Giordano Viaggio Build
#76
Legs; OK! Lungs; not!
Bikes: ''09 Motobecane Immortal Pro (Yellow), '02 Diamondback Hybrid, '09 Lamborghini Viaggio, ''11 Cervelo P2
Liked 9 Times
I just did an upgrade on my brakes. I added standard road brakes,
[h=1]Tektro R559 Road Brake Extra Long Reach Caliper 55-73mm[/h]
The Install went well, but did require some engineering. The stock short 5mm shoulder bold was not long enough to mount the rear brake. A medium 5mm shoulder bolt was required. In addition, the cross bar between the seat stays is meant for mounting a fender, so I had to drill out the hole on the seat tube side (1/4") to fit the shoulder bolt. To reinforce the shoulder, I added a 1/4" (8mm) stainless flat washer.
Adding these standard caliper brakes, along with the
[h=1]Kool Stop MTB Mountain Bicycle Brake Shoes[/h]
the braking is far better than the stock brakes, or even the Avid 7s that I installed 5 yrs ago.
Next step will be to retro fit some 6703 Ultegra shifters and switch over to 10 spd cassette and derailers. Not in a big hurry. I have the shifters and cassette, need to pick up an 3 spd FD and 10 spd RD. Meanwhile I've got to see if I can disassemble the current Microshift Left shifter. It no longer shifts out of the granny gear, but since I'm in flat fla. and just riding with the grandkids, I really don't have much need for much gearing.
#77
Liked 9 Times
Got the shifters installed and everything tuned up over the weekend. Here's a pic of the handlebar setup:
Took our first ride into school yesterday and the second this morning:
You can see in the pic above the pedal blocks I made for the back from 2x4s. I considered buying crank extenders, but they're $100 and my daughter will only need them for less than a year. After our first ride I turned up the rear handlebar so that she isn't so stretched out.
I've updated the build costs in post #4 . The total came in under $900. I still have a few small parts to buy and to sell, which should about cancel out, so I haven't included them.
According to my scale, the total weight was just a hair over 40lb with the wooden pedal blocks installed. Without them it would probably be around 38lb. So it's about the same weight as the stock bike. I suppose the added weight of the brake adapter and brakes offset the weight savings from the fork and cranks.
Some thoughts on the ride: First, my fit was way off. I expected to do some adjusting but not this much. I'm just under 6' tall (5'12" according to my wife) with a 32" inseam. I have the seatpost above the minimum insertion point to get comfortable leg extension. I also have the seat set as far back as possible on the post to get my knees over the pedals. One of my first purchases will be a 400mm post with more offset. The stem I had on hand is 110mm. It's way too long. I've ordered both a 80 and 90mm to see what's most comfortable. That should get me more comfortably placed and reduce some of the twitchiness I feel right now in the front end.
The tensioner I made is barely audible while riding. I don't notice it. As of now I plan to stick with 39t rings and maybe eventually go to 38t. We're in the lowest gear on our morning climb to school.
I'll try to remember to post some additional thoughts after we've ridden for a couple of weeks and I have the new stem installed.
#78
Liked 9 Times
#79
Still loving the Giordano. I changed out the stem for higher rise, 16 degrees I think, and got a longer seatpost. The front rim brake squeals despite my toeing it out. I'm going to try a cheap brake booster next. During the summer we're mostly riding it on weekends for bagels/doughnuts. Here we are fully loaded on a morning bagel run.
#80
Bikes: 2015 Apollo Syncro tandem, 2006 Scott CR1 SL (still a beastie race bike), 1993 Trek T200, 2006 Fuji Absolute Le, 2000 Thorn Club Tour
Quoted: 16 Post(s)
Us? We have a 1983 Viscount Grand Tourer poptop in original condition!
Glad you like the bike!
W
#81
Bikes: Ribble Stealth (R872), Giant Defy 3.5
I just ordered an A2Z DM-UNI adapter from Wiggle. It was a little more than I had budgeted, but these things are getting harder to find, so I went ahead and picked one up while I could. If you look closely at my X01, you'll see I'm using a heavily modified A2Z to run discs on this old frame. I have had no trouble with it in 3 years of use and do check it regularly. I trust it for the tandem. I'll post some pics of the install when it arrives.
I hope to keep the total cost around $1000. If I can sell off some parts I think that's doable. I'm posting a JPG of the spreadsheet I'm keeping. I'll update the spreadsheet and the pic as I go.
quick question regarding the a2z dm-uni adaptor? Sorry if question is a bit of topic. I am considering using an a2z dm-uni adaptor on my road bike. You are the first person I've been able to find, through google search, that has used the adaptor on anything other that a mountain bike. How much modification did it require? My frame dropouts look to be of similar size to your Trek's. I would appreciate any advice or additional pictures if available. Feel free to send me private message regarding this question.
Thanks,
Stephen
#82
Hey Stephen. The type of bike isn't as important as the dropout style. I posted some other pics on forums.mtrb.com. I would search through the posts there to see what folks have done on a variety of bikes. You want to be comfortable with a grinder or dremel tool. Then go slow. Take a little material off, test fit, take more material off, repeat until it fits. I probably took too much off on the Trek commuter bike. Nonetheless, I've been using it daily for nearly 5 years of 10 mile commute.
Brian
Brian
#83
Brian
Brian
Thanks for that. I've had a look at mtbr.com. Better pictures on it for sure. I knew I would have to modify a bit. My dropouts are small but flat and more importantly the inner face of the drop is flush with the chaistay and seatstay so will probably only need to modify/bodge the faceplate. I plan to use an existing hole in the dropout (rack/mudguard eyelet) to further stabilise the adaptor with an M4 allen screw. The faceplate of the adaptor appears less substantial in terms of thickness of material which should make it manageable. I have to get my hands on a dremel.
Stephen
#84
Hi Brian,
The a2z adaptor worked perfectly, needed a bit more work on the grinder than expected but still managed to get it clamped tightly around the dropout.
Thanks again for the advice.
Stephen
Stephen
#85
Made a couple of changes to the Giordano this week. For the last months I've been battling a skipping chain. It seemed to come from the rear, but I couldn't see what was happening from where I sit and my daughter wasn't much help diagnosing. Turned out the crankset chain rings were severely worn, especially the smallest. So...
I installed a compact crank (50/34) from Nashbar. It was cheaper than buying 3 new rings. Haven't had any trouble on our local hills going up to 34 from a 32:
I also replaced the 2 39-tooth chainrings with 40-tooth narrow/wide from Race Face. Probably not necessary but should keep the chain more secure. I might eventually install a narrow/wide jockey wheel and run the chain a bit looser, so it's not so noisy.
#86
just learning about this Giordano as we are researching our first foray into tandems. has anyone measured the ETT for the captain on those frames? Giordano says "The front frame measures 20”" but this is not especially useful for sizing. elsewhere i see "21-inch top tube length." is that accurate? i have not seen an actual geo chart. i like the price but i don't want to deal with the hassle of returning it if it's too big.
#87
I'll try to measure the top tube tonight. I'm 5'-11" and you can see how much captain's seat post is sticking out. I think it would fit down to at least 5'-9". You're probably going to have to play with the stem length and angle to get it comfortable.
Turns out the skipping chain was caused by the ancient, used derailleur I stuck on. It wasn't tensioning the chain enough. This summer I upgraded to 10 speed with a 11-40 cassette and new 9-speed Shimano MTB derailleur. 11-40 in the rear and 34/50 in the front is a great combination for us.
We've upgraded from a kid's trailer to trail-a-bike:
#89
Trickstuff Exzentriker
I've seen the Trickstuff Exzentriker eccentric bottom bracket mentioned several times in the Giordano Viaggio threads, but can't find anywhere where someone actually tried one. I purchased a set of Truvativ Elita cranks for our Viaggio several years ago and never got around to putting them on. We've decided to swap the cranks this Winter, so I bought a Trickstuff Exzentriker to replace the front bottom bracket at the same time. Since the Truvativ cranks are 24/22mm, and the Trickstuff Exzentriker is made for 24mm Shimano cranks, I also bought a reducing shim for the non-drive side. Total cost, including the tool required to install it and shipping from Germany, was about $170. I'll post back once we've completed the upgrade.
#91
#92
Our bike mechanic son looked at the Exzentriker and couldn't see any reason that it wouldn't work. We shall see...
As for upgrading to disc brakes, I have no desire to head down that rabbit hole with our Viaggio. I've upgraded the brakes on ours to Tektro R539 dual pivot calipers with Kool Stop dual compound pads. They are much better than the stock brakes. Since my wife has little interest in climbing or descending big hills, the Tektros are more than adequate for us.
Once I get enough posts to be able to post pictures, I'll post a picture of the drop-bar 29er my son and I built. I think you'll get a kick out of it. I'll probably post it in the gravel bike forum as not to derail this thread.
Likes For johnmc_76:
#93
We finally got the Trickstuff Exzentriker eccentric bottom bracket and Truvativ Elita cranks installed on our Viaggio this weekend, what a difference it makes. It's so much quieter without that little idler wheel chattering. It took a bit of fiddling to get it installed, but I think it was worth the effort. My wife/stoker wasn't feeling so well by the time we got it done, so I was only able to ride it up and down the street, solo. I'm really looking forward to going for a real ride with her in the near future. Here's a picture of the Exzentriker:
Any questions, fire away.
#94
Bikes: Vary
#95
Bikes: Vary
I bought the Lamborghini tandem (Now it's Giordano Viaggio) back in 2010. I didn't want to spend $4-6k for a good component tandem as my girlfriend (now my wife) didn't want to do exercise. I've tried to change to pink because that's her favorite color and replace the component which i felt more comfortable.
Back in 2012-2013, we rode averagely 100 miles weekly. I found the chain stay crack and have the local hitch installer to weld the crack (around $80).
Here is the link to the album:
https://photos.app.goo.gl/7FiVEzQmSDqciJax7
#96
We bought ours back in 2012 and it only has a couple thousand miles on it. Many of those were with our grandson, who rode with me for a year or so before losing interest. He and I rode a century ride on it. My wife had both of her knees replaced last year, so we're hoping to start putting some more miles on it once spring arrives. Funny, we trimmed ours out in purple, my wife's favorite color. Once we get a sunny day, I'll get some more pictures of the whole bike and share them.
#98
Hi! I am upgrading my viaggio too and I just wanted to know what compact crankset did you use and did you have to change your bottom bracket? Thanks!
#100
Quoted: 16 Post(s)
Very nice how you matched cable outers, bottles and bar tape.
Also I did not know about the Exzentriker, a neat solution.
Enjoy!
Enjoy!
