which tube to install water bottle cage on?
Old 07-25-20, 03:06 PM
Symox
Quoted: 14 Post(s)
Liked 7 Times in 6 Posts
Hello,
My bike has two water bottle cage threaded inserts. For my rides I only ever need one large Camelbak bottle. I have settled on putting the cage on the seat tube instead of the down tube because I can grab it, sip and put it back without looking. But I was wondering if there is a consensus on which tube is "better" in terms of handling.
Thanks
Symox is offline
Old 07-25-20, 03:47 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1445 Post(s)
Liked 355 Times in 218 Posts
That bike only has one purpose - to make you happy. No other opinions count. At worst, if you decide you don't like it on the seat tube, you can move it to the other location.
Retro Grouch is offline
Likes For Retro Grouch:
Old 07-25-20, 04:10 PM
woodcraft
woodcraft's Avatar
Quoted: 1466 Post(s)
Liked 512 Times in 301 Posts
Wind tunnel testing shows a slight aero advantage on the down tube,
where I also find it easier to grab the bottle.
I've never seen any case made for weight distribution other than that lower is better.
woodcraft is offline
Likes For woodcraft:
Old 07-25-20, 04:14 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2391 Post(s)
Liked 832 Times in 561 Posts
I find reaching the down tube location easier. Tradition says that the first cage goes on the down tube. In the '70s when I race, race bikes has a set there only.
All that said, I second Retro above. It's your bike. I'm good with whatever works for you, (I put a third bottle under the downtube for really hot and/or long rides. Time trialists use cages behind the seat, In the old days the pros had cages bolted to their handlebars. That trend is coming back. Camelbaks have become fairly popular on road cyclists.
Hydration is important, On hot or very hard rides, often of supreme importance. How you arrange your bottles and cages is far less so, as long as it works for you. I"m a pure traditionalist. I raced the two cages, down tube and seat tube (the seat tube cage secured with the metal straps), drank from the down tube bottom cage first, then swapped the bottles. But that's just me. I learned too long ago to change. You have a clean slate.
A consideration - will a Camelbak bottle stay in the cage if you hit rough road? Losing your only bottle on a very hot ride on a fast downhill on a group ride could be very costly; as in one of those nightmare you will always remember and hope to never repeat. I ride with standard bottles and their either "necks" of "waists" depending on bottle size in SS King cages because that combo never flies off.
Stay hydrated! Welcome to cycling! And Bike Forums!
Ben
79pmooney is online now
Likes For 79pmooney:
Old 07-25-20, 04:24 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3112 Post(s)
Liked 470 Times in 349 Posts
Makes you wonder if they made aero shaped water bottles that only hold eg. 12 ozs and are completely hidden by the frame tubes.. in which case 2 of these could be better than 1 large bottle setup?
Sy Reene is offline
Old 07-25-20, 04:59 PM
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 869 Post(s)
Liked 401 Times in 283 Posts
It's wherever is easiest for you. I always find it easier to grab from the dt so all my bikes have at least a dt cage.
2cam16 is offline
Old 07-25-20, 05:38 PM
Troul
:D
Troul's Avatar
Liked 194 Times in 142 Posts
DT may allow for a taller bottle whereas the ST might restrict the height of the bottle that you choose to use.
ST has a less likely chance at spitting out the bottle when jarred by the riding conditions. A larger diameter ST bottle might interfere with leg movement.
I use both.
Troul is offline
Old 07-25-20, 07:31 PM
Miele Man
Quoted: 1127 Post(s)
Liked 677 Times in 479 Posts
Do you mean like this? 500ml (16 ounces each)
Cheers
Miele Man is offline
Old 07-25-20, 07:40 PM
WGB
WGB
WGB's Avatar
Bikes: League Fuji
Quoted: 558 Post(s)
Liked 117 Times in 87 Posts
This summer? In the heatwave we've had?
I run, Camelback with 2 liters on back
Down tube and seat tube each with a bottle and as of yesterday, two bar bottles. Just two bike bottles in this heat, let alone one, would scare me. Losing sunglasses is bad. Losing water is not healthy.
WGB is online now
Old 07-25-20, 08:15 PM
bargo68
bargo68's Avatar
Bikes: 2008 Surly Cross Check, 1979 Miyata Gran Touring, 1983 Miyata Ridge Runner, 1997 Serotta Atlanta
Quoted: 70 Post(s)
Liked 164 Times in 89 Posts
Down tube is an easier grab for me. Also, a frame pump runs up the seat tube on a couple of my bikes.
bargo68 is offline
Old 07-25-20, 08:27 PM
70sSanO
70sSanO's Avatar
Quoted: 482 Post(s)
Liked 217 Times in 161 Posts
I’ve always put a cage on both the down tube and seat tube; pump is under top tube. If I’m only using one battle it is in the downtube cage.
I use Cateye BC-100 on all my bikes. While they are extremely ugly, I never lose a bottle. And, I’ve found different colors of NOS on eBay.
John
70sSanO is offline
Old 07-25-20, 08:41 PM
Bill in VA
Bill in VA's Avatar
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji with custom black Imron paint by Stinsman Racing of PA.
Quoted: 147 Post(s)
Liked 94 Times in 74 Posts
These were popular back when aero first became a 'thing'. The downside was small capacity, and proprietary cage bottle combos and even proprietary mounting at times. Plus they were expensive. So if may be why they were not broadly popular.
I find a King IRIS stainless steel cages will keep a bottle, even a 24 oz. bottle, in place over all the bumps I have encountered and in the 2 low speed crashes I have had. They will also hold stainless Klean Kanteen bottles. I have found the more vertical the bottle the greater the chance of ejection, and handlebar mounts eject more than seat tube mounts. Just my experience and YMMV.
Bill in VA is offline
Old 07-25-20, 09:35 PM
veganbikes
Clark W. Griswold
Quoted: 1526 Post(s)
Liked 346 Times in 252 Posts
I usually have two but in the rare case I have one it is on the down tube (unless it can't be placed there for some odd reason). However put it wherever works for you.
veganbikes is offline
Old 07-25-20, 10:15 PM
woodcraft
woodcraft's Avatar
Running 6 to 0 for bottle on the DT- looking like a consensus.
Old 07-26-20, 06:47 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Yeah, something like that.
Definitely would be a kinda specialized purpose/niche need. Seems with the more prevalent even larger and more aero CF tubing on entire lineups of bikes now, and the wider downtubes as a result, it might be a bit easier now to something tuck worthwhile behind the downtubes especially.
Sy Reene is offline
Old 07-26-20, 06:57 AM
GlennR
Passing on your left
GlennR's Avatar
Quoted: 1945 Post(s)
Liked 908 Times in 479 Posts
Wow.. 15 posts, must be too hot so everyone is inside on the interwebz.
I'm going for another ride.... with 2 water bottles.
GlennR is offline
Likes For GlennR:
Old 07-26-20, 07:07 AM
joesch
joesch's Avatar
Bikes: 83 Colnago Super, 87 50th Daccordi, 87 Guerciotti, 90s Colnago Master and Titanio, 96 Serotta Colorado TG, 95/05 Colnago C40/C50, 08 Lemond Filmore, 12 Cervelo R3
Quoted: 203 Post(s)
Liked 87 Times in 61 Posts
Ben
Agree DT+1 may also help your improve your riding position as does riding more in the drops
joesch is offline
Old 07-26-20, 07:13 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1069 Post(s)
Liked 641 Times in 329 Posts
Seat Tube Preference...
I put bottle holders on both the downtube and seat tube of my three bikes for longer rides.
But I mostly commute, and over the years I have found that I will usually take a drink when I'm stopped at a light. When I'm stopped and sitting upright on the seat it is easier to reach under the seat to grab the water bottle than to bend forward to reach for the DT bottle. In fact, I only take one bottle when commuting and I put it on the seatpost holder.
I hadn't thought about this before reading this thread. I suppose I grab the downtube bottle when in motion on long rides, but I don't know.
...great, now I'll be pre-occupied with how I drink when riding and probably fall.
I'll let you know.
BobbyG is offline
Likes For BobbyG:
Old 07-26-20, 07:16 AM
bruce19
bruce19's Avatar
Quoted: 1225 Post(s)
Liked 566 Times in 340 Posts
Back in the late '80's I had bottles and cages similar to what you mentioned. They were Campy kit. I made the mistake of selling the bike (MAZA Prestige) and let the cages/bottles go with them.
bruce19 is offline
Old 07-26-20, 12:27 PM
Troul
:D
Troul's Avatar
sooo late in the day for the additional ride? Already did a medium, long, short, & round-bout' rides before cyber church bells rang.
Troul is offline
Old 07-27-20, 05:34 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 640, '74 Fuji Special Road Racer, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 971 Post(s)
Liked 618 Times in 349 Posts
The seat tube location is most efficient for me to reach and replace without looking. So, if I'm riding with only one bottle, it goes there.
If I'm riding with two bottles, then the seat tube one is for drinking and the downtube one is the back-up. Once drained, the primary bottle goes to the downtube and the other replaces it at the seat tube.
Phil_gretz is offline
Likes For Phil_gretz:
Old 07-27-20, 05:48 AM
Quoted: 11660 Post(s)
Liked 3,484 Times in 1,859 Posts
Precisely the same with me.
Old 07-27-20, 07:36 AM
wolfchild
wolfchild's Avatar
Quoted: 1855 Post(s)
Liked 539 Times in 297 Posts
+ 1....I also have two water bottle cages on all of my bikes.
wolfchild is offline
Old 07-27-20, 07:39 AM
wolfchild
wolfchild's Avatar
Thanks
It doesn't matter.
Old 07-27-20, 11:04 AM
Ogsarg
Quoted: 420 Post(s)
Liked 499 Times in 216 Posts
Hello,
Thanks
So if you find there is a consensus on putting it on the down tube, are you going to move it?
If it works for you, why would you care what others do?
Ogsarg is offline
