Brake levers mounted on sides of trekking bars?
Anyone run their trekking bars with brake levers mounted on the sides? Are there any considerations I need to take into account as far as the brake levers I use if I go with this setup?
I'll likely go with bar end shifters, either mounted on Paul Thubmies at the forward-outside corners of the bars, or at the ends of the trekking bars if I can figure out a hack to make it work. Seems like I should be able cut the ends off the trekking bars and somehow affix the cut off ends of a road bar in their place.
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 42 Times
What would be the point of brake levers on the outside of trekking bars? Seems they would catch on anything you would pass close to. In their typical positions inside the bars you would get more leverage and stopping power. You might want to searching for phots of other trekking bar setups before cutting the bars up. IMHO
~ike
Vertical sections? how are you thinking of mounting these?
here's a Mustache bar and a mustache bar like setup with Trekking bars
https://sheldonbrown.com/deakins/handlebars.html
and here is the setup I have used for many years
https://www.cyclofiend.com/working/20...clark1008.html
the bars as you see are gently sloped, to a comfortable angle.
the reach to the 10:00 and 2:00 portions of my bars on the sides
is somewhat like reaching the hoods of my road bike..
though a bit closer.
Perhaps if you are insecure without brake lever under your hand
at all times, you can string several interruptor /cross bar top levers
on the same cable ..
I'm still not sure what you have in mind with the trekking bars. They are mounted basically on a flat, to a slightly sloping horizontal plane. Your descriptions implies that you are mounting them straight up and down?
Here is my setup-
Here is my setup-
I'm terrible at describing these things, but I found a pic that shows what I've got in mind:
https://www.commonwheel.org.uk/mtb-touring-bike
Looks straight forward enough.
just get drop bars.
(hes talking about mounting levers parallel to the direction of the top tube of the frame. Not too hard to imagine, though i dont think id like riding them like that.)
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
If you want drops, why not use these and a flat bar? https://www.amazon.com/Origin-Bicycle.../dp/B0013G6PB8
This page has a similar setup to what you want to do.
https://www.woollypigs.com/2009/11/lh...y-handle-bars/
I was going to do this to a touring bike I have that currently has drops. I bought most of the components I would need and then found that the levers didn't fit on the side sections as I wanted. There were two issues, firstly the Shimano V brake levers I had wouldn't fit around the corners of the trekking bar. Secondly the side section only had a very short straight section and hence it would be difficult to get the levers far enough forward without the clamp being on the forward curve section resulting in the levers angling out.
I think it is very dependent on the model of levers and bars you get. Also trekking bars are wide so it depends on whether you want your hands that wide. Another similar setup could be bullhorn bars.
GTryder
8
07-17-17 08:29 PM
Heatherbikes
Classic & Vintage
19
06-04-14 06:51 PM
