Smelly gloves
Smelly gloves
Old 08-10-20, 06:57 AM
delilo
Bikes: Jamis
Quoted: 9 Post(s)
Smelly gloves
Tired of my performance bike gloves I have, they are rancid, and my hands smell awful after using
Others I should try? thanks
delilo is offline
Old 08-10-20, 07:01 AM
GlennR
Passing on your left
GlennR's Avatar
Quoted: 1955 Post(s)
Liked 916 Times in 485 Posts
Do you wash them?
GlennR is offline
Old 08-10-20, 07:05 AM
Rides4Beer
Bikes: Defy | Revolt
Quoted: 591 Post(s)
Liked 519 Times in 289 Posts
Have you tried washing them? I've found that while people will wash their kits regularly, a lot of people seem to neglect their gloves and helmets, which both can end up stinking since you're sweating in them just the same.
I use Specialized bodygeo dual gel gloves, no issues, I throw them in the wash every 2-3 rides.
Rides4Beer is offline
Likes For Rides4Beer:
Old 08-10-20, 07:13 AM
delilo
Bikes: Jamis
Quoted: 9 Post(s)
I wash them
Even after just 20 miles, its awful
delilo is offline
Old 08-10-20, 07:16 AM
delilo
Bikes: Jamis
Quoted: 9 Post(s)
Im thinking the material is low grade or something, the smelly ones are a year or so old, my old pair that are more than 10 years old, no issues
delilo is offline
Old 08-10-20, 07:17 AM
drewguy
Bikes: Trek Domane 4.3
Quoted: 174 Post(s)
Liked 25 Times in 17 Posts
I've been happy with pearl izumi gel gloves. I wash them ever few rides, and while they eventually won't come really clean I can't smell them while riding (just if I stick them in my nose).
I put them on, put a little laundry detergent in the palm, and then basically wash my hands thoroughly that way for a minute or so, rinse and then let air dry. Do that after every 5 rides or so.
drewguy is offline
Likes For drewguy:
Old 08-10-20, 07:22 AM
MattTheHat
MattTheHat's Avatar
Bikes: 2020 S-Works Creo SL, 2020 Specialized Roubaix Expert
Quoted: 519 Post(s)
Liked 1,448 Times in 565 Posts
Mine get washed and dried in the washer/dryer with other laundry every ride with no ill effects. Well, no I’ll effects so far. Probably 300 wash cycles on them and they’re still fine.
MattTheHat is offline
Likes For MattTheHat:
Old 08-10-20, 07:28 AM
noodle soup
noodle soup's Avatar
Quoted: 4370 Post(s)
Liked 1,424 Times in 795 Posts
Same here. I only buy gloves without velcro, because it can damage bibs/jerseys while going through the wash.
noodle soup is offline
Likes For noodle soup:
Old 08-10-20, 07:37 AM
delilo
Bikes: Jamis
Quoted: 9 Post(s)
Non velcro?? intrigued....[scanning the interwebs]
delilo is offline
Likes For delilo:
Old 08-10-20, 07:46 AM
noimagination
Quoted: 164 Post(s)
Liked 141 Times in 75 Posts
I haven't really noticed a difference in brands. Maybe brands with more wicking/quick drying material will build up smell less quickly? Speculating here. Gel padding would be better than foam, I would guess, since gel is hydrophobic and wouldn't soak up sweat. But, again, I've used both and I haven't really noticed a difference (doesn't mean there isn't one, just that I haven't noticed).
During the summer, after a ride I will rinse my gloves under the faucet and squeeze (not wring) the water out, several times (5x or so) to wash out most of the sweat. Then air dry in the furnace room (they're dry by the next morning). This helps to keep the smell down between laundry washes, but probably shortens their life a bit. It's worth it in my opinion. .
When the weather is cool, after a ride I just hang them to dry after a ride (like all my cycling gear) and wash them when they start to smell. Moisture tends to foster smells, IME, so hanging sweat dampened gear after a ride to let it air dry, if it isn't laundered right away, helps to keep down smell.
noimagination is offline
Likes For noimagination:
Old 08-10-20, 07:51 AM
vespasianus
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar
Quoted: 97 Post(s)
Liked 65 Times in 40 Posts
I rode with a guy who never used to wash his gloves or helmet -just throw them in the back of the truck and pull them out next time. You could smell him in the wind when he was behind you!
You might want to hand wash/soak your gloves before even putting them into the washing machine.
vespasianus is offline
Likes For vespasianus:
Old 08-10-20, 08:01 AM
MoAlpha
MoAlpha's Avatar
Bikes: Shmikes
Quoted: 4233 Post(s)
Liked 1,545 Times in 853 Posts
If the combination of skin flora and glove material is right, no amount of soap and water is going to make an appreciable difference. In that case, the options are a soak with a real bactericide or bleach. Some gloves come with the silver-based antibacterial treatment used for non-stink footwear. If it works for my sailing shoes it'll work for anyone's gloves.
MoAlpha is offline
Likes For MoAlpha:
2cam16
2cam16's Avatar
Bikes: TOO MANY
Quoted: 869 Post(s)
Liked 403 Times in 283 Posts
I always put mine in one of those delicates net bags. Never had a snagging problem with the velcro.
2cam16 is offline
Likes For 2cam16:
Old 08-10-20, 08:16 AM
Nachoman
well hello there
Nachoman's Avatar
Quoted: 414 Post(s)
Liked 139 Times in 89 Posts
Try submersing in some water with a touch of bleach prior to throwing into washing machine.
I find that my eco friendly washing machine just doesn't do the job properly on some of my more dirty garments.
Nachoman is offline
Likes For Nachoman:
Old 08-10-20, 08:26 AM
noimagination
Quoted: 164 Post(s)
Good point. Some of us just have stronger body odors than others. Also, some of us are more sensitive to odors than others. Who knows - what's bothering the OP might be tolerable to others of us.
On a side note - IME cycling gear doesn't like bleach. If you use bleach then expect much shorter use life from your gear. I've used peroxide and vinegar as alternatives, and I've also used laundry detergent supposedly designed for synthetic fabrics (Sportwash and the like). I like Sportwash and clones more because they have less in the way of fragrances added than anything else, if my skin is rubbing against fabric with fragrance (or, god forbid, fabric softener) for hours then I tend to get rashes. When the odor starts to get noticeable even after a wash with detergent, then I'll add a half cup of vinegar or peroxide (whichever I have handy) and that helps. I use it in the pre-wash/pre-soak cycle.
Old 08-10-20, 08:48 AM
RGMN
Quoted: 165 Post(s)
Liked 91 Times in 67 Posts
I also put my helmet pads in one so I don't need to search the washer to find all the pads.
RGMN is offline
Likes For RGMN:
Old 08-10-20, 10:07 AM
Iride01
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 1621 Post(s)
Liked 512 Times in 392 Posts
I throw a scoop of oxyclean in with my cycling clothes... which includes gloves. Essentially when mixed into water it's ingredient sodium percarbonate breaks down and becomes hydrogen peroxide which is a very good sanitizer.
So if you have any smells being caused by biological things, then this will take care of many of the causes of those smells. And if you don't like perfumey smells either, make sure you get the original oxyclean. The stuff they advertise now as odor control is heavy with the perfumes and less of the sodium percarbonate .
Iride01 is offline
Likes For Iride01:
Old 08-10-20, 10:22 AM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 2392 Post(s)
Liked 833 Times in 562 Posts
Segoi makes gloves without velcro. I take my velcro'd gloves and just stick the straps shut and toss them in the wash.
I haven't tried this but I bet Fabreeze would kill the smell. It handles much bigger jobs nicely.
Ben
79pmooney is offline
Likes For 79pmooney:
Old 08-10-20, 10:52 AM
noodle soup
Velcro sucks on gloves. There’s no need for it.
Old 08-10-20, 03:48 PM
Germanrazor
Bikes: Trek Madone
Quoted: 98 Post(s)
Liked 74 Times in 54 Posts
This is why I buy cheap gloves and have several sets then after a few cleanings and no longer works.....throw them out and keep on trucking.
Germanrazor is offline
Likes For Germanrazor:
Old 08-10-20, 09:05 PM
njkayaker
Quoted: 2261 Post(s)
Liked 252 Times in 177 Posts
Stick the gloves with Velcro in an old sock to wash them.
njkayaker is offline
Likes For njkayaker:
Old 08-11-20, 07:50 AM
noodle soup
Or just buy gloves without velcro. There''s no need for it on gloves.
Old 08-11-20, 08:16 AM
njkayaker
The issue with washing them is easily fixed. So, it's not really a problem.
That you can't deal with a simple solution isn't any reason for other people to do anything.
Old 08-11-20, 08:24 AM
noodle soup
Your simple solution, is as unnecessary as velcro on gloves.
Old 08-11-20, 08:32 AM
njkayaker
It might be unnecessary but who cares?
The issue with washing them (which you agree has a simple solution) isn't a reason not to buy gloves with velcro.
"Unnecessary" is a rather weak motivation.
I've managed to get free new gloves a few times. They happened to have velcro.
No one really cares whether or not you like gloves with velcro.
Lots of people buy them. Some of them might find the simple solution worthwhile to know.
