23mm to 25mm tires. Much smoother ride?
I am trying to make my caad8 smoother. Aluminum frame, carbon fork, 23mm tires. If I swith to 25mm tires, will I have a substantial improvement? I currently inflate to 95psi. Anything above 100psi makes the ride harsh on the cement trail I frequent. Thanks.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
wider tires like 25 mm PRO4 Endurance will help some.
I used to have 23s on my bike and now ride 25s. Same make and model tires. People say you can run lower pressures on a 25 than a 23 which I do. My bike feels substantially smoother with a little less pressure and with the wider tires.
SuperGimp
A little lower pressure and yeah, it'll be a little bit smoother. Wider rims, wider tires both contribute.
Quoted: 86 Post(s)
i've found that my 25mm clinchers run softer even at the same PSI as my 23mms. nice thing is that they can probably be run at a lower PSI too. only drawback is that they weigh a little bit more. most people don't seem to care about that though.
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
The brand of tire matters too. I went from crap stock Bontrager tires in 23 to GP4000 SII tires in 25 shortly after getting my bike, lowered the PSI to around 82/90 front/rear (I'm 175) and I could definitely notice a ride improvement with much less road buzz. There are probably other tires with an even smoother ride than the GP4s.
Aluminum frames are a bit more sensitive to small changes like tire size and inflation so you should notice a difference. For me on a Caad10, switching to tubeless made a huge difference in ride quality, something to consider if your wheels happen to be tubeless compatible?
Bikes: Cannondale SuperSix EVO w Hi-Mod frame, Raleigh Tamland 1 and Giant Anthem X
Quoted: 352 Post(s)
Liked 8 Times
I recently switched my Cannondale Super6 Evo w/ Hi-Mod frame from 23's to 25's and am very pleased with the difference in the ride. Not only did the harsh ride go away, so did the twitchy handling.
I run them at 90 psi
Quoted: 7652 Post(s)
Liked 3,479 Times
I second the carbon seatpost idea, but only if you have a lot of seatpost showing--pretty sure two inches of CF is not a lot flexier than two inches of alloy.
I found an old NOS Bontrager on Ebay for $25 and I'd say (since it is all so subjective) that it really helps, and the cost was minimal--even if it had made no difference I could tell myself that I had saved 50-75 grams (worth 0.01 seconds if I ever climb Alpe d'Huez.)
Why do you think wider tires helped with twitchiness? My cadd8 is very twitchy, and I would like to solve that.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
For the record, I'm 165 lbs and I typically ride a 100psi on my road bikes.
Quoted: 352 Post(s)
Liked 8 Times
I am guessing that a little wider footprint was just enough to cause that "skinny tire" balancing act to help ease that awful twitchy handling. I know there isn't a huge difference between 23's and 25's, but for my bike, there was a tremendous difference. Now, the handling is acceptable and the bike enjoyable to ride. I almost was going to sell it because I didn't care for the bumpy, harsh and twitchy ride. As a newbie to cycling, I didn't know what to do but I started a thread here, got some real good advice and made some adjustments. It was worth the effort
Bikes: Firefly custom Road, Ira Ryan custom road bike, Ira Ryan custom fixed gear
Quoted: 9 Post(s)
If you also go with an open tubular design (basically a tubular carcass designed for clincher wheels), you will also add to the smoothness. The supple cotton casing allows the tire to move more and allows for a lower pressure to be run. They are more expensive, and they wear faster. They are also sublime in terms of smooth feel, and the grip is extraordinary.
Quoted: 9 Post(s)
Quoted: 352 Post(s)
Liked 8 Times
I agree adrien. My bike is the SuperSix Evo w the HiMod frame that I bought used for a great deal. After my first 30+ mile ride, I wasn't too sure about that "great deal" part. The biggest improvement was switching the tires, I like riding it now.
Going from 23mm to 25mm tires gives about 20% more air volume. Not much.
A bigger difference in comfort can be felt going to a supple tire from a stiff side walled tire.
Going from say Gatorskins to a Vittoria EVO CX Open Corsa would be an eye opener.
Quoted: 352 Post(s)
Liked 8 Times
I went from 23 Schwalbe Lugano's to Michelin Dynamic Sport 25's. For me, I like the ride of the Michelin's and they are very affordable too with good thread life and flat resistant.
Serious Cyclist
Bikes: Emonda SL6
Liked 261 Times
My Felt Z85 is similar to your caad8, AL frame and CF fork. Funny story, I replaced my tires in June; 700 miles and 4 months later I realize that I'd gone from the factory original 25mm tires to 23mm with my new Vittoria Rubino tires. So, for me, there was no noticeable difference in comfort or performance switching from 25mm to 23mm tires.
