Yard/estate sale part 2 - custom bike
#52
Quoted: 7348 Post(s)
Liked 2,470 Times
Frankly, I don’t know the difference between TIG welds and filet braze because everything I have except the Klein in a couple of the photos is lugged. Just ignorance on my part.
I’m hoping I can find a serial number when I clean it up and then contact R&E in Seattle to see if they have any records
TIG stands for tungsten inert gas. Tungsten is the filler, and the welder is electrical and creates a high temperature. Because of the high temperature, one must spend a short amount of time at each point to avoid overheating. As such, it requires more skill.
After filet brazing, you can file away the brass filler which is why the joints are so smooth.
Here is a more extensive explanation with pictures.
Likes For noglider:
#53
GranSport70
Congratulations on finding your new friend.
I am new to the forum and I don’t know if it is proper to ask if the Brooks Saddle that came with the Bike is available.
My 1968 Brooks is in need of replacement.
#54
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
Tange #5 straight gauge has 26.6 internal dim.It was used on Univega Gran tours.
#55
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 458 Times
Been a couple of weeks. The bike has cleaned up well. I slapped on some cheap Performance Forte Strada 700X25 tires but will eventually go to tubulars with Continental Sprinter Gatorskins. Swapped in a Suntour Superbe seatpost thanks to a trade and just need to put on a new chain and possibly freewheel to solve the skipping issue. Can't wait to take it out for the first time.
I was able to locate some Bike Ribbon Professional bar tape which is my favorite and the white hoods cleaned up pretty easily with soap and water. Looking at this I guess I need to fix that crooked hood too.
1984 Gitane Tour de France; 1968 Peugeot PL8; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1983 Vitus 979; Colnago Super, mid-80's Bianchi Veloce, 1984 or 85 Vitus 979
#56
What's the OD on the headtube? Looks like it might be 33mm, possibly with internal reinforcements. That's another lugless trick--use an OS headtube with pieces of a regular headtube inside to support the head races.
#57
Liked 1,062 Times
Likes For unworthy1:
