Racer Tech Thread
Old 12-30-16, 10:13 AM
  #4501
hack
hack's Avatar
Quoted: 417 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by shovelhd
Why? I'm in my third year on $550 overseas wheels with zero issues. Just pick good components and plan on truing after the first 500 miles.
As for strong, light and fast, it's possible to get fast wheels under 1300 grams. I had a set of Zipp 404 10 speed wheels, 58mm and 1270g. However they were not wide. Adding width adds weight. So if you want light, snappy, and almost as fast, go narrow.
I've been thinking about grabbing a pair of these from far west for the TT bike. I've read some of the thousands of pages of info on them and in general the experiences have been good .. just seemed too good of a deal. I figure if it's on the TT bike and something goes wrong, I won't be taking others down with me.
hack is offline
Old 12-30-16, 12:32 PM
  #4502
UmneyDurak
RacingBear
UmneyDurak's Avatar
Quoted: 280 Post(s)
Liked 68 Times in 36 Posts
Which wheels?
Reason I want 25mm wide is that my new race wheels are 25mm, and on new summer/race bike (that I still need to build ), adjusting brake width is PITA, and I am lazy. lol
UmneyDurak is offline
Old 12-30-16, 07:19 PM
  #4503
canuckbelle
canuckbelle's Avatar
Bikes: Scott Foil 10, Di2
Quoted: 148 Post(s)
So...got both the Metron 55s and the Reynolds 32s. *shrug*
canuckbelle is offline
Old 12-30-16, 07:22 PM
  #4504
revchuck
OMC
revchuck's Avatar
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times in 49 Posts
One can never have too many sets of nice wheels.
Regards,
Chuck
Demain, on roule!
revchuck is offline
Old 12-30-16, 07:24 PM
  #4505
canuckbelle
Quoted: 148 Post(s)
Went with the Metrons because they're bombproof, and I'll be confident railing rough corners on them...and the 32s because they're light and can do smoother crits and the hilly RRs on them.
Old 12-30-16, 07:29 PM
  #4506
UmneyDurak
RacingBear
UmneyDurak's Avatar
Quoted: 280 Post(s)
The weight of Metrons is suspect. The 81 tubular weight less then 55 tubular. o.O
I should weight mine seating in the box when I get home.
Old 01-12-17, 08:54 AM
  #4507
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
I'm debating whether to go eTap. I can get a really good deal on it, but I'm still running 10-speed on my bikes. I still have new 10-spd cassettes and chains. Granted, I could use them on my second bike, since I'd only be upgrading one bike.
And, since I don't have a compact SRM, I have been going with a Sram WiFli RD and 11-32 cassette for my mountain trips, so I would either have to run WiFli all the time or buy the WiFli RD too.
Any of you guys run WiFli all the time?
topflightpro is offline
Old 01-12-17, 03:10 PM
  #4508
spectastic
commu*ist spy
spectastic's Avatar
Quoted: 653 Post(s)
Liked 5 Times in 5 Posts
wifli is just sram's version of the medium cage from shimano, right? the only difference would be that (provided they use the same springs) the longer arm would require more leverage to make the same tension on the chain, and as a result of a slightly less chain tension, the shifting suffers slightly. however, this different might not be noticeable, and they might use a stronger spring for the wifli. it depends
spectastic is offline
Old 01-12-17, 03:23 PM
  #4509
spectastic
commu*ist spy
spectastic's Avatar
Quoted: 653 Post(s)
I think the biggest weakness with those wheels is the braking surface. you won't be using that a whole lot for a tt. the other big thing, especially for tt, is aerodynamics. the wheels are getting faster, and everyone has figured out that wider rims are more aero. but these big companies have spent money researching these things. the cheap wheels don't really have that. personally it's hard to say how much of a factor that is. I mean gcn found out that the new zip 808 wheels save you around 25W compared to traditional box rims. the chinese wheels save probably closer to 25W than 0W, but who knows?
Old 01-13-17, 01:01 PM
  #4510
dz_nuzz
Rides too much bike
dz_nuzz's Avatar
Quoted: 232 Post(s)
I ran WiFli all the time on my SRAM bike. Never noticed an issue. Personally I don't see a really good reason to not run it unless you are being really weight conscious about your bike. Gives you the ability to run larger rear cassettes if you need em which is a benefit in some of the races I did.
dz_nuzz is offline
Old 01-13-17, 01:42 PM
  #4511
topflightpro
My concern was not about weight. More about how well it functioned with smaller cassettes.
I've run two different WiFli derailleurs, and Apex and a Force. The Apex was terrible. The Force worked very well.
Old 01-14-17, 03:08 AM
  #4512
revchuck
OMC
revchuck's Avatar
Quoted: 461 Post(s)
Just a data point on tire/rim combinations - Specialized Roubaix Pro 23/25 tires on Hed Ardennes+ wheels measure 28mm wide. And they're pretty nice at 80f/90r too.
revchuck is offline
Old 01-14-17, 06:54 AM
  #4513
dz_nuzz
Rides too much bike
dz_nuzz's Avatar
Quoted: 232 Post(s)
In that case: Yup, used a RED and a Force WiFli, both shifted fine. Although the SRAM red ones seem to be made in such a way that if you do a lot of miles it wears down the pin that retains the cage into the body of the derailleur. So be warned (If that pin gives way the derailleur cage will eject towards the spokes, cost me a wheel and frame once). Noticed that issue on two separate Red derailleurs and then I switched to Force.
dz_nuzz is offline
Old 01-15-17, 09:42 PM
  #4514
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times in 253 Posts
What is the hardest drying tubular glue you know of? I'm going with Soyo so far. Anything else?
Doge is offline
Old 01-21-17, 10:35 PM
  #4515
tetonrider
Quoted: 693 Post(s)
Kind of old news at this point, but I forgot to post.
These wheels were publicly announced last week: Cycling Weekly Roval article.
I was a tester for the wheels and have thousands of miles on them. They're a pretty worthy aero (and light) option. If anyone has questions, I might be able to help. I can certainly give first-hand experience that not many have (yet).
tetonrider is offline
Old 01-22-17, 05:13 AM
  #4516
revchuck
OMC
revchuck's Avatar
Quoted: 461 Post(s)
We just sold a set of these at the shop where I work. They're really nice. I'm waiting for the 32s to come back in stock since I'm too slow for taller wheels to be of benefit.
Regards,
Chuck
Demain, on roule!
revchuck is offline
Old 01-22-17, 07:55 AM
  #4517
Wylde06
Wylde06's Avatar
Bikes: Cannondale Six13
Quoted: 140 Post(s)
Liked 58 Times in 21 Posts
I wish deeper wheels would come with a higher spoke count (the rovals have 21(?) spokes). Im sure I would be fine on them but the former fat kid that I once was (still at 200 pounds) has me a little worried about buying deep section wheels
Wylde06 is offline
Old 01-22-17, 08:10 AM
  #4518
shovelhd
shovelhd's Avatar
Bikes: Yes
Quoted: 9 Post(s)
You should not worry. Today's rims and spokes can easily handle 200 pounds of hard racing. Be concerned about the build itself, not the spoke count. Buy name brand or custom built. Stay away from generic offshore.
shovelhd is offline
Old 01-22-17, 08:09 PM
  #4519
ancker
W**** B*
ancker's Avatar
Bikes: Several
Quoted: 103 Post(s)
And AFAIK you can't get a 21H Powertap.....
ancker is offline
Old 01-22-17, 08:19 PM
  #4520
revchuck
OMC
revchuck's Avatar
Quoted: 461 Post(s)
With the Roval carbon wheels it's pretty much irrelevant. I bought my Allez Comp Race in large part due to the fact that the rear (carbon) wheel was 24h, and I had a 24h Powertap G3 hub. When I got the bike, I found that the rim is designed to work only with 16 spokes DS and eight spokes NDS, while the Powertap hub is supposed to be laced 12 spokes double cross to a side. I ended up trading the CL40s for a set of barely-used Boyds which I could use the Powertap hub in.
Regards,
Chuck
Demain, on roule!
revchuck is offline
Old 01-23-17, 01:27 AM
  #4521
UmneyDurak
RacingBear
UmneyDurak's Avatar
Quoted: 280 Post(s)
So what is considered light these days? Not like super light climbing only wheels, but for general racing like crits?
How would these compare?
Front: 712
Rear: 833
Just the wheels, without tires or cassette.
Old 01-23-17, 07:13 AM
  #4522
dz_nuzz
Rides too much bike
dz_nuzz's Avatar
Quoted: 232 Post(s)
I have had both a set of CLX60s (Sold to teammate) and currently a set of CLX64s (both clinchers). They are incredibly bombproof wheels. I would not worry about it. I am also a higher spoke count advocate, mostly because I feel that the weight lost is not worth the durability lost, but neither of those sets of wheels ever went out of true and I certainly put them through their paces and pinched them once or twice.
Anecdotally: Every time I took them to the local crit I managed to go OTF for the whole race on them. It was definitely the wheels (And the bike, skinsuit, helmet, and a whole lot of IAB. I was definitely the aeroweenie).
But yeah. My experience is that they are relatively light, aerodynamic, sturdy wheels.
dz_nuzz is offline
Old 01-23-17, 10:06 AM
  #4523
hack
hack's Avatar
Quoted: 417 Post(s)
Front: 712
Rear: 833
That's about where my race wheels are. I'm around 1575g total with a 20/24 build on 50mm rims.
hack is offline
Old 01-23-17, 11:24 AM
  #4524
Doge
Doge's Avatar
Front: 712
Rear: 833
The Mercury M5 Tubulars (50mmX25 wide) we got 4 years ago were 1110g/pair (bare). I did not know how light that was at the time, but did have them built with Extralite hubs. When junior ran them over a parking curb in Belgium I replaced them and the new setup came out to 1130g. He used those for everything. Crit, RR, cobbles, hill climbing and TT (Mass start legal bike TT).
The M5 clinchers same width and profile about 1,660 (mfgs weight, not mine).
Doge is offline
Old 01-23-17, 08:58 PM
  #4525
tetonrider
Quoted: 693 Post(s)
Front: 712
Rear: 833
My prototype CLX50s (50mm rims) were ~1,400g. The production version is lighter -- mine had slightly heavier hubs.
I think max aero has been hit (or close to it), so the focus now is on reducing weight and improving handling (and related to that, delivering comparable aero but better handling and lower weight by reducing depth).
There will always be a market for 64mm depth rims and such (I was going to say deeper, but the CLX64s really obviate the need for most everything beyond that).
The tri-spoke wheels are still interesting for particular use cases.
