29er rack
29er rack
Old 01-22-08, 07:46 AM
lapher22
lapher22's Avatar
Bikes: Surly Karate Monkey, Nashbar MTN "Frame", 96' GT Avalanche, Jamis Dakota
29er rack
Hey guys, I had posted this on Dirtrag forums and was directed here and told some of you commute with KM's and could help so here it is. I am having trouble finding a rear rack that fits my KM with discs and Big apples. Right now I have an old avineir rack that I made some leg extensions for but it is just too shifty. Thanks.
lapher22 is offline
Old 01-22-08, 08:01 AM
markhr
POWERCRANK addict
markhr's Avatar
Please correct me if I'm wrong but shouldn't any wide 700c rack fit? You may need p-clips if your frame doesn't have eye-lets and you may need to use slightly longer screws to fit around the disc brakes.
700c road/hybrid = 622 etrto = 29" mtb
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
markhr is offline
Old 01-22-08, 08:03 AM
markhr
POWERCRANK addict
markhr's Avatar
something similar to this
or this
markhr is offline
Old 01-22-08, 08:09 AM
climbhoser
climbhoser's Avatar
Bikes: SS Surly Crosscheck; '91 Cannondale 3.0
Planet Bike has a disc specific rack for 700c wheels. That'll work.
climbhoser is offline
Old 01-22-08, 08:57 AM
JeffS
not a role model
JeffS's Avatar
I think the problem is that 29" big apples are going to have a lot larger diameter than a 700c tire. He's likely running into issues with the tire hitting the upper rack.
JeffS is offline
Old 01-22-08, 09:05 AM
lapher22
lapher22's Avatar
That is correct. Tire rub is my problem. The discs can easily be overcome with a trip to the hardware store and some steel tubing.
lapher22 is offline
Old 01-22-08, 09:09 AM
lapher22
lapher22's Avatar
I see lots of racks with adjustable legs on the web but am having a hard time finding the specs for how long they will extend.
lapher22 is offline
Old 01-23-08, 12:33 AM
Bren
Bren's Avatar
I ride the same bike as you: Karate Monkey with discs and Big Apples. My rear rack is made by Axiom. Pretty sure it's this one.
It works, but it's a PITA to adjust and install. Holds a lot, but I have had the front leg extensions pop out on me when they weren't totally cranked down.
Bren is offline
Old 01-23-08, 12:59 AM
joeyfrench
I just took a look at my Topeak Explorer and it does not have the clearance for Big Apples. Sucks, cause I wanted to try some someday, and I didn't even think about the clearance issue. I looked at the PB Eco Rack Disc as well, it doesn't have the clearance, either.
Joey French
joeyfrench is offline
Old 01-23-08, 02:16 AM
bobcrotch
Bikes: 1988 Fuji Cadenza
Just like you said, it seems there are too many points of failure for larger loads. I'm sure that with some proper pre-load checking you would be fine though. This unit seems to be able to handle anything.
bobcrotch is offline
Old 01-23-08, 06:33 AM
lapher22
lapher22's Avatar
It looks like a tourture device... but if it works it works. Thanks for the help and feedback.
lapher22 is offline
