tube and lug kits / practice
Quoted: 2338 Post(s)
Liked 2,827 Times
I have been watching and am fascinated building my own frame.....not sure I ever will, but was wondering if anyone knows of supply places offering full kits of tubes/lugs? just seems to be a good base.
Only on I seen now is, Richard Sachs..... certainly would a a quality start
practice: any ideas for sources for practice 4130 ? or anyone willing to put scraps in usps box and send (pay for it of course)
Randomhead
Liked 3,699 Times
Lugs are relatively expensive. Ceeway used to have a full kit, I think I recently saw they wanted $190 or something like that. Nova used to have kits, but they are gone. I used to buy their columbus SL kits, those were a bargain.
When I wanted to practice for using brass with lugs, I cut out some 4130 rings in lengths from 1/2" up to 3". If you can braze from one end of a 3" sleeve to the other, you can braze any lug.
Bike tubing is inexpensive for what it is. But one issue for practice is the butting. You used to be able to buy TrueTemper straight gauge, but they are long gone now. I feel like 4130 is better for practicing.
One more edit: I think a lot of people buy nice stuff for their first frame and then botch the frame and don't want to just cut it up. The nice thing about cheap tubes is you can go into building a first frame with the idea you are going to cut it up.
Yet another edit: you might look on ebay
Quoted: 321 Post(s)
Liked 263 Times
I would practice on old bike frames. I happened to have a 4130 Trek that broke. By the time I'd cut it up into pieces a few inches long and welded them back together again at various angles I just about had the ability to make my first new frame. I TIG everything but you can probably heat the lugs off an old frame. Or make some lug-like things for practising. The steel alloy doesn't matter but the thickness does, especially for TIG: you need to be able to handle thin walled tubes.
Quoted: 4210 Post(s)
Liked 3,875 Times
Many of us did recycle old frames into practice material but the time it took to clean off the paint was taking away from the practice torch stuff time so speaking for myself I suggest raw tubing as a first choice. There are a lot of on line sellers of 4130 tubing. Aircraft Spruce, Stockcar Steel, McMaster-Carr, to name a few on my saved list.
I save my cut offs (sometimes called drops by the metal supply industry) for practice and small projects. I do have a box full right now and would send someone some of it (cost to be agreed on) if asked. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
On occasions, I had seen lugs on eBay that were quite affordable. You may want to try checking.
Well, here you go:
https://www.ebay.com/itm/16648137608...Bk9SR-qPtseiYw
https://www.ebay.com/itm/30397920124...Bk9SR-qPtseiYw
semi-retired framebuilder
Ceeway still has a couple of options of starter frame kits, a standard diameter set for £188.95 and an oversized set for £194.95. They are very complete. See the scroll bar at the top of their website - Tube and Parts Bundle if you haven’t found it already. Peter gives excellent service.
Likes For Mark Beaver:
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I have a bunch of random lugs that would be good for practice. They came as part of a package of tubing and bit I bought during peak pandemic. Happy to send you several of them for postage. PM me if interested.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Speaking as someone currently going through this - consider modifying an existing frame. I am taking a 21" and changing the stack/reach to test out the geo I think I want, before spending $400 on new steel. The only thing I purchased is a head tube (20 years ago, actually). For me this is proving to be a low cost way to try out the techniques, figure out processes and experience the joy of a fillet-brazing, where the goal post comes into view very quickly.
For new tubing to play around with, some places have mixed bags and drops for a discount, although at the end of the day the shipping is going to get you no matter what.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I don't have tons of spares, but I've got a few random tubes and lugs that may be helpful. Yours for shipping cost. PM if interested, and I'll pull out the spares box to see what, if anything, is of interest.
Ed
Ed
Randomhead
Liked 3,699 Times
I just went and looked at a couple of U.S. based suppliers. Cheapest tubes/lugs were at framebuilder supply. Columbus Cromor is really cheap, but chainstays and seatstays really add up. So you could just make a couple of main triangles.
I feel like Joe Bringheli could put together an inexpensive practice kit for you, but I haven't heard his status recently. Last time I ordered from him was a long time ago. He went out to the shed to look at what he had in stock and called me. I bought a batch of Zero Tre from him for practice, enough to get a quantity discount.
If you want to ride your first frame, put something really valuable in the top tube to motivate you to cut it up. I would say your wedding ring, but that might cause trouble. Maybe just a stack of Starrett hacksaw blades?
Quoted: 321 Post(s)
Liked 263 Times
Likes For guy153:
Randomhead
Liked 3,699 Times
I'm assuming a bird's nest wheel is called a "cup wheel" here in the states. I never had much luck with a grinder, always had to burn off the paint. Which isn't a good idea. I have a stack of tubes i want to get the paint off of. I was thinking about setting up a camping stove in the middle of the back yard and burning it off that way.
Likes For unterhausen:
Quoted: 321 Post(s)
Liked 263 Times
https://www.amazon.co.uk/Removal-Gri.../dp/B08MVLHR87
They're very good at taking off the paint and only the paint. If you're actually stripping a complete frame for repainting (i.e. not cutting it up) then the work is all the tight bits you can't quite get to with the wheel.
Randomhead
Liked 3,699 Times
Interesting, I have some of those. I'll have to try it. The tubes I want to strip are cut out of frames already, so no hidden parts. Removing paint mechanically is much better than the alternatives
Liked 3,875 Times
I have to admit the whole angle grinder world is foreign to me. Andy
AndrewRStewart
AndrewRStewart
Quoted: 321 Post(s)
Liked 263 Times
I know it's not the traditional framebuilder tool but I like it and use it for nearly everything. I don't have to worry about tube blocks because I can just hold a tube with one hand and cut it with the other (using a cutoff wheel). I mitre with templates and find it very quick and accurate just to sand up to the line with a 120-grit flap disk. Works better for me than filing. I also don't have to clamp the tube (and actually it helps to be able to roll it around a bit with one hand while holding the grinder in the other). I use the same 120-grit disks (when they're new) for sharpening tungsten electrodes. I also use it to clean up any flat parts like drop-outs ready for welding. And of course to remove tubes when modifying a frame or something has gone wrong.
Randomhead
Liked 3,699 Times
Angle grinders can be dangerous, so it's possible not having one is a good thing. I like to live dangerously, so I have 3. I recently got a cordless grinder. I have never used one on a frame though, I feel like my angle grinding game isn't up to something that aggressive. They are pretty useful for cleaning rust off of things before welding. Like our chimney cap that was rude enough to fall off.
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
I trust your standards are higher than his, I'm not lumping you in with him! Also I will grudgingly admit that my insistence on "water-tight" miters is overkill. I probably do let Perfect be the enemy of Good sometimes.
Randomhead
Liked 3,699 Times
I watch car guys doing miters just to make myself feel superior. Same with motorcycle guys brazing fillets.
Liked 2,576 Times
Randomhead
Liked 3,699 Times
The video I have seen of the guy using that method has horrible miters, so I can still feel superior.
I'll admit I don't have the patience for it.
Quoted: 321 Post(s)
Liked 263 Times
There's a youtuber who goes by something like The Fabricator. I watched his video on notching tubes, which he does for making roll cages for race cars. He notched with a flap wheel in an angle grinder, quite crudely compared to what I'm used to, and said something like "There — perfect tube notch!" Looked worse than the worst miter I have ever done, but I have no doubt it's good enough for the thick stuff he makes rollbars from. Thin bike tube would warp all over as those big gaps pull closed.
Car people (working with thicker walled tube of course) tend to actually bevel back the cut edge a bit if they use a hole-saw. Not so there's a gap but at least somewhere for the weld to go. Some YouTubers I have seen making bike frames notch with a hole-saw and then don't knock it back at all. This means the tubes fit perfectly, but there's actually very thin metal at the joint. Then they weld it with "pulse and lay wire" which doesn't add much filler. I have my doubts about the strength of that. For welding there's nothing wrong with a tiny gap IME. You can even fill quite a big one and get away with it if you have the welding skills to do that. But it's all about the fun and satisfaction of trying to do the best job you can which for me does mean improving fit-up.
Liked 2,576 Times
I'll never miter with an angle-grinder since I have at least 4 other ways to miter that are faster for me, and I think probably just a little more precise. Pretty sure I can have my miters done before you've even got your paper templates printed and taped on. But I have big expensive tools. 3 of my 4 ways (mill, lathe and belt-grinder set up for mitering) involve kilodollar expenditures and a certain amount of shop space that they take up, so they're not for everyone. Nice to have though, for things other than mitering.
My fourth way is filing, which I'm fast at because I made frames full-time that way for 2 or 3 years before we got a mill. No paper templates needed when you just "know" how the miter is supposed to look. Oh and you need the right sizes of half-round, that cut the correct radius "automatically".
I've told this story here a few times but here it is again: When we got a mill, I raced with Glenn Erickson, and he filed his faster than I got mine done on the mill. Maybe Glenn was a little faster than me at filing miters but I was close. I don't remember how many filed miters it took before I was good at it, that was 45 years ago. I don't think it was all that many though; I think the first time I did it (with expert supervision) was more than good enough, though of course slower than I got later with practice. I can't swear, from memory, that the accuracy was perfect, but I think they were pretty darn close since I was mostly making lugless tandems in those years, more demanding of miter accuracy than say lugged joints. We only got the mill because our tandems had one continuous way-oversized top tube that was pierced in the middle for the cap'n seat tube, which was smaller than the TT. That pierced hole was tricky and slow with a drill, die-grinder and files, piece of cake with the mill.
It's because of that experience filing miters that I think paper templates are a waste of time. Maybe useful for a first-timer, but after that they're slowing you down. With proper filing technique, the paper does nothing.
Likes For bulgie:
Quoted: 321 Post(s)
Liked 263 Times
As for mechanical mitring I am using that for one thing: joining steerers to fork legs (for a segmented or a unicrown fork). I made a fairly robust jig for holding the arbour from a cheap "tube mitring" thing in and I can get a pretty decent cut that way. The angles for one of these are very tricky and you can't wrap paper around a curved fork leg if it's a unicrown.
