Specialized Allez
Old 11-09-18, 03:34 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times in 92 Posts
Specialized Allez
Late 80's, I'm thinking...anybody know for sure?
Serial # L26681
  1. Friction?
  2. Frame material?
  3. Quality of the Suntour GPX group?
  4. Decent rims?
THANKS!
67tony is offline
Old 11-09-18, 08:46 PM
StarBiker
StarBiker's Avatar
Bikes: Bianchi Grizzly, Cannondale F700,
Quoted: 807 Post(s)
Liked 154 Times in 123 Posts
Might be an 87'. I passed on a similar one a while back. Didn't think it was much of a flip, it was a dark purple with scratches. Yours looks nicer. The one I passed on I could have got for $25
These can be nice bikes. They aren't worth a lot though. Not this model. But if it's your size?
And there are a few nut buckets on Ebay trying to get silly prices.
StarBiker is offline
Old 11-10-18, 08:54 AM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1236 Post(s)
Liked 964 Times in 628 Posts
GPX is a very good group, typically indexed. Decent rims, but they do show some brake wear.
wrk101 is offline
Old 11-10-18, 09:09 AM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times in 1,183 Posts
OP,
I can't offer a value on the Allez but can tell you that many here like these lugged steel frames...any information about the tubing on the frame, I would also rank GPX as a good group and if original to the bike would indicate a later model.
Shine it up, install new tires and BP along with a good service and enjoy it.
Ben
Voltaire
xiaoman1 is offline
Old 11-10-18, 10:26 AM
T-Mar
Quoted: 4722 Post(s)
Liked 3,036 Times in 1,874 Posts
Based on the serial number, in conjunction with what appears to be oversize tubes, I'd say that it was a 1993 frame, manufactured in late 1992. If so, the tubeset was an unspecified custom Tange set but given the era and oversize diameter it's likely based on Tange Concept.
GPX was introduced in 1989 and that was the only year, that I'm aware of, that it was used on the Allez. However, this obviously isn't a 1989 Allez, so I'm assuming the parts came from a donor bicycle.
I'm going to be the dissenter on SunTour GPX, While it was an improvement on the SunTour's earlier Accushift groups, I did not find the indexed shifting or braking of GPX to be quite as good as Shimano's direct competition. Furthermore, in my experience, the SunTour groups of this era had durability issues. I've seen too many with worn out and sloppy pivots. Finally, there's the dedicated derailleur cable pull to derailleur travel ratio and cog spacing, which means that when things do wear out, there's the problem of finding obsolete Accushift parts.
T-Mar is offline
Old 11-10-18, 11:46 AM
wrk101
Thrifty Bill
wrk101's Avatar
Agree with T-Mar, Suntour's peak was in the friction era. When indexing came around, Suntour was no longer competitive. I love the earlier Suntour products, many were innovative. They ended up behind when indexing came around, never caught up to Shimano, and went bankrupt in the early 1990s. Accushift was the worst, so this is better.
wrk101 is offline
Old 11-11-18, 08:03 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Still a garage full
Quoted: 847 Post(s)
Liked 66 Times in 44 Posts
I will diverge from WRK101's opinion regarding GPX. Reliable, indexed, I agree, but is notchy and loud when shifting. I much prefer Tricolor.
oddjob2 is offline
Old 11-11-18, 08:24 PM
wrk101
Thrifty Bill
wrk101's Avatar
Yes, once you go to indexed, its tricolor for me too. I guess I was answering in regards to where it appeared in the Suntour product line. It was in the upper half. At the same time, once indexing came around, Shimano became dominant. Suntour was outmatched.
I have one bike with Suntour indexing, only because it is Superbe Pro. Still, tricolor works better.
wrk101 is offline
Old 11-13-18, 10:02 AM
67tony
67tony's Avatar
Quoted: 209 Post(s)
Thanks for the great replies.
According to Bikepedia the '93 version came with RX100, which probably got pulled and replaced with the Suntour stuff.
Tubing is still a mystery, since the only '93 Specialized catalog I came across was in Dutch. Bikepedia only says "OS chrome-moly thin wall" for frame material...
67tony is offline
Old 11-13-18, 10:24 AM
himespau
himespau's Avatar
Quoted: 4233 Post(s)
Liked 2,948 Times in 1,807 Posts
That's probably all you're going to get on the tubing. Specialized in that era liked to disquise the sources of their tubing. Not sure if it was you'd think they had some special recipe or just so they could swap it around depending on supply chain availability or both, but a lot of their catalogs in that era just have a generic terminology like that. Or call it something like Direct Drive OS, which means nothing to anyone but them.
himespau is offline
Old 11-13-18, 07:27 PM
merziac
merziac's Avatar
Quoted: 4511 Post(s)
Liked 6,378 Times in 3,667 Posts
Tubing was their own spec from whoever was producing it at the time, make no mistake, with the likes of Neenan, Merz, DiNucci pulling the levers and guiding the process with a host of others this was a process that set the stage for most of the excellent Japaneese and Taiwan built frames we now have 10's of 1000's of to this day.
The tubing is excellent quality, designed and executed by some of the best in the business, especially at the pricepoint of the day.
merziac is online now
Old 11-14-18, 01:20 AM
jetboy
jetboy's Avatar
Bikes: centurion cinelli equipe, look hinault 753, Zunow z-1, 83 stumpy sport
Quoted: 814 Post(s)
Liked 331 Times in 186 Posts
I have to agree that every bike I have had with "direct drive" tubing was light, responsive, and all around great. whatever it was. This was true of both the mtb and road versions.
jetboy is offline
Old 11-16-18, 10:35 AM
WaveyGravey
Quoted: 131 Post(s)
Liked 126 Times in 87 Posts
I have a 1997 Allez Sport.
WaveyGravey is offline
Likes For WaveyGravey:
junkcheck
Classic & Vintage
28
12-09-18 04:27 PM
marius.suiram
17
09-10-16 04:17 PM
calstar
Classic & Vintage
2
02-23-13 02:17 PM
owen006
Classic & Vintage
5
09-09-12 03:13 PM
parkrun72
1
03-28-11 08:50 AM
