Anyone using a SRAM 11-36T cassette with a Di2 setup?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I am thinking of trying this, based on some reports that it could work with the B-screw cranked down.
I have a Di2 Ultegra 11-speed system with the longer cage and am currently running a 11-32T cassette.
Is anyone doing this successfully here? Any suggestions to keep it working smooth? Would it work with a Shimano 11-speed chain, or would I need to use an SRAM 11-speed chain?
Quoted: 551 Post(s)
Liked 277 Times
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I am running exactly what is described.
Bike is a Niner RLT 9 RDO. It shifts fine. I cross chain the crud out of it, shift under load, basically beat the heck out of it. No problem whatsoever.
The B screw had to be turned in (clockwise) quite a bit but the pulley clears clears large sprocket fine. I don't like the angle of the B screw against the derailleur hanger but this might be an issue specific to the shape of the hanger which comes with the Niner. If it becomes a problem then I'll get some kind of derailleur hanger extender, Wolf Tooth or similar. This is a picture of the screw before it was cranked in clockwise. The angle is much more acute now.
Four links were removed from the stock Ultegra chain and a KMC Missing Link was added. The KMC part number for 11 speed is CL-555.
This is how it looks crosschained small front (34) and small rear (11)...
This is how it looks crosschained big front (50) and big rear (36)...
If the sprocket were any larger than 36 it would definitely need derailleur hanger extender. I was prepared to need a Wolf Tooth RoadLink extender but did not need to do so. If the B screw becomes an issue in the future then I won't hesitate.
-Tim-
- SRAM PG-1170 (Force) 11-36 cassette
- Shimano Ultegra 6870 Di2 GS mid-cage derailleur
- Shimano Ultegra 50/34 compact road cranks
- Shimano Ultegra chain.
-Tim-
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
OK, looks like it works, at least on the stand. If the weather is decent tomorrow, I will test it in the field. Briefly, I have the 11-36T cassette set up with a new Shimano chain (which I waxed) and my 46/30T crankset. That gives me a 22.6 "gear inch" low (as opposed to a 29" low gear I started with when I had a 50/34 vs. 11-32), and I can safely cross-chain (not that I plan to) with two links removed from the new chain. The shifting seems rougher, but that could be the hot paraffin lube I decided to try...
Quoted: 551 Post(s)
Liked 277 Times
Occam's Rotor
Liked 2,331 Times
It works fine. I also use Shimano's 11-34T eleven-speed cassette on another wheel-set. Both work without issue. I don't know why I wrote that the shifting seems rougher. It is fine.
ilovecycling
Road Cycling
94
09-20-11 10:14 PM
ilovecycling
Road Cycling
6
03-30-11 11:56 PM
