Today I (v2):
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Today I got my frame from the powder coater.
Yeah, aluminum welds are ugly.
Now I can stop playing with with wheel bearings and build this thing so it can get back on the road.
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
The problem isn't just grip strength of the cage although that is a consideration. It also has to do with the shape of the bottle relative to the cage. This isn't my information. This comes from lots of experience in the triathlon community. I got grief over wanting bottles with proper grooves. Here is why.
100% right.
The bottle in this picture below has a rounded shape to the groove. It does not engage the bottle cage lip properly. By the way, it is an old bottle used for parts cleaning just as an example.
Contrast the generic no name bottle above with a higher quality bottle below. The bottle and cage have a complimentary shape, the cage is able to properly grip the bottle. This setup does not eject.
Both pictures are high quality Zipp Speed Cages. much less effort is required to pull the top bottle out of the cage than is the bottom bottle. The bottom bottle clicks in.
If you want grip strength though then the best is going to be XLAB Gorilla Cage or the Gorilla XT. Not cheap but the XT has the highest grip of any cage out there. But yeah, check the fit of your bottles to the lip in the cage. You may have to adjust bottle and cage brand/type to get a better interface between the cage lip and the bottle groove.
-Tim-
100% right.
-Tim-
Twofish seems to work excellent on round tubes and even side-mounted on oval fork blades, as long as they're dry, if it's raining things get interesting. I'm going to put a piece of clear grip tape on my downtube to try and combat this.
- Soli Deo Gloria -
Liked 736 Times
Quoted: 399 Post(s)
Liked 274 Times
My bike is pretty small diameter round tubing & I have some occasional slight slippage/twisting problems (and even once tore the velcro strap trying to get it really tight) but nothing like yours.
Much appreciated. I'll see how my Purist bottles interface with these cages when I get home. I used my large Camelbak Podiums this morning.
Calamari Marionette Ph.D
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
I tried two different saddle mounted butt rocket cage holders. No matter what I tried, mount, cage or bottle, I launched every single time. Even tried the Specialized Zee side entry cages thinking that would prevent a launch. Nope. Lost a few bottles and damaged two others. Decided to remove the mounts and throw them in the trash where they belong.
- Soli Deo Gloria -
Liked 736 Times
XLAB Gorilla cages and Aquashot bottles. Done.
If you only need one bottle then get the Delta 200 system - mount, cage and bottle.
Delta 200
Gravel is out of bounds though. Might want to check gravelcyclist.com and see what those guys use.
Delta 200
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
I use the Tacx behind the saddle bottle holder as well, because my 80's Raleigh commuter I've posted here doesn't have any cage mounts on the down tube or seat tube.
Quick link to pic: https://www.flickr.com/photos/rattle...posted-public/
I've never had a problem with a bottle ejecting, and part of the paths I take are pretty rough, but it's not gravel.
These are the cages I use: https://www.amazon.com/Delta-Inox-Bi.../dp/B000ACAML0
Two mounted.
I do have a problem with the mount being a little bulky on the underside of the saddle, making it quite difficult to smosh a saddlebag up there. So I'minterested in that Minura double holder y'all are talking about. Can anyone share a pic of their bike with it on? google image search wasn't the most helpful. I'm not sure I like the angle of them.
Two mounted.
- Soli Deo Gloria -
Liked 736 Times
Quoted: 481 Post(s)
Liked 131 Times
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
I was referring to the Tacx one I currently have making it difficult as there is a big plastic arm that is right in the middle under the saddle.
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
So from these - it looks like you can adjust the angle of the bars? Is it just held by tension on the clamp, or are there nuts/bolts?
I also have a problem with the Tacx mount tipping down because of the weight of full bottles hitting bumps.
- Soli Deo Gloria -
Liked 736 Times
They are the same. The angle is not adjustable and depends entirely on the angle of your saddle rails. I could not bend the mount by hand but not for lack of trying. Contemplated a vise or heating but tried the Tacx first.
The Tacx did not tip like Sci Guy's. The mount however, is cheap sheet metal and flexed as I tightened the bolts. Was not satisfied.
I tried an expensive antique T.A handlebar mounted cage but didn't like the look and it scratched my new Nitto bar so I got mad and threw it away. Dug it out of the garbage the next day and sold it on ebay.
I tried a Minoura BH-60 (22mm bar only) and an SBH-80, both of which I still have and will send free to anyone who wants either. PM me your address.
I tried the Twofish and thought about trying a really expensive Rube Goldberg XLAB X-Wing setup but they didn't come in chrome.
Check this site out --> Adding Water Bottle Cages to Bicycles without Braze
At the end of the day I just put a 25oz bottle in my jersey pocket. Works every time.
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Been riding mostly dirt, the optimo has me riding on the road a lot more. Now there's a road bike in the works. So cycical.
Next I'll get hit by a car and migrate back to the woods.
Quoted: 481 Post(s)
Liked 131 Times
Gold chains on everything
Bikes: Heavy Pedal Zephyr, '16 Mash Work, '14 Cinelli Parallax, C-Dale Synapse Disc
Quoted: 17 Post(s)
Just don't drink any water and stick to the alleged bike mantra of HTFU.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
fun fact: athletes back in the day used to specifically not drink water during races, it was basically cheating
Quoted: 1332 Post(s)
Liked 398 Times
- Soli Deo Gloria -
Liked 736 Times
