What's the hot setup for 2019 dynamo lighting?
#51
Bikes: Jamis Aurora, Rivendell Sam Hillborne, Surly ECR, Serotta CSI
Quoted: 9 Post(s)
A little late to the discussion, but in my opinion, state of the art is the Sinewave Beacon. USB charging and lighting in one package. The ability to use a buffer battery for constant light is clutch for technical night riding. With a small lipstick battery you could ride all night.
I use magnetic connectors as well to easily switch between bikes.
#52
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I'm still using battery taillights, but it seems to me that the truly hot setup would include dyno taillights for a completely set-and-forget system. The thought of running wiring from the front to the back always gives me pause, though.
Maybe I'll try one of those induction lights like @rhm. The price is right!
#53
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
https://cygolite.com/product/hotshot-pro-200-usb/
#54
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
www.rhmsaddles.com.
www.rhmsaddles.com.
#55
Liked 2,568 Times
Aw crap, I should have checked in with you before spending that $10!
#56
multimodal commuter
Liked 574 Times
#57
Liked 2,568 Times
I'll manage my expectations, maybe start a thread on the Electronics subforum. Sure seems like a cool idea for a light!
#58
Randomhead
Liked 3,696 Times
I have one of these on my seatstay to complement my B&M Secula dyno light. The flash is bright enough for daytime visibility, you can set the steady brightness dim enough to be group friendly.
#59
Quoted: 3459 Post(s)
Liked 1,465 Times
B&M IQ-XS
Almost all the snow and ice has melted here, I have taken the studded tires off, a few days ago I finally got around to installing the B&M IQ-XS (or XS for short) that I bought a few months ago.
https://www.bumm.de/en/products/dyna...di-silber.html
I like it. The light pattern is not quite as good as the Luxos U, the XS has some brighter areas and dimmer areas in the field of coverage, but overall I think it is a very nice light pattern for riding on pavement. I bought it shipped from Germany, I was rather happy with the price too.
I had mentioned the XS in a thread, perhaps on a different sub-forum, someone asked why I bought that instead of the X. Since I was happy with the 70 lux out of the Luxos U, I felt that the rated 70 lux of the XS was good enough and the price was much better for the XS than the X.
I usually prefer battery powered taillights, but I picked up a cheap used dyno powered taillight at a swap meet a couple months ago. I did not plan on putting a dyno powered taillight on this bike but I put my new (used) taillight on the same bike as the XS. Not sure yet if it will stay there the taillight wiring job that I did looks rather temporary.
ADDENDUM ADDED NEXT DAY:
Photo of the XS on my bike. Fork crown was already busy with the canti brake cable hanger, so I mounted the light on the canti brake post. I used the extra long light mount and bent it up a bit to get it high enough above the wheel to avoid too much wheel shadow. I was concerned that my brake bolt was not long enough to add the light to the canti post with the original bolt, so I used a short threaded rod and some nuts instead. The wiring is a bit busy because I did not want to cut any wiring shorter than I needed it to be at this time and I also have a Sinewave Revolution wired in parallel with the headlamp which complicates the wiring. The light is small enough that I have plenty of clearance for my handlebar bag above the light.
#60
Quoted: 551 Post(s)
Liked 722 Times
The problem with it is you can't tell exactly how long it will last because you change the flash pattern frequency to extend battery life, but it's hard to guess what the runtime will be.
#61
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Has anyone used Kasai dynamo hubs? My shop can get them cheaper than the Shutter Precision hubs, and I wonder if there's much of a difference--or any at all. I wonder if they're just rebadged SPs.
#62
Randomhead
Liked 3,696 Times
that's an interesting hub. It does look like an SP
#63
Liked 1,465 Times
#65
Randomhead
Liked 3,696 Times
SP is happy to built rebranded hubs for other companies
#66
multimodal commuter
Liked 574 Times
Looking at the photos I've found online, the Kasai hubs appear to have a different plug for attaching the wires. I'm not sure how relevant that is, but it suggests to me they're different hubs.
www.rhmsaddles.com.
www.rhmsaddles.com.
#68
Liked 1,465 Times
Does that mean that Shutter Precision no longer makes SP hubs?
I have two SP hubs, both PV-8, one from 2013 and one from 2017. I bought the 2013 hub on line shipped from Taiwan because I could not find a dealer in USA that sold them so I might have one of the first ones made, but by 2017 everybody seemed to sell them. There is a slight difference in the shape, the center band where the printing is on my older one that band is much more rounded in shape. Otherwise the old and newer ones look identical.
#69
I am pretty sure Shutter Precision still make SP dynamo hubs. Perhaps this shop thinks Shutter Precision used to outsource production but now they make them in house or something like that, but that was also the first time I had ever heard anything like that.
#70
Randomhead
Liked 3,696 Times
I have seen rumors about SP folding, but I'm pretty sure they aren't true.
#71
I have googled for Kasai and can't seem to find any related business of that name. Perhaps it's just a Japanese-sounding brand that Merry Sales or Soma came up with for an OEM version of SP (who are based in Taiwan). I imagine they can get more margin on an OEM version but by using a different brand name they're not directly undercutting SP retail pricing. This is pure speculation on my side, of course
#72
multimodal commuter
Liked 574 Times
The SP website doesn't give any hint that they've gone under, or at least none that I can find.
SP Store
SP Store
www.rhmsaddles.com.
www.rhmsaddles.com.
#73
Randomhead
Liked 3,696 Times
I'm sure they are still there, I hope I didn't help spread any rumors. Maybe a dealer stopped carrying them? At one point you could only go direct or through a single ebay vendor, but now they have many people selling their hubs. I probably am only buying SON hubs in the future, but when I was buying SP's, I wished that I could buy them through my LBS. But they don't have a Merry Sales account.
