Parks hacksaw - good?
Quoted: 198 Post(s)
Liked 52 Times
https://www.parktool.com/product/hacksaw-saw-1
anyone have an opinion? or do I just get the hardware store one for half the price? to me, the blue is almost as intoxicating as bianchi celeste!
Non omnino gravis
Quoted: 1188 Post(s)
Liked 1,154 Times
I'd say you're better off buying a decent one for the same money, because you know there will be a 30% Park Tool Blue tax on the Park one... then go scrounge a Park sticker from your LBS and stick it on your new saw...
That hacksaw looks very nice.
Another nice hacksaw is this Starrett K145.
My experience is that the lower cost / quality hacksaw tools do not hold the blade with the same rigidity.
So, if quality hacksaw work is required, then get a quality tool. If good enough is good enough, then shop by price.
Quoted: 198 Post(s)
Liked 52 Times
oh, brother! the starrett saw is plenty nice. I have a feeling I could "only 2 dollars more" myself into oblivion...
but ended up ordering the lennox saw. the selling point was the ability to use it as a jab-saw: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I have a klein in the shop which works well, so the new one is for the van.
thanks for the inputs.
Likes For southpier:
Work in a bike shop? then your price is typically cost + 10%..
(I bought one that stores spare blades in it's frame)
Quoted: 604 Post(s)
Liked 1,064 Times
Get the Lenox, it’s got blue highlights. It’s not like Park actually made their hacksaw. Lenox is known for quality hacksaws, I’ve had one for over 20 years great tool. Besides it’s not really a bike tool, more for general use. Tim
The tool is very nice.
My attempt at fitting a standard reciprocating saw blade, as-shown on the manufacturer's images, were not successful so I went to the manufacturer's web site. In the User Reviews section, I found another user was also unable to get that blade to fit as-shown. Right now there doesn't appear to be any way to secure the reciprocating saw blade into the opening.
Another issue identified in the User Reviews section was that there were other users who had broken the retention mechanism, from over tightening the knob. One user states that proper retention is when the knob is 12 turns tight from loose. An image is attached of the broken part, that fails when the mechanism is over tightened.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
All of the 20-25 hacksaws on ebay have user ratings of about 4.5. Pick the color you like.
The ones I like (Bahco 319 and 325) are more expensive (33 and 50 bucks) but I think they'd last longer.
Quoted: 198 Post(s)
Liked 52 Times
not much of a mechanic, but 48 years of woodworking taught me most tools are really "tool kits" and will require varying amounts of tuning before they work to satisfaction. so changing a screw or dabbing a ****** of grease isn't the death knell.
a hand plane quite often requires substantial flattening of the sole & truing the sides to 90 degrees of the sole, blade grinding & sharpening, and often removing the blistering factory applied finish to the handle which the marketing department insisted to ensure display rack appeal.
life: it's a process.
Quoted: 7 Post(s)
You were thinking of getting the park hacksaw and then you bought the lenox and tried out the reciprocating blade. What where you cutting on a bike that needs a reciprocating blade? :-)
Anyway, my option is to get a very good hardware store hacksaw. Hacksaws are a basic garage kit. It will last for years, just make sure you use good blades and the blades attach firmly to the saw. My Stanley is 20 years old and work great. I see no reason for the reciprocating saw feature. But you should buy a real reciprocating saw for the home.
Not me, the OP.
The Lenox HT50 is specified to include a jab saw feature when using a reciprocating blade.
As of this time I am unable to get that feature to work as-shown by Lenox.
You may be aware that a hacksaw is part of a basic garage kit, not used exclusively on a bike,
Thanks, but I already have an excellent Milwaukee Super Sawzall. It is an excellent high-power electric reciprocating tool.
There are many instances where I need / use one of my keyhole or jab saws. All of them have a pistol grip. I would like to have the jab saw working properly on this tool to enable the two-hand grip.
Quoted: 6193 Post(s)
Liked 4,810 Times
I'd be happy with a five dollar hacksaw frame. The three frames I have look similar to this. Two were my Dad's so they are as old or older than me. The third I bought in the mid 90's. I don't use a hacksaw daily, weekly or even monthly, their use comes in spurts. So the few times I need one it doesn't matter how well it fits my hand or how many cuts I can make before it falls apart.
The blade is what matters most anyway. Use the correct blade and tooth count for the material and it's thickness. Quality blade assortments are inexpensive.
If you are going to use it every day, then sure, go for comfy grip and extra durable frame.
Liked 341 Times
Many posts on this site ask about how to hide the purchase price of new bikes from, or get approval from "She Who Must Be Obeyed.". Tools are like this, too. When we had a leak under my kitchen sink, we needed to replace the Masonite under-sink shelf. My wife wanted this done, pronto, and I was dragging my heals.
"Gee, sweetie, to do that sink job easily, you need one of these Sawzall things, don't you?"
"Uhhh. Why yes. Yes, I believe I do".
The catch was that it was easy to drive to Lowes to get the Sawzall (and a scrap of linoleum flooring). Took several hours of work to get the waterlogged masonite out, to clean the thing up, and then to install new 3/4 plywood covered by linoleum. But the point is, I've got a really clever wife who saw a win-win. She got her home repair and I got an "unh unh - more power" tool.
In the machine shop, horizontal band saws have long since replaced reciprocating hacksaws for cut off work. So, if the OP really needs to cut massive steel (like 8" I beams and such), they should get a portable band saw:
https://images.homedepot-static.com/...20-64_1000.jpg
Liked 4,810 Times
@WizardOfBoz oooooooo Powertools........ now your talking. Just like bikes, you need lots of them.
I wonder how heavy a bike with eight inch I-beams will be for top, seat and down tubes.... er... girders?
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Once you've used a proper hacksaw frame, those stamped absurdities go in the trash - it doesn't matter what blade you use, if the frame can't hold it right, and those cannot.
It probably doesn't matter which high-tension frame, but one with end pieces joined by a section of square tubing or with a body that has webs on it makes the difference between an object of frustration and a serious tool with which one can do real work.
A good hacksaw with an actual frame will cost $12-15. A stamped piece of garbage will cost $5.
And then yes, by all means, get some decent blades for specific jobs. But in a good frame, that lets them cut easily and straight.
Quoted: 930 Post(s)
Liked 393 Times
Band saws are slow and have limited capacity - that portable one would be an exercise in frustration for anything large. I used to have a 4x6" tilting one, and while I did saw through a 3.5-inch cast iron bar with it, it took the better part of an hour and didn't cut it remotely straight. I couldn't imagine trying to hold a portable one in position long enough to do that (also induction motors are much quieter than universal motors). In comparison, the serious cutoff bandsaw you'll find at a metals vendor or large machine shop is a huge piece of equipment, not just from the capacity but to keep the blade aligned - same issue as with flexy stamped hacksaw frames really, but magnified. Unless there's a definite need for the portable, the small tilting one is a better investment, and there are plenty of articles on improving them.
Quoted: 930 Post(s)
Liked 393 Times
But the screw used there is too large to fit the hole in the blades people are trying to use.
A little searching will show that the body of the screw on a sawzall doesn't actually go through the hole - only a divot or pilot on the end does. Maybe the screw lacks that. If you can figure out the screw size perhaps you can get another one and file it to fit, though in mild steel it may not last.
Or maybe it needs a special blade.
Or maybe this was just an idea from the marketing department with little actual utility.
The knob screw is used to close the 5-blade-maximum storage cavity AND to secure the reciprocating blade to use as a jab saw.
The screw diameter is large and the reciprocating saw blade hole is small.
It looks like a part like that saddle is required. The width of the blade is narrow and the opening is wide. Even if the screw retained the blade, because of these width differences the blade would be arcing up and down during usage, pivoting on the screw. The blade should NOT swing up and down during usage.
One of the images in my reply shows the Lenox reciprocating saw blade. An observation shows the Lenox blade and the Milwaukee reciprocating blades have identical ends.
The Lenox Customer Service department will be contacted during business hours to determine why this is a problem. The information gleaned from that conversation will be posted.
Quoted: 930 Post(s)
Liked 393 Times
But personally I'm going with bad idea from the marketing department, possibly in the "worked on an earlier generation of the frame but no one used it so it got dropped in a design change" variation.
This is an excellent tool that has fast / amazing results when used w/ the appropriate discs / wheels. I have a full set of the available discs / wheels for very flexible usage.
Liked 4,810 Times
Um, no what? After over 50 years using a hacksaw that worked well for me I have to get a more expensive one?
I'm still happy with mine. One doesn't hold the blade so great, but for cutting stuff that only takes a dozen strokes it is not an issue.
The OP gave no information about intended use or desires. I was only putting out there that you don't need to spend a lot for something if you don't use it all the time. Mine will cut a top tube fine. I've cut things similar to a top tube with just the blade alone and no frame.
And when you read a post, stand back and grin some.... you did realize the power band saw was more humor than a serious suggestion, didn't you?
I've got and or used reciprocating saws and hand held power bands saws. Just like a simple hack saw, they all require some skill to make a straight cut. But it can be done with repeated experience or a good teacher and operator willing to listen.
