SRAM Red/Force front derail flex
Bikes: 2012 S Works Tarmac SL4, 2013 Allez Race
I've had my new Red groupo for about a month and I'm getting fed up w/ SRAM's FD's. A solid, trustworthy front shift hardly ever shows up.
I called SRAM and the advised/supplied a Force Stainless cage to try instead of the Red Ti cage, saying they had lots of issues w/ flex on the ti one. Gave it a shot and the shifting is still sloppy. The limits are about as perfect as they can be, but only 1 out of every 8 or 9 shifts is buttery. In either cage there is a good ammount of flex near the rear. Is there a way to compensate for this on the SRAM FD's? Is this just common with SRAM? My braze-on adapter seems solid, but could this be a culprit? Anyone other suggestions?
My LBS is recommending a switch to an ultegra/DA cage. The owner said he had the same issue, switched, and never looked back. Anyone tried this?
Bikes: LOOK 595 & Cannondale CAAD9
I just now compared the flex between Ultegra 6700 (my bike) and Rival (gf's bike) with my fingers. I just pinched it with my fingers and gave it a little wobble. Rival is way stiffer. That being the case, Ultegra 6700 front shifting is still really really nice. I actually think Shimano is better for front shifting, but SRAM is better for rear.
I don't think a lack of stiffness is your problem. I don't know what else it could be since you said it's already properly adjusted. New cables maybe?
Bikes: 2008 Specialized Roubaix Expert, SRAM Force, Boyd 38mm wheels
No problems for me with both Force and Rival. When I was installing my Force group, I did have to fuss with the height and angle of the FD before I got it dialed in. Check that the gap between the top of the teeth of the large chainring and the bottom of the FD cage is equal to about a penny's thickness.
Changed out the cables...same issue. Interesting about the ultegra/rival comparison first hand. Have you had issues w/ your rival? Is your's a braze on or clamp on?
"I did have to fuss with the height and angle of the FD before I got it dialed in. Check that the gap between the top of the teeth of the large chainring and the bottom of the FD cage is equal to about a penny's thickness."
"I'd check that you are screwing down the cable correctly"
When you refer to angle, are you talking about running it non-parallel to the chainring?
Also, screwing down the cable correctly? Do you mean inside the grooves or something else I'm not seeing?
Yes. Put on a Shimano. I got a 6600 Ultegra front derailluer on my Force/Red group and it is great. 6600 FD's are very cheap and can be had for about $30 on CL.
Knocking off the rust
Bikes: LeMond Tourmalet, Specialized Tarmac
On Shimano front DR's the cable must come over the top of the attachment - some people run it from underneath and the shifting can never be dialed in if that is the case. I am not familiar with SRAM routing, but maybe something to check out.
The "Mechanic"
Bikes: 2013 Tarmac SL4 Pro; 2011 Lynskey Cooper, 2015 BH Quartz Disc, 2014 Yeti SB75
Shift to the small chain ring and see if you have slack in the cable underneath the down tube, that may be your issue, readjust if necessary. No need to buy a new FD.
The Rival is on her bike, which has a clamp on FD. I also had Rival on my '11 Cervelo R3 before I sold it. That was braze on and also shifted flawlessly. I'm pretty excited for my Red gruppo to show up so I can see what all the Red FD fuss is all about. I doubt I'll need to swap it out for a Rival/Force FD though.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I went in the other direction when I somehow broke the 6600 FD on my CAAD9, because the Force FD was cheaper. It was the day after Thanksgiving and I needed it NOW. It was a distinct improvement. When I switched over to an Allez Comp frameset, I had to get another FD since the Allez required a braze-on, and I went for Force again.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Same issue here with my Rival FD. It is perfectly dialed in.. takes several pushes to get it to shift either up or down.
Here I was thinking of going to Force for a FD, but maybe I look at Shimano. I do like my DA cassette and chain. I just hate Shimano shifters.
Best part was when I was humping up a hill the other day and really started to come to a hault, panickly tried to get into the little ring and couldnt.. I didn't unclip fast enough and I fell over. lol
Might I add the RD is flawless shifting everytime. Silky smooth!
[QUOTE=W F Collins;12774680]"I did have to fuss with the height and angle of the FD before I got it dialed in. Check that the gap between the top of the teeth of the large chainring and the bottom of the FD cage is equal to about a penny's thickness."
Actually, I was talking about making sure it was running parallel. The bigger issue was getting the height right so the gap was what it should be.
Quoted: 10 Post(s)
You know, I think this topic has come up a few times inside other threads.
I find it interesting that all the pro teams use a Red FD with a steel cage. It is the exact same steel cage as the Force FD, they just put a Red sticker on it..haha..
But, I've personally left my titanium one on, and it works perfect pretty much. I don't notice any degredation from my Ultegra 6700 setup.
Also, I don't expect perfect shifting every single time, and I really don't see how you can.
There are so many things involved in a simple mechanical shift.
1) A mechanical unit trying to lift and push a chain from a smaller diameter chainring up to a larger on.
2) The chain itself. Wear/tear, design/machinig.
3) The chainrings themseves, how they are machined, QC.
4) The FD and its adjustment/height/limits/angle
5) Shift Levers, the type, brand etc..
6) Cables are in the mix and how they are routed/secured. Wear and tear/stretch over time.
7) Frame itself of the bike and the QC tolerances they achieved could effect shifting and other aspect.
When I see pros having their chains fall off, shifting issues...and plus my 28yrs of riding experience on road bikes, I'm going to assume some stuff just isn't going to ever be fixed right mechanically speaking with manual setups so it is 100% butter every time. I will take the 99.9 that it works perfect though.
Look at Schleck at the Tour De Suisse yesterday on the TT. He gets a few hundred meters down the road, stupid bike won't shift and stay on the rings. He ends up having to swap his bike to the Road one and finish the TT. These are basically custom one off bikes that costs $15K to make likely and setup for these guys, and the stupid thing couldn't shift at all and work. Kind of like the Formula 1 car that goes around the track a few times, after they put $2M into the car.
Maybe Di2 is really the only solution to take out several aspects of the shifting issues mentioned above. But I don't want to spend $2K for something that I have to charge every few days like my cell phone, my Edge 500 and other stuff in life. Plus, what happens with Di2 when the battery dies or something with the wiring goes wrong during a race/ride?
I will say this though, although I have all Red now, except brakes, most of the components are basically the same compared to the Force. The FD/RD/Cranks/Brakes, except chainrings themselves, are basically the same, just some weight savings, titanium bits etc.
I'm not so sure the extra $100 is warranted for Red over Force per component personally. Except with the shifters. Zero loss on both sides is very nice. The best switch I made for sure was to Red shifters.
Bikes: Cervelo R3 (Force)
Rival FD and Force FD are exactly the same except for label and the color of the arm.
If its perfectly dialed in, it'll shift fine every time. Once the shift lever clicks, you should not have to worry about it not shifting gears. Two clicks do shift down obviously (for 2009+ Rival and 2010+ Force - earlier is two clicks up 1 click down).
Bikes: Cervelo S2, Workswell 062, Banshee Spitfire
Double check your cable and make sure that its not binding. Make sure the braze on tab that the FD mounts to is straight. Take it to another shop.
I'm using Red shifters, Force FD, Stonglight CT2 rings...shifts smooth every time.
