Road surface effect on speed?
Rabid Member
I do the vast majority of my riding on fairly rough chipseal roads. I notice on the few true asphalt paved roads on my routes that I'm able to maintain a higher speed. However, I don't know if this is just a psychological effect or if there is a measurable difference in rolling resistance and/or power required. Anyone have any data showing differences in speed between different road surface types?
Quoted: 1186 Post(s)
Liked 289 Times
Some data here: https://www.biketechreview.com/forum/...-testing-notes
Also, search the above forum for posts by 'AFM' with crr and road surface, you should find some more info. AFM tests lots of tires and publishes the results periodically.
Quoted: 1400 Post(s)
to a point, smoother = faster, all other things remaining equal
It's all downhill from here. Except the parts that are uphill.
Quoted: 18883 Post(s)
Liked 10,646 Times
Freshly laid asphalt is like slicks, and chip seal is like knobbies.
Recusant Iconoclast
Recusant Iconoclast
Quoted: 2952 Post(s)
Liked 3,106 Times
I just thought of an idea for my son's science fair project next year.
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
I was going to help my daughter do something with aerodynamics on the bike, and use the power meter to quantify.
Got shut down because all the ideas involved a "human subject" which was against the rules of her science fair.
You could get lost and die.
You could hit a tree and die.
Liked 3,106 Times
Hmmmm. I'm going to have to check the rules.
Schleckaholic
Bikes: '08 Trek 1.2, Schwinn Avenue Hybrid, '11 GT Sport
I don't see the downside to that. If anything it gives you reason to build that necessary wind tunnel.
Liked 3,106 Times
Maybe I can argue that we're going to use a bike racer rather than a human being.
Portland Fred
gmt
Quoted: 45 Post(s)
I rode on "freshly laid asphalt" today.
It was so fresh my tires sunk into it. It was like riding with two flat tires.
Give it a few days to cool first (if you can, I didn't have a choice in the matter)
Bikes: Secteur, Camber, Trek 930
I recently rode on a paved road which had been roughed up in preparation for a new coat of asphalt. It had a wire mesh like texture which made my front tire wobble side to side. I slowed down some out of fear of crashing.
I feel the same way, to the tune of 1-2 mph. Around here 90 % of the roads I ride on are very course chip and seal. There are a couple of newly paved roads I can get on that are like Nirvana and I see an immediate increase in speed. It happens, whether or not it is psychological remains a mystery to me.
Quoted: 2326 Post(s)
Liked 4,999 Times
I wish I knew what a paved road was!
Steel is real...and comfy.
