Tires that will allow a road bike to ride ok on Rails To Trails gravel?
Quoted: 82 Post(s)
Liked 23 Times
Can I ride a road bike on the small gravel you see on the old train track bike trails with the right tires? I wouldn't think the smooth 27x1 1/4 road tires would do great... but then again, it's usually a pretty straight line ride. I have close to zero road bike experience. I have one road bike with tires that look like skinny mountain bike tires. I haven't ridden it enough to know much about how those would do. Any thoughts on this setup?
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I have rode lots of gravel miles on 700x28mm. Most is ok, but if you get new gravel that isn't compacted or mud it can be difficult.
Likes For c_m_shooter:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
27 1/4" tire equal a 33/34mm tire. While not the best choice, depending on the type of gravel and tires, they could be not so good , to very good. It is such an open question, "Can I ride", absolutely. How will the tires do, one way to find out. If the tires are old and/or have a lot of miles, I would not use them on gravel.
Quoted: 20810 Post(s)
Liked 9,456 Times
The rails-to-trails gravel that I've ridden has been fine, hard-packed, and generally smooth. I wouldn't have any qualms riding several miles of that kind of stuff with my 28mm tires. Just be aware that you'll be grip limited and act appropriately.
Likes For WhyFi:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Its not just the tires I would worry about. You need quite a long reach and top tube length to feel comfortable on singletrack.
Sunshine
Quoted: 10986 Post(s)
Liked 7,509 Times
Here in Illinois at least, the rail trails are hardpacked FA-6 gradation limestone screenings. Closeup, it resembles very small gravel. But it packs hard and makes for a very hard and smooth surface for road bikes. I've ridden countless miles on them, ever since about age 12 or so, first with 27x1-1/4 tires and now 700x25C tires on regular drop-bar road bikes. Nothing special about reach or top tube length. Same bikes I ride on the road.
Likes For Reflector Guy:
Quoted: 1825 Post(s)
Liked 1,700 Times
A 27x 1 1/4" tire is about the same width as a 700 x 32 road tire which is more than wide enough to ride on those sorts of trails. I have even ridden a rail trail on 700 x 23 tires without issues.
Likes For alcjphil:
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
You mentioned 27x1 1/4 road tires. If that's what you have, Panaracer Paselas are available in that side and they're pretty nice all-purpose tires. They'll work well on compacted gravel, although maybe not as well on loose stuff.
Quoted: 6214 Post(s)
Liked 4,824 Times
All the rails to trails paths I've seen were made with bicycles in mind. Do you see people riding bikes on that particular trail? Look and see what they have on their bikes. Note what bikes they are using. Talk to them about their experience on the trail with that bike and if they'd want something different for their bike.
You don't need much tread pattern for packed gravel. 27 x 1¼ tires are about 32mm wide x 630 bsd, IIRC. So they should be okay for packed gravel, but wider might be better. I don't have much experience on gravel, but I've ridden it on 25 mm tires. When it becomes loose gravel, you won't want to ride very far. I'm not sure even 40 mm will work well on loose gravel.
Thankfully, our two rails to trails paths here are paved.
Tanglefoot Trail
https://www.longleaftrace.org/
Both about 44 miles.
Tanglefoot Trail
Likes For Iride01:
Randomhead
Liked 3,704 Times
I rode one of the local rail trails with 25mm tires and I really wished I had 32mm tires. Probably larger tires would work marginally better, but 32mm seems fine.
Likes For unterhausen:
Quoted: 82 Post(s)
Liked 23 Times
Depends on what you mean by "small gravel" I suppose.
I assume we've been on the same trail. I rode the old train trail in that area (Milwaukee to Chicago and maybe further north or south) many times. Nice packed gravel. I've never ridden that trail on a road bike (BMX as a kid and later mountain bikes), but it was always super smooth. Good to hear it's doable.
The only time I wish I had more rubber is when I drive down to the south suburbs and ride on the Old Plank Road trail which is asphalt, but it is very bumpy.
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times
Advice to see what others are riding is excellent. Were I you, I would opt for your road bike with the skinny mountain bike tires absent other input.
Truly depends on the surface as everyone said. I've ridden 25 and now 28mms on untold miles of packed dust/gravel trails, and they do fine. Unless it's made of old ballast stone, the road bikes work fine for me. Go ride the trail you're interested in. And if it's too rugged, turn around.
Likes For exercion:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
100% agree. Most crushed limestone or gravel paths are well compacted enough that they'll hold water in low spots just like asphalt, with the occasional loose spot. I ride on 35mm 700C tires on it just fine. I was able to traverse loose larger gravel (acorn sized to walnut sized road underlayment) on Mackinac Island, but handling was very compromised. That stuff doesn't pack under bike wheels. I'd look to much wider tires to handle long stretches of that.
Likes For Unca_Sam:
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I ride a crushed limestone towpath fairly often (1-2x/week) and my 700x23's do just fine on them. "Bile trails" that consist of rail ballast suck for bicycles IMHO. I don't even like to ride a mountain bike on them.
Likes For Rdmonster69:
Quoted: 229 Post(s)
Liked 327 Times
Rode 40 miles on a Rail Trail in Michigan on finely packed gravel. I probably could have used the stock 28mm tires. But not knowing what the gravel was like beforehand I put 35mm Schwalbe G-one tires on my bike and 38mm Specialized gravel tires on my wife's bike and we were both very happy.
Despite the surface being uneven (though finely packed) no vibrations reached my butt or hands. I was really surprised how pleasant the ride was. I'm sold and I'm glad I got a second wheelset and tires.
Right now though it is so dry that the path is dusty. I rode last night after work and in the low setting sun I could see the dust kicked up by almost every bike or jogger.
Likes For Friisk:
Quoted: 383 Post(s)
Liked 690 Times
Agree. Years ago when they first opened one of the old rail grades to bikes, it was some form of crushed rock or ballast. We specifically took our mtn bikes. It was like riding through honey or molasses. After two miles we turned around and found an old forest dirt road - what a relief!
Likes For kahn:
Bikes: Optima Baron LR, '14 Nishiki Maricopa,'87 Trek 330 Elance, '89 Miyata 1400, '85 Peugeot PGN10, '04 Fuji Ace, '06 Giant Rincon, '95 Giant Allegre, '83 Trek 620, '86 Schwinn High Sierra
Quoted: 225 Post(s)
Liked 164 Times
All depends on the surface. You said you have 27"x1.25 tires? You should be fine for surfaces like what I see on the GAP. I would lower pressures to 60psi to help absorb the small bumps.
Likes For friday1970:
Quoted: 643 Post(s)
Liked 1,528 Times
You have a bike. Go ride some of the trail and see if you're comfortable. What's the worst that can happen? You won't be comfortable and turn back. Big whoop.
Quoted: 2606 Post(s)
Liked 1,937 Times
Agreed. There's so many rail trails with so many different surfaces that, as the saying goes, all generalities are incorrect.
Likes For pdlamb:
SE Wis
Quoted: 2747 Post(s)
Liked 3,403 Times
