Difference between these 2 Zipp bars?
https://www.bike24.com/1.php?content...pgc%5B20%5D=85
https://www.bike24.com/1.php?content=8;product=283603
ZIPP Service Course SL-70 Ergo Handlebar - high polish black
ZIPP Service Course 70 Ergo Handlebar - bead blast black
Is it only the weight and the finish? One is 6061 and the other is 7050 alloy.
Yes, SL is lighter and the finishes are different
35 gram difference between the two.....not much
Not willing to spend for the CF though ;-)
Quoted: 18378 Post(s)
Liked 4,512 Times
6061 is a good basic marine grade aluminum.
7050 is a stronger (thus allowing thinner lighter) aluminum, but at least some of the 7xxx series aluminum is susceptible to corrosion.
I got a bit lost trying to quantify corrosion resistance between aluminum varieties. Apparently it also depends on the heat treating, tempering, and artificial aging of the aluminum.
Some people tend to be prone to corrosion issues, and some aren't. If you've noted pitting and corrosion in the past, then go to 6061, or carbon fiber. If not, perhaps the 7050.
Quoted: 4717 Post(s)
Liked 1,882 Times
I think the bars you are looking at have the exact same shape as the carbon version.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times
The 70 ergo's came stock on my Ridley. They 're nice bars, but I swapped them out for CF.
My only issue was they were twitchy in the drops, but that was probably my issue.
I had Zipp SL-70 Aero drop bars on my bike that was stolen 4/15/18, and loved the way they looked. When I got the Domane, I thought a more traditional style bar would look better., so I went with the SL-70 carbon. I couldn't be happier.
Do they have flat tops?
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
Resurrecting this thread as I am in the market for bars am considering Zipp SL service course. As I am googling around, I am coming across bars with the designator B1. But I don’t find any explanation of that, nor is it ised on the Zipp website. Does anyone know what that refers to?
Liked 1,882 Times
Customer Service/B2B Support: 1-800-231-6755 Mon-Thu 10-6pm EST, Fri 10-4.30pm EST
