Go Back  Bike Forums > Bike Forums > Framebuilders
27.5x20 vs 28x20 oval fork blades
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 02-14-24, 11:55 PM
3dvvitch
Junior Wingnut
3dvvitch's Avatar
Bikes: 1988 Litespeed, some Lemond, Slingshot 650c, blah blah
Quoted: 31 Post(s)
Liked 45 Times in 16 Posts
I haven't handled them personally, are 27.5x20 oval fork blades compatible with cast fork crowns designed for 28x20 legs? Wondering if the difference is more nominal than actual.
Thanks!
https://early-titanium-archive.neocities.org
early_titanium87@aol.com
3dvvitch is offline
Old 02-15-24, 09:01 AM
unterhausen
Randomhead
Liked 3,699 Times in 2,519 Posts
There is always some blacksmithing involved in getting fork blades into fork crowns. I might not even notice the difference. If there is a gap anywhere, you can bend the crown into compliance and use brass.
unterhausen is offline
Likes For unterhausen:
Old 02-15-24, 10:52 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4210 Post(s)
Liked 3,876 Times in 2,315 Posts
I find the "need" to manipulate the oval shape to fit some crowns. Slight "crushing" in a bench vise can change the amount of large VS small cross section. very few times there's been enough remaining gap (blade in crown socket) where I felt better with using bronze instead of silver fillers. I'll add that the very top few mms of the blade often has a slightly different shape than that a couple cms below the top.
Much of framebuilding entails black smithy type mods, Raking blades, aligning dropouts, Setting lug/socket angles and fits, creating tire/ring clearance indents are all examples of this stuff that are done to some degree with nearly every frame made by hand and one at a time. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 02-15-24, 01:24 PM
unterhausen
Randomhead
I'm not sure why blades are usually swaged in a little, I always cut that part off.
