Do you use a torque wrench when adjusting seat height?
Now that I have a carbon bike I have become paranoid (probably overly so) about torque specs. In the case of a carbon frame with alloy seatpost how necessary is a torque wrench?
Yes, yes I do. No need to damage your carbon frame.
Some sort of pithy irrelevant one-liner should go here.
Bikes: Cervelo R3 (Force)
I dont - I just use very short hex wrenches. Might bite me later but its worked well so far...
+1. Use the short end of a hex wrench between thumb and one finger and 5Nm will be quite uncomfortable. Kind of a natural torque wrench.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
Torque wrench + Tacx carbon assembly paste = peace of mind.
"Unless he was racing there was no way he could match my speed."
Sua Ku
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
Yes. It's not something I do often so it's not a problem. The Ritchey key works well if you need 5 nm or less.
I'm always spruced as to how tight the torque specs are. My "feel" for a seat collar would be around 5 nm, the specs are higher.
Schleckaholic
Bikes: '08 Trek 1.2, Schwinn Avenue Hybrid, '11 GT Sport
I use a torque wrench now, now that I have a carbon bike as well. a good 50$ investment.
Bikes: Cervelo RS
I have this one, it works pretty well. On sale now for $60!
https://www.performancebike.com/bikes...8_20000_400155
on a road near you...
Bikes: Wilier Izoard, Tricross FG
This thread now makes me want a torque wrench. Any other recommendations for good value pickups like the one on Performance? Is it better to go with the click or beam type?
What if you have an aluminum frame with a carbon seat post? (i.e. caad9) The Cannondale manual says to use a torque wrench, but it would probably be relatively safe to adjust without?
If it's a carbon wrapped post (i.e.not carbon) you should be fine. That said, I managed to break my seatpost-collar bolt on my caad8 once when I torqued down too much on it.
George
George
I'm not convinced a torque wrench is absolutely necessary if you use a bit of common sense. I just tighten it until I can't twist the saddle with one hand..I've never had a problem with the post slipping or getting crushed so I suppose I'm in the ballpark.
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
as i have learned, over-torquing a seat post clamp (aluminum or carbon) can cause tiny cracks to occur. tiny cracks become big cracks become faceplants.
if you think about it: the saddle & post is like a lever and the seat post is the fulcrum. as you pedal on the bike, forces in all different directions are going through that point - where the post and seat tube meet....compounded by all the leverage your body weight puts on it.
just get a $20 torque key that's calibrated for 5nm and never worry about it again!
In that case tighten it until it doesn't slip vertically. To get a seatpost not to slip, you really only need to barely cinch it down. If you are uncertain, use the short end of the wrench, or a very short wrench.
