Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Wide wheels plus crit racing= Sidewall wear
Old 07-09-18, 09:40 AM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
Hello,
I have an interesting issue I have been having. I have been running 25mm Continental GP 4000II on my Roval SLX 64 wheels. The wheels are supper wide (30mm external). I have been doing some agressive crit racing and have noticed my sidewalls looking like garbage. Recently I did a crit with a practically new tire. It was all right hand turns. When I got done the tire looked like this:
There is significant wear on the sidewall of the tire. I haven't had this issue with any other tires. My specialized s-works turbo tires were rock solid and didn't suffer this issue.
Anyone else have similar issues? I'm wondering if it's a Conti thing? Should I be running 28mm?
Bridrider is offline
Old 07-09-18, 11:45 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
I have similar on my 23mm clincher Conti GP 4ks, my tubular Zipp Tangente, and my tubular Vittora Corsa. Not worried about it myself.
rubiksoval is offline
Old 07-09-18, 11:47 AM
rubiksoval
Bikes: bikes
Originally Posted by Bridrider
Hello,
Just me, but I don't want rock solid tires for cornering. A big reason I used the turbos for about two weeks and swore them off completely. Suppleness is good.
Old 07-09-18, 11:53 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
Contis have thin sidewalls, this is known fact. Not a problem and why they have low rolling resistance and ride nicely. Before you go to 28s, what pressure were you running and what was your weight? That wear pattern to me would indicate too much deflection, not necessarily a problem if you felt they were gripping well at the cost of wear.
redlude97 is offline
Old 07-09-18, 12:05 PM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
When I say rock solid I mean I got a whole season out of them without this issue. I actually feel they are extremely similar to the Conti's in terms of grip and feel.
Old 07-09-18, 12:07 PM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
I actually had to air them down a bit from what I had them at because the crit coarse was so rough. I usually have my rear around 90. I'm betting it was about 85 ish. I weigh 170.
Old 07-09-18, 12:12 PM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
I also have a theory that they are wearing like this because the tires mount up much more square on these really wide rims. I feel the tread needs to extend further down the tire casing on these Conti's. Maybe Specialized realized this and engineered their tires to work with these wider width rims.
Old 07-09-18, 12:13 PM
TheKillerPenguin
Nonsense
TheKillerPenguin's Avatar
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times in 237 Posts
I had that issue on an old frame with not much clearance. Didn't really cause any problems, never had a blowout or anything like that.
TheKillerPenguin is offline
Old 07-09-18, 12:23 PM
redlude97
were you running the 24mm or 26mm version on those wide wheels? Obviously the square/stretched shape of the tire on the really wide rim is the point, better aerodynamic shape and stiffer effective sidewall laterally but not vertically.
Old 07-09-18, 12:29 PM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
I think I was running the 26mm. Interestingly I think they measured less wide than the Conti's.
Old 07-09-18, 12:35 PM
wktmeow
wktmeow's Avatar
Bikes: CAAD 10
Quoted: 277 Post(s)
Liked 229 Times in 111 Posts
All my 23mm GP4000s look like that after a while, no issues that I've noticed due to it yet.
wktmeow is offline
Old 07-09-18, 01:12 PM
Bridrider
Bridrider's Avatar
Quoted: 8 Post(s)
My issue is this is an almost brand new tire. I've had others where the sidewalls start splitting due to this long before the center tread is worn.
Old 07-09-18, 08:47 PM
Ttoc6
Cat 2
Ttoc6's Avatar
Bikes: Tarmac, Why Cycles R+, Evil The Calling
Quoted: 605 Post(s)
Liked 194 Times in 87 Posts
Same. I've noticed on more recent versions of the GP, but never got it when I rode in more humid (wet..) environments.
Ttoc6 is offline
jimmuller
Classic & Vintage
35
03-06-17 08:53 AM
Super D
Road Cycling
44
01-03-15 07:02 PM
spectastic
Road Cycling
11
07-09-13 06:57 AM
eyeheartny
Road Cycling
11
02-06-11 12:32 PM
Andy_K
9
06-03-10 03:53 PM
