Polar FlowSync Update
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
If you have not connected your Polar to a PC recently then be aware that the next time you do you might be prompted to update FlowSync.
The new version is 3.0.0.1337 and it installs new drivers.
I've tested plugging in my V650 and turning it on several times. It has successfully opened FlowSync and updated each time. My hope is that the update failure issue is fixed.
If you don't get prompted to update then you might want to upgrade manually by downloading the new version from https://flow.polar.com/start.
-Tim-
-Tim-
