tubeless tires road bike
Old 08-09-20, 11:40 AM
shona
Quoted: 31 Post(s)
At the suggestion of somebody I put tubeless tires on my road bike. I realize I know nothing about them. How much pressure do I want in the tires? I like 100 in my regular tube tires. I bought Stans No Tubes Dart in case I get a flat on the road but I'm not really sure how it works. Do any of you have tubeless tires on your road bike? If so, please share your knowledge. Thank you
shona is offline
Old 08-09-20, 01:10 PM
WhyFi
WhyFi's Avatar
Quoted: 13593 Post(s)
Liked 2,871 Times in 1,537 Posts
There are a lot of threads. Maybe start on this one - https://www.bikeforums.net/road-cycl...eless-not.html
WhyFi is online now
Old 08-09-20, 01:11 PM
shona
Quoted: 31 Post(s)
tubeless tires
Thank you. I didn't notice it.
shona is offline
Old 08-10-20, 06:43 AM
oldwinger14
oldwinger14's Avatar
Bikes: 2020 Cannondale Synapse 105, Mavic Ksyrium Elites
Quoted: 25 Post(s)
Liked 17 Times in 11 Posts
There are also lots of online videos on the use and maint of tubeless tires.
oldwinger14 is offline
Old 08-10-20, 07:21 AM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 385 Post(s)
Liked 74 Times in 53 Posts
This discussion usually turns in to a holy war. Search some old threads, there's lots of info out there. My suggestion: have your first set put on my an LBS. Tubeless tires can be hard to mount and seal at first. They also require different materials and skills if and when you puncture on the road.
dmanthree is offline
Old 08-10-20, 07:35 AM
WhyFi
WhyFi's Avatar
My suggestion: if you go this route, only do so if they'll let you watch and (ideally) talk you through some of the nuances. The biggest obstacle with tubeless is the learning curve; having someone do it for you doesn't help you with that unless you can watch and bounce questions off of them.
WhyFi is online now
Old 08-10-20, 10:41 AM
dmanthree
dmanthree's Avatar
Bikes: 2017 Roubaix
Quoted: 385 Post(s)
Agree. Mounting tubeless is not like tubed, and you may need a special pump to give it that first "blast" you need to seat the bead on the rim. There are special floor pumps with a charge tank attached, and they help a lot. Since there is no tube, getting things seated properly, and installing the valve properly is crucial. None of this is hard, just different.
There's lots of videos on YouTube that can be helpful, as well.
Old 08-10-20, 10:46 AM
shona
Quoted: 31 Post(s)
tubeless tires
Thank you. The bike shop I go to put them and and got me set up. I just have questions like how much pressure do they need? I keep 100 in my tubed road bike tires. I also have questions about what to do it I get a flat but, as you pointed out, I can probably find something on YouTube that addresses that. Thanks
shona is offline
Old 08-10-20, 11:07 AM
WhyFi
WhyFi's Avatar
There are a number of online pressure calculators - use them as a starting point, but adjust as needed/wanted.
Set yourself up for maintenance schedule first - do that and flats will be few and far between, as long as you're using an appropriate sealant. Again, lots of info in the other thread.
WhyFi is online now
Old 08-10-20, 11:31 AM
sfrider
Asleep at the bars
sfrider's Avatar
Quoted: 163 Post(s)
Liked 134 Times in 82 Posts
Check the max pressure of your tire and wheel. If 100 psi doesn't exceed it you're fine running that.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
sfrider is offline
