would value? My Wahoo Kickr is pretty darn quiet. My fans are louder than my trainer. If your trainer is old enough - maybe it's loud??? Just a justification for exploring the switch
Bikes: yes, i have one
Quoted: 1151 Post(s)
Liked 1,193 Times
most apps have this feature.
Liked 3,055 Times
To the OP:
To that end, I begin to wonder the new Wahoo Move, and so on. But I'm not prepared to pay that price tag...
Liked 3,055 Times
BTW, in a group Zwift ride one "feels" the hills without a smart trainer b/c you quickly sense that keeping with the pack requires increased effort.
Randomhead
Liked 3,757 Times
Trainerroad has the +/- thing. I have only used it to increase power on very short intervals. But TR also seems to do okay if your power drops too far and doesn't simply lock the trainer up because you aren't at the power setpoint. It seems to drop the requested power if you get some % low, like 20%. I saw that the new Kickr bike has a feature along these lines.
Quoted: 186 Post(s)
Liked 176 Times
Quoted: 4255 Post(s)
Liked 2,973 Times
I used to use a power meter (either powertap hub or assioma duo pedals) with rollers with progressive resistance. When the fork stand on the rollers broke, I switched to a smart trainer (elite direto xrt). I don't think I'd switch back. So much more enjoyable with the resistance changing. Makes keeping up with groups easier too. A rocker plate made the setup even nicer.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
