Shop Bending Aluminum handle bars
my nice bike is at home
I was musing to a local bike shop mechanic about how I might alter the sweep and bend of a set of bars.
He said, horrified, "I would never ride on that bike! "
I was thinking...how does he know he is not talking to a metallurgical expert?
He wasn't..
...so I am asking here: if I properly anneal the bars first and use the correct-size pipe bender,
can I tweak the sweep of my bars? They are Velo Orange Tourist, just want to 'tuck' them back a bit.. so they don't 'wing-out' so much.
Maybe 1/4" each side? Any of you people have experience w/ this type of adjustment?
He wasn't..
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
Quoted: 519 Post(s)
Liked 453 Times
I wouldn't if they were heat-treated. Otherwise, as long as you don't get too crazy, why not?
It's funny. A few of the guys I started racing with had Peugeot PX-10s and Gitane Tours de France, and after a couple years their stock bars that lacked reinforcement sleeves would sag from the stem. And sometimes they got bent in a crash, and we'd pull them straight again.
Quoted: 5859 Post(s)
Liked 2,702 Times
As noted above heat treating is a critical consideration so the following assumes they're either not he treated at all or you properly anneal them first.
That said, certainly you can recurve the bars. That's how they were made in the first place. It's also how we saved crash damaged bars all the time, before everybody became paranoid about product liability lawsuits.
The key is to properly support the bar especially at the fulcrum of whatever you're using for leverage so you don't kink it, or produce a concentrated local bend. Since you're only talking about a slight change the curvature you should be fine as long as you're careful.
Quoted: 1438 Post(s)
Liked 1,092 Times
You can fill the bar with fine sand before bending them to help avoid it collapsing at the bend.
Bikes: old ones
Quoted: 26460 Post(s)
Liked 10,418 Times
...I am much less adventurous, and threw these away. They frightened me.
Bikes: old ones
Liked 10,418 Times
...to the OP. I don't know definitely about your VO bar, but I suspect it is one of the modern alloy bars that are heat treated as a matter of course. It's how they make them lighter, out of thinner alloy tubing, and stronger nowadays. If all you are bending is the ends a little bit, you can probably get away with it. The major issue with an alloy bar breaking is when they break close to the stem, and you end up with one half of the bar waving around in the air, unable to steer, and with a very surprised look on your face.
At least, that's what I think I looked like, the one time i busted an old French handlebar. Very surprised...didn't have time to proceed to frightened.
Honestly, I would probably just shorten the ends with a tubing cutter, before I tried bending them. That should narrow them down a little.
Quoted: 4224 Post(s)
Liked 3,917 Times
This question is one of those "if you have to ask than you don't know enough to do it" ones. I've watch a few handle bars crack and separate during riding, thankfully from the results I saw none were my own. But, hey, it's your bike and your risk value judgement. Just don't ride in any groups please. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2524 Post(s)
Liked 3,010 Times
Likes For Trakhak:
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 520 Post(s)
Liked 433 Times
related to the topic, if you want more info..... and just plain fun. I bent a set of Noodle bars and opted to throw them away. I was nervous about bending them AND them being heat treated.
cheers.
cheers.
Likes For mrv:
Bikes: Bicycles? Yup.
Quoted: 487 Post(s)
Liked 1,622 Times
I tossed 'em this morning. At first I considered using them, 'the bike is more for show than go' and new tape will cover the dings...WTF am I thinking!
Into the recycle bin, next to the AVA stem that lost an epic battle for Who Controls the Fork.
Likes For BTinNYC:
Quoted: 519 Post(s)
Liked 453 Times
Makes me chuckle, though. I'd worked on a Specialized model, probably early versions of the Roubaix, that had an adjustable quill stem and an "anatomic" bar that drooped and swept back from the 25.4 mm center clamp. It was the ugliest looking most unusable bar I'd ever seen on a bike. Some crazy ideas went down in the name of Body Geometry.
Likes For oldbobcat:
Quoted: 519 Post(s)
Liked 453 Times
Then maybe 45 years later pulling the tape off vintage bars and there's weird perpendicular dings and stressy marks near the stem, "what's this?" 🤔
About 10 or 15 years ago, a lot of guys were reporting that the spindles on their Lyotard 460D pedals were breaking, as if it were some major indictment of French metallurgy. Well, of course, Lyotard wasn't as good as Campagnolo, Shimano, or even MKS. But they'd gotten over 40 years of service from those pedals. What is the problem?
I got rid of the stock bar on my Raleigh International early on, just because I wanted something wider and stiffer for more confident sprinting. The first was a nifty GB bar. But in my club we all used Cinelli or 3T bars and stems eventually.
Bikes: old ones
Liked 10,418 Times
...here is the VO page on this "Tourist" bar. Maybe I need a secret decoder ring, but I'm unable to find that information on the VO page. Is there some other link I'm missing ?
Quoted: 519 Post(s)
Liked 453 Times
A $42 tourist bar isn't going to be heat-treated. But just to be sure, I messaged VO. I'll let you know when I hear.
Bikes: old ones
Liked 10,418 Times
...whether or not it's heat treated, why is it you insist on telling this guy that bending aluminum alloy ---any aluminum alloy---is a good idea ?
I honestly do not get it. If he wants only to narrow the span of these bars by a couple of inches, there's plenty of excess on the ends to remove with a plumbing cutter.
Quicker, probably easier, certainly less problematic in terms of adding additional stress to the stress risers that might already exist at the bends. Just because you can do something doesn't mean it's a good idea. If there's a way to accomplish the desired result that does not involve bending in the operation, why not avail yourself of it ? What am I missing here ?
Quoted: 4845 Post(s)
Liked 3,972 Times
The thing about soft aluminum is it will give you plenty of visual warning before it fails. But you gotta look under the tape. And 45 years is a half lifetime. Int the early '70s our bikes were all less than six years old.
And those platforms. I rode many pairs into the ground but never got them to last to spindle failure. That same fix gear. I'd loosen all the pressed joints in the pedal body. (And unscrew the left pedal caps with pedal scraped, UO-8s on sewups being VERY low bottom bracketed.) I still have a book of about 10 pounds of dead Leotards here somewhere but maybe one dustcap.
Fun memories. Thanks!
Liked 3,972 Times
But closer to this thread - I don't even consider doing additional bends to modern aluminum bars. The old bars often fails like the GB of my last post, by bending, Hand still attached to the stem so rider probably still on the bike. All good. Modern, higher strength, thinner walled bars rarely bend, last longer but when they go, they break into two pieces. Those cables and housings are very poor substitutes for even 30 degree bent aluminum.
Plus I know all too well what can happen from a total failure between the front rubber on the road and my hands.
Edit: Instead I have had a bunch of stems custom made to put stock bars where I need them.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1241 Post(s)
Liked 327 Times
You're asking about alu bars that can corrode in 2 years from sweat under wrap?? LOL.
Quoted: 569 Post(s)
Liked 596 Times
How to handle a possible outcome, about 55 seconds in:
Still he finished third in this the 1989 Worlds with only the stem.
Quoted: 519 Post(s)
Liked 453 Times
They'd have been bankrupted from lawsuits long ago if all the handlebars assploded.
Quoted: 1149 Post(s)
Liked 1,773 Times
Those bars were failing in the 70's, usually after being coldset from being drooping.
the Lyotard pedals also historically would break.
Another that would break is the pedal eye of Avocet triple cranks of the early to mid 80's cranks.
Quoted: 519 Post(s)
Liked 453 Times
If it were my bike I wouldn't even bother, and I'm not encouraging him to do it. I've just seen handlebars made that way that kept working long after worse things happened to them.
Quoted: 511 Post(s)
Liked 646 Times
I think you said you were not a metallurgist, right? How then do you know how to "properly anneal" the bars? As I understand it, the annealing process depends very much on which alloy you have. But then I am not a metallurgist.
Likes For KerryIrons:
Quoted: 18419 Post(s)
Liked 4,532 Times
The thicker metal bars are likely 6061 or similar aluminum. The thinner bars would be 7000 series aluminum.
The OP seems to be aware of heat treating, and wants to first anneal the metal. If he can do that, perhaps he also has full heat treating capabilities.
Where do handlebars break? I'd assume that they are most susceptible to catastrophic failure within 2" of the stem. Bending the ends of the bars may not be a high stress area, assuming the bend is somewhere beyond the brake mount.
