Buying new saddle
Old 08-02-20, 10:11 AM
daveton
Bikes: Trek checkpoint ALR 5
Quoted: 7 Post(s)
Liked 9 Times in 2 Posts
Buying new saddle
Mostly a curiosity question. When buying a new saddle how would you know if itís the right fit?Weather itís comfortable? Right saddle for the riding you do? The saddle that came with my bike is working out fine. I just thought Iíd throw out the question. Also how will I know when I need to replace the pads on my disc breaks?
daveton is offline
Old 08-02-20, 10:18 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,278 Times in 798 Posts
Oooh Another 'which saddle' thread ...
as to the disc pads .. take them out & look ?
fietsbob is offline
Old 08-02-20, 10:26 AM
Reflector Guy
Reflector Guy's Avatar
Bikes: '17 Trek
Quoted: 68 Post(s)
Liked 78 Times in 46 Posts
Not only that, I'm not even sure why he mentioned the weather.
Reflector Guy is online now
Likes For Reflector Guy:
Old 08-02-20, 11:08 AM
phughes
phughes's Avatar
Quoted: 438 Post(s)
Liked 222 Times in 144 Posts
You can determine if a saddle will be comfortable by ensuring the seat height, fore and aft adjustment, and tilt are correct, as well as your reach.
phughes is offline
Old 08-02-20, 11:15 AM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 176 Post(s)
Liked 47 Times in 37 Posts
I have Specialized Body Geometry (which is surprisingly comfortable), Brooks B-17 which is a very nice saddle (and quite comfortable), and Selle AnAtomica which is an extremely nice saddle (and extremely comfortable - and also my favorite).
Those are my choices!
Wanderer is offline
Old 08-02-20, 11:22 AM
GlennR
Passing on your left
GlennR's Avatar
Quoted: 1949 Post(s)
Liked 914 Times in 484 Posts
Test ride and bring your buttocks
GlennR is offline
Likes For GlennR:
Old 08-02-20, 01:44 PM
MattTheHat
MattTheHat's Avatar
Bikes: 2020 S-Works Creo SL, 2020 Specialized Roubaix Expert
Quoted: 519 Post(s)
Liked 1,448 Times in 565 Posts
You really canít know if a saddle is going to be comfortable until you try it.
As for the disk pads, just visually inspect them. If the bike is new notice the thickness of the pads now and make a mental note. If the bike isnít new, go look at a pair of replacement pads at your local bike store and make a mental note of the thickness. Then inspect your pads every 6 months or so. When they get very thin, replace them. I can get about 12-15,000 miles out of my pads, but some people get significantly more and some significantly less.
MattTheHat is offline
Old 08-02-20, 01:45 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2242 Post(s)
Liked 637 Times in 428 Posts
Some bike shops have "test saddles" you can use to help decide which saddle works best. You put a nominal deposit down, install the test saddle on your bike, ride for some arbitrary period (days, weeks, whatever the shop can agree to), and get your deposit back (or apply it to a new saddle) when you return the test saddle.
JohnDThompson is offline
Old 08-02-20, 02:45 PM
Mulberry20
Quoted: 291 Post(s)
Liked 109 Times in 81 Posts
Saddle threads can be entertaining but nothing like ďbest lubeĒ, ďcampy vs shimanoĒ or ďconti vs vittoria. Those are usually popcorn worthy.
Mulberry20 is offline
Old 08-02-20, 04:23 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Bikes: Canyon Endurace, 105; Battaglin MAX, Chorus; Bianchi 928 Veloce; Ritchey Road Logic, Dura Ace
Quoted: 559 Post(s)
Liked 664 Times in 364 Posts
Gee, I don't know if I'd want to ride a saddle after somebody put a deposit on it. Ewwwww.....
genejockey is online now
Likes For genejockey:
Old 08-02-20, 04:43 PM
one4smoke
Bikes: 2020 Specialized Roubaix Comp SC - 2016 Specialized Roubaix SL4 - 2015 Giant Roam 2 Disc
Quoted: 546 Post(s)
Liked 138 Times in 100 Posts
The attempt at humor when it works ...makes one look good. But, when it doesn't work...
one4smoke is offline
Old 08-02-20, 06:52 PM
Sojodave
Sojodave's Avatar
Bikes: Fezzari Fore CR3 Di2
Quoted: 167 Post(s)
Liked 72 Times in 34 Posts
I'll take a stab at the great saddle dilemma. Narrow down what saddle would work for you. Find out if you like a short-nose or long-nose saddle. Curvey or flat, cut out, no cut out. Go to your local Specialized dealer and get your sit bones measured. Find a saddle that is at least 20mm wider than your sit bones.
Sojodave is offline
Old 08-03-20, 04:04 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 240 Post(s)
Liked 116 Times in 92 Posts
Saddles - good advice given so far: find a local bike shop that will let you test ride saddles and try them out. A bike shop may also have some saddle manufacturer test system that will give you an idea of size and shape.
Disc pads: short answer is when the pads reach 1mm in thickness, time to replace. That is a bit thinner than a US dime, or (legend has it) 3 business cards.
On anything bike maintenance-wise, you can do an internet search on the term and add Park Tool -they have very good videos explaining stuff. I find that is easier than finding old threads on the online forums.
jpescatore is offline
Old 08-03-20, 05:52 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 640, '74 Fuji Special Road Racer, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 971 Post(s)
Liked 618 Times in 349 Posts
Saddles have characteristics, as j@Sojodave pointed out above. Learn the attributes of saddles that work for you, and buy only "in family" of those sorts of saddles. For me (for a racing position or for MTB):
1) Narrow
2) Flat fore and aft, not scooped
3) Flat port to starboard, not rounded
4) Firm beneath, and minimally padded
5) Under 200 grams
For a utility/touring position, then add:
1) A bit wider, think Brooks Team Pro
2) Leather, with laced side skirts
3) Weight is not a consideration
Phil_gretz is offline
Old 08-03-20, 07:13 AM
wolfchild
wolfchild's Avatar
Quoted: 1855 Post(s)
Liked 539 Times in 297 Posts
The type of saddle you choose depends on what type of bike you're riding and your riding position. Is your riding position aggressive and aero, is it neutral or is it more upright ??...once you have the right saddle for your bike and riding style, then you need to adjust it correctly.
wolfchild is offline
Old 08-04-20, 11:36 AM
Bob the Mech
Bob the Mech's Avatar
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 36 Post(s)
Liked 43 Times in 29 Posts
Saddle fiiting:
1) On line research and reviews.
2) Buy one on line, ride with it and hope it won't cut you in half.
3) Buy one from a good LBS which will provide a saddle fit service, ride with it and still hope it won't cut you in half.
4) Already have a well fitted saddle and make sure your next saddle is 'like for like' or that the lenght, width, shape (waved, flat, cutout etc) are as near as damn it.
5) Make sure your cycle shorts padding is up to scratch...the best fitting saddle in the world can't compensate for poor designed chamois padding (like riding 6 hours in bibs designed for 2-3hrs of butt pressure...).
6) Years of riding...sometimes you just know what will work for you just by looking at it...like some kind of Jedi Saddle Master...
7) Impulse buying a saddle because it's the lightest, most technically advanced perch...ever...and it will make your bike look 'way cool'...NO, just no...
Disk pad replacement:
Parktool recommend changing disk pads at 1mm and less of pad material...the thickness of three business cards apparently
Bob the Mech is offline
Old 08-04-20, 04:04 PM
avmech
avmech's Avatar
Bikes: 2003 Trek 5200, 2015 Trek X-Caliber 8, 2018 Trek Domane SL 6
Quoted: 7 Post(s)
and he already knows his discs are broken.......LOL
Seriously, as previously stated, take the BRAKE pads out and have a look at them.
Carpe Diem
avmech is offline
Old 08-05-20, 09:33 AM
phughes
phughes's Avatar
Quoted: 438 Post(s)
Originally Posted by Bob the Mech View Post
Saddle fiiting:
I ride without special bike shorts quite often, 50 miles or so days on tour without issue. How do you explain that? Oh... yeah, proper seat height, reach, etc.
phughes is offline
Old 08-05-20, 09:35 AM
phughes
phughes's Avatar
Quoted: 438 Post(s)
Originally Posted by Hison View Post
My old saddle's already scratched, is there any way to save it?
No. Throw it out. It will never be the same. You will feel the scratch. The only potential you have to not feel the scratch is if "your cycle shorts padding is up to scratch..." as per Bob.
phughes is offline
Old 08-05-20, 11:03 AM
fietsbob
Bikes: 8
gaffers tape... Better than duct tape.
Vinyl upholstery patching goo @ auto parts stores..
fietsbob is offline
Old 08-05-20, 11:40 AM
Bob the Mech
Quoted: 36 Post(s)
Ok...calm down fella Each to their own sunshine. Advice, take it or leave it...no skin off my padded butt.
Likes For Bob the Mech:
Old 08-05-20, 11:44 AM
phughes
phughes's Avatar
Quoted: 438 Post(s)
phughes is offline
Old 08-06-20, 08:50 PM
cubewheels
Bikes: A really old BMX bike and a 2020 Phantom 20" hybrid
Quoted: 181 Post(s)
Liked 89 Times in 72 Posts
Mostly a curiosity question. When buying a new saddle how would you know if it’s the right fit?Weather it’s comfortable? Right saddle for the riding you do? The saddle that came with my bike is working out fine. I just thought I’d throw out the question. Also how will I know when I need to replace the pads on my disc breaks?
How long do you ride? If you ride 3 hrs for example, and the saddle remains comfortable for 3 hrs, then it's comfortable for you.
Sometimes, a saddle might be uncomfortable for two days and then becomes comfortable in the 3rd day (your muscles have adapted to the new saddle).
The fact is, you'll never know if a saddle is good for you until you have used it for one week.
cubewheels is offline
Old 08-07-20, 11:33 AM
Mojo31
Bikes: Specialized Sirrus 4.0
Quoted: 52 Post(s)
Liked 44 Times in 37 Posts
Are you saying this is one time you can trust an as*hole?
Mojo31 is offline
Old 08-07-20, 01:49 PM
GlennR
GlennR's Avatar
Not the hole so make sure the saddle is on and you don't sit on the seat post.
GlennR is offline
