Garmin calories counting
Quoted: 22 Post(s)
I recently purchased a second hand Garmin Edge .+ 520 bike computer. I have previously used Strava on iPhone to record my rides. When counting calories Garmin Connect app seem to count 30-40 -% more than Strava. Others out there who find calories in Garmin to be very over-exaggerated?
Quoted: 6199 Post(s)
Liked 4,816 Times
Pick one of those places or things to be your Calorie count reference and use it. Don't worry about whether it's the correct number or not and don't worry about what other say. Just as long as it's consistent it's usable. Otherwise you'll be in a state of panic wondering why one say one thing and another says something else. Don't try to use Calories to come up with the effort you did on a ride to attempt to do training by power. Get a power meter for that.
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,448 Times
Likes For skidder:
Quoted: 506 Post(s)
Liked 639 Times
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
I found that my Garmin 520 Edge tended to overestimate by a similar percentage as you noted. I do find that my Apple Watch seems to be much more accurate, but it should be as its tracking heart rate in addition to monitoring moving statistics. All that said, I agree with Iride01 that consistency matters more than accuracy unless you have a very specific reason for tracking that requires some degree of accuracy
Huh, I upload my Garmin .fit files to Strava and don't see any difference in calorie numbers. Is this because Strava's just using Garmin's data? I've heard that the most direct way to measure calorie expendature is to use a power meter. I do have one...not sure if that also affects the accuracy. But yeah, picking one to standardize on and sticking with it is probably a good bet.
Quoted: 2604 Post(s)
Liked 1,933 Times
Applying a fudge factor to any calculated calorie count is a good idea, as long as it's less than 1.0.
I'd add, DO NOT!! use the calorie counter to figure out how much you can eat if you're trying to maintain or lose weight. Without (expensive) lab tests, power meter results, and a few months of weighing everything you'll eat to calibrate the system, you'll gain weight if you take that calculated value as permission to have 2 Tbs of ice cream.
Likes For pdlamb:
Quoted: 137 Post(s)
Liked 27 Times
Bikes: 2011 Cannondale SuperSix 3, 1987 Raleigh Technium 440
Quoted: 22 Post(s)
Liked 30 Times
If you are not using an HR monitor it will do that. I have an Edge 510, and my old HR crapped out on me this year. Ride to work said 1025 calories without. I knew that was wrong, its only 11.5 miles. Got a new dual HR monitor, about 600 calories, right in line with previous rides.
Any estimated power or calorie number during a bike ride that is not measuring power directly can be off by say up to 50%, and that is if everything is set up correctly. Your tool might not know about inclination, wind, speed, weight.
Then if in the settings something is really wrong, like weight or if speed is not correctly measured it can be off by any factor.
On the other hand if you have a feel for what these numbers mean you can make a rough estimate yourself.
For example if you ever ride on a flat road with no wind for a little bit, then remember the effort it takes to go 22 mph on a road bike, if you can keep that up for the entire ride that gives you about 1000 Cal/hour. For other speeds that is about:
20 mph -> 800 Cal / hour
18 mph -> 600 Cal / hour
16 mph -> 400 Cal / hour
This should get you to say within 20% of the actual numbers.
For a regular ride with wind and inclination, the speed is less of an indication for calories burned, but you can still compare the effort it is taking you to get an estimate.
Quoted: 1743 Post(s)
Liked 1,281 Times
Outside of a research lab you are not going to find an accurate calorie counter. There are online charts and formulas that you can use as long as you realize these are gross estimates.
