Fingerless Cycling Gloves and Hacks
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,649 Times
OK, this is an inane thread but am suffering from triptophane poisoning post Thanksgiving. For decades I removed my fingerless gloves, like you would remove fingered gloves by working them off by the fingers. One day after riding, I was in a major rush to get to the WC (details omitted) and just pulled the gloves off by the palms, so they were inside out. Rather than spending 30 seconds to get the gloves off as usual, the new method was instant, and a snap to turn right-side out. All these years and I never knew. (And now I REALLY need to hear from all the people who never wear cycling gloves because their input is so critically important. <- You just know it will happen). The tips one never gets to make life easier.
Any short cuts/hacks you have learned to make something a snap, other than not bothering with cycling gloves? (Eg: Getting Velotoze on and off easily)
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Tons of stuff I know now that seems to impress people despite me doing it the hard way for years.
When putting a tight tire on, put the unmounted portion on the bottom and grip the tire on both sides, pulling it down as hard as you can starting from the top and ending at the unmounted portion. It may look like you're not making any progress, but it will often settle just enough to let you get the last bit into place with just your fingers.
Shift to the smallest cog before removing the rear wheel. This allows the RD to be out of the way the most, and is often easier to align the wheel when putting it back on.
Store wheels with tubeless tires so that the valve stems are at about the 4 or 8 o'clock position. This makes gravity help you keep the sealant from clogging the valve. Any higher and gravity holds the sealant inside the valve. Too much lower and the sealant pooling at the bottom will possibly fill the stem.
Use hair spray to lubricate grips when installing them. It dries sticky so the grips don't move around when you're riding. Compressed air removes the grips without much risk of damage.
As mentioned here in a recent thread, use silicone tape to finish bar tape. No adhesive means it doesn't leave residue, but it adheres to itself strongly to hold the tape in place.
If you have a clamp-on FD that interferes with your chosen model of bottle cage, spare valve nuts make excellent shims.
Outline cleats with a white-out pen before changing them. Very easy to align the new ones the same exact way. Note, this was more useful when shoes didn't have markings on them.
As for the glove thing, I didn't learn that until I complained to someone about the ends wearing holes on them and someone said "Just pull them off like this".
Only loosen the top strap of your cycling shoes when removing them. Chances are you can get them back on that way and won't have to worry about adjusting the other straps.
Spit on the contact patches of your heart rate strap will get it to register sooner.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 2488 Post(s)
Liked 2,958 Times
Quoted: 18424 Post(s)
Liked 15,581 Times
Unbuckle your chin strap before trying to remove a helmet. Things go much smoother.
Use the best chain lube: NFS.
Use a beltl instead of saying “On your left!”.
Ride Gatirskinz to eliminate flats.
Ti is the best frame material.
Don’t carry anything on a front rack.
Wave.
Don’t waste your money on Rapha apparel.
And for the love of Pete, tie your jacket to your frame.
Did I miss anything?
Wave.
Quoted: 7653 Post(s)
Liked 3,481 Times
I was looking on hack to improve my fingerless cycling ....
Liked 3,481 Times
Wave.
Wave.
Likes For Maelochs:
Liked 15,581 Times
Hi. I dislike finger exposed riding gloves. Many years on motorcycles and a few mishaps, I learned bare fingers get messed up when you hit the street….first thing you do is put your hands out for the fall. A word to the wise.
Quoted: 6972 Post(s)
Liked 10,971 Times
Untie them first.
Likes For Koyote:
Liked 15,581 Times
Likes For indyfabz:
I outline the old cleat with black sharpie before I remove it - no one sees marker on the soles of your shoes.
I trickle water on my HRM contacts - either from the tap or from my water bottle, depending on where I am. Spitting on the contacts is just gross.
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 171 Post(s)
Liked 395 Times
Depending upon where you live:
Check cycling shoes (and for that matter, all shoes) to make sure nothing creepy or crawly as made your shoes their new home.
Check cycling gloves, both long and short fingered, to make sure the above creepy crawly thing has now decided to live in your gloves.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
https://www.bicycling.com/repair/a34...-tire-sealant/
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Apparently saliva is more conductive than water, and the sweat that covers me at the end of the ride far overshadows the grossness of a small amount of spit. FWIW I actually lick my thumb and rub that onto the contact pads, but you might find that just as gross. Now let’s talk about snot rockets!
Liked 15,581 Times
Apparently saliva is more conductive than water, and the sweat that covers me at the end of the ride far overshadows a small amount of spit. FWIW I actually lick my thumb and rub that onto the contact pads, but you might find that just as gross. Now let’s talk about snot rockets!
Likes For indyfabz:
Liked 15,581 Times
Likes For indyfabz:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
If you train yourself to fall properly, you won't put your hands out... hopefully.
Liked 2,958 Times
Some falls and crashes happen more slowly than others, and some involve more complicated causes and effects than others. I suppose it's possible that training might help a bit with some falls, but falling on, e.g., wet leaves or glare ice happens appallingly fast; too fast for training to kick in.
Likes For Trakhak:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Liked 2,958 Times
"Hopefully" is exactly right. You can be as cautious as you like . . . I crashed a couple of years ago when I hit a patch of wet moss on a paved downhill trail when the afternoon sun was perfectly positioned to shade only the moss, making it indistinguishable from shadow. I had just that instant applied the front brake as the front tire entered the shadow/hit the moss. Result: wham. Mild concussion. Disorientation. There's reasonable caution, and then there's plain bad luck.
Likes For Trakhak:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
a guy could get pretty banged and broken up practicing crashing.....tuck and rolling hurts at 30mph on pavement or dirt.....
Quoted: 904 Post(s)
Liked 1,899 Times
anybody still do the wool sock hack for toe warmers? probably extends your riding comfort by at least 2 degrees colder .
Quoted: 5224 Post(s)
Liked 3,585 Times
fun tip, thank you
when I'm in a meat induced coma, I try to check in on forums, but fail because I pass out. gloves that I have to struggle with, do not remain my gloves for long. now where's my turkey leftovers?
Grupetto Bob
Liked 5,649 Times
When riding in cold weather, like today 34*, rather than removing my booties, I peal them back and put the shoes over a heating vent which dries the shoes completely and no wrestling the booties back on over the well worn cleats.
