TRP Spyre mechanical brake = bee's knees?
#51
Bikes: 2015 Calfee Tetra tandem,2016 Calfee Tetra Adventure Tandem, Ventana ECDM 26 mtn tandem, Ventana ECDM 29r full suspension Mtn tandem ,Ventana Fat tire tandem, Calfee Dragon Fly, Santa Cruz Carbon 5010, 907 Whiteout fat tire
Quoted: 57 Post(s)
Liked 6 Times
Received my TRP Hy/Rd brake caliper yesterday. I was surprised that it weights less then the Bengal caliper it replaces. 175 vs 187 grams. Quality looks very good. It was a very easy install although I did have to replace my inner brake cable as the routing is different and my original cable was too short. The housing was fine. Direct bolt on replacement other wise. My very initial impression is that it requires much less pressure on the brake lever (Shimano Ultegra Di2) then the mechanical brake does. I can squeeze the lever to the bar but on a short test ride down the block it had nice modulation and the braking very quickly got better as the pads seated and broke in. It easily skidded the rear tire although my stoker was not aboard. I will have a better evaluation after todays regular ride. This install was utilizing my already used Hope V2 non vented rotor. It has a nice feature for a travel bike in that it has a locking mechanism that can be engaged to prevent it from being actuated while traveling in the case.
#52
Quoted: 427 Post(s)
Liked 339 Times
With the extra moving parts of two cylinders I was wondering if the Spyre was any more prone to squeal or chatter? Have any of you early adopters been able to gauge how quiet they are compared to a BB7? The weight savings is very impressive for the Spyre.
#53
Bikes: Paketa V2r di2, C-Dale MT 3000, Teesdale, 1963 Huffy Daisey
Quoted: 15 Post(s)
orderded TRP Spyre SLC by phone with Dave. He said I was the thirsd to say it was for a tandem. After which he read me the disclaimer that the brake is only warrentied for single person bikes. So tandem voids warrenty. Same as any disc brake I suppose. The web site only offers 160 or 180 packaged with a rotor at $110 for the SLC. Since I have a 203mm ICE rotor, I didn't need the rotor. He offered to knock off $10 or include some extra pads in exchange for the rotor. I'll receive them Friday, $5 shipping, and can confirm the posted 146g.
#54
Quoted: 57 Post(s)
Liked 6 Times
We don't have much time on the new brake but did one ride with some 8-9 % descents and the braking was very good. My wife commented that the braking was throwing her off the seat if she did not anticipate it. As I was testing I was braking much more then usual. Non of these were long enough to really heat up the brakes with only about 1000ft of decent to work with. I do think they are going to do well. They require much less hand pressure and seem to modulate well. I was surprised that they were actually lighter then the Bengals. When I talked to both Brice and Dave at TRP they stated that they had tested them on tandems but still were interested in feedback. I called them and ordered direct from Dave and got them in two days I really like a two piece rotor and used a Hope V2 rotor but am going to try a Shimano Ice and see how it feels. I hope that combo deals with all the heat issues. I do like the fact that the pad is about 1 1/2 times larger then the Bengal so it should off gas much later.
#55
Quoted: 15 Post(s)
Is it known that the "CHILL" pads from Scrubs, are compaitble with the TRP since they list shimano fitment?
Can't say if they are a "grippy" as TRP says their custom pads are. $15 more than other TRP pads.
https://www.scrubcomponents.com/Brake...ILL/chill.html
I don't actually see the Spyre pads listed on TRP's site should one want to replace them with OEM pads.
https://www.trpbrakes.com/products.php?catid=187
I only see paradox pads.
#56
Quoted: 15 Post(s)
Response from Scrub about their CHILL pads and more...
Scrub:
"- I looked up the M515 caliper, and it looks like it uses a different pad than the Shimano pads we stock. You can look at the store on our site to see images of all the pads to be sure.
"- I am not sure about the TRP calipers, I haven't seen them yet but I would say it is unlikely that the CHILL pads will clear the mechanical arms.
"Keep an eye on Scrub since it sounds like you are in to mechanical calipers, we'll have something interesting to share eventually.."
FYI, the scrub site indicates beta projects in works including a disc caliper but with few facts. Like under "weight" is says "lite".
Scrub:
#57
Clipless in Coeur d'Alene
Anyone find a link to Owner/Install Manuals for the TRP Spyre and/or Hy/RD models?
#58
Quoted: 57 Post(s)
Liked 6 Times
#59
Tandem Mountain Climber
Bikes: Calfee Tandem, Litespeed Gravel, SuperSix Evo HM, Larry vs. Harry Bullitt (e-cargo)
I just bought a Hy/Rd to test out with EBC gold pads (my favorite) and an Ice Tech rotor.
95% of the time the BB7 works fine, but I was again reminded by the Owen's Valley that the BB7 is barely marginal for those kinds of descents. The upper 1/3 of Onion valley, for example, has prolonged 10-12% sections with a repetitive cycle of >45 mph straightaways and hairpins that are maybe 25-30 mph. My confidence was shot to hell with the BB7, on that particular descent.
#60
Tandem Vincitur
Bikes: BMC Pro Machine SLC01, Specialized Globe, Burley Rock 'N Roll tandem, Calfee Dragonfly tandem.
No braking = no speed. Only a fool descends fast without the confidence lent by a powerful brake to pluck you from calamity though the hurtling speed and vertiginous grade combine to make your team a juggernaut.
#61
It will be interesting to hear several accounts of the TRP brake on a tandem (both the Spyre and the HD/RD. We received our HY/RD yesterday, but I have not installed and we will not be putting it through extensive testing immediately as we are predominantly on the mtb tandem for the next few weeks.
I'm cautiously optimistic. I am also pleased to know that the teams that are "experimenting" with the new TRP brakes are quite experienced in tandems in general, but also mountainous terrain. This should make for some good real world testing. Time will tell if these brakes give us a better alternative to braking options for tandem use (tandem "rated" or not).
#62
Wow, your Strava link speaks volumes about BB7 confidence, because instead of your usual 1st out of XXXX on the descent, it is 61 out of 113. That is a result more akin to the Ritterview's unskilled captain/pusillanimous stoker combo than the Marco/Ruth corner carvers.
Curious, what setup would Marco/Ruth have?
#63
I just felt like I was abusing the hardware, exceeding the intended usage parameters if you will. I felt uneasy enough that I actually stopped the bike to check things over (see stopped time, on the link). Everything was fine, I added a few clicks the the pad adjuster, checked the tires/wheels/rotor, waited a few mins and took off down the hill.
#64
As cool as the Profile carbon Wing cowhorn stoker bars look and lightness, we are switching back to drop bars (300gm heavier w/stoker pegs) for a few reasons, one of which is pertaining to Ritterview's comments about highspeed cornering. With my stoker hanging on to cowhorns it is a bit more scary than we like. She can get into a fairly low position but cannot lock in and so the bike gets unsettled with her shoulders and head throwing off the balance when we whip through a corner. I'm taking about fast corners, not just lolligagging cruisers. Our routine with drop bars was to have her always drop & lock when I yell "CORNER!". The dropbar position results in much better unison and a single-bike feel. Another reason is in crosswinds the cowhorns suck... and my stoker is petite too. I can't see how any team wanting performance handling can stand using cowhorns. We may still use cowhorns for non-technical travel/touring, but otherwise maybe mount them on the wall.
#65
Quoted: 15 Post(s)
#66
Quoted: 15 Post(s)
In a couple weeks we'll have a new rear wheel built up for the TRP Spyre SLC / 200mm ICE 6 bolt. We'll share the experience. Based on our cross tandem with disc, I don't expect more "power" than the rim brakes, nor more confidence in descents to go faster. All our discs so far are mushy compared to rim brakes. But as we have several doubles with 20k climbing this year through the Rockies, and pretty tight time limits; it is a given we will be descending in the rain at some point. The Rockies rain 9 out of 10 afternoons from June to August. For those rides we'll swap in the wheel and disc brake (with a splice in the brake cable). I did not want to fret toward the end of 200 mile day heading down a mountain pass in the rain that I'm wrecking a rim with road grit or have any loss in brake ability on a wet rim.
#67
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
Sounds like in your case the drop handlebars are weight well spent. My stoker also likes to have the drops available. She doesn't use them as much as I would like but she has the final call on her fit issues.
My stoker decided she likes Dia Comp knobs much better than the Cane Creek Dummies. The diameter of the rubber cover is larger than the handle bar and she likes the fit in her hand and the fact that it makes a different angle where it attaches to the bar. Somewhat lighter than the heavy Cane Creek Dummies that seem to come standard on most tandems. They look old school so that might be a downside.
#68
Quoted: 9 Post(s)
Dumb question...
The HY/RD’s advantages over the Parabox include easier installation (presumably no bleeding is necessary and there is no hydraulic hose to speak of)"
Does that mean just install the brakes and run the brake cable to them? No dot fluid, bleed or whatever else I don't really want to deal with if I get these for my Volagi? After descending Regnart road and other 19% grades in Cupertino I've grown tired of the squeal of BB7 with HSX rotors and metallic pads. The residents probably are too at 6am during my pre-work rides.
#69
Dumb question...
"Does that mean just install the brakes and run the brake cable to them? " YES.
There are no brake lines to bleed, in reading the instructions, apparently there could be a situation in which you would need to bleed the resevoir - although I don't know what circumstances would require it.
#70
Dumb question...
I will follow up once I have it in my possession.
#71
Are the HyRd shipping in the USA? what distributors? or just running the dealer bypass scheme?
#72
Anyone know if they'll work with the Hope vented rotors? Are you guys just running them on the front or rear or all-round?
I'm thinking on the front would be good, provide that extra power and you've still got a cable operated rear incase things do cook.
#73
I'm not sure that I'd call it a "dealer bypass scheme". As for availability elsewhere, I have not investigated.
#74
Quoted: 57 Post(s)
Liked 6 Times
The calipers come full of mineral oil so they are bolt and go. Direct bolt on replacement of the a Avid or Bengal. Literally a 10 minute job if you cable is long enough. They recommend compression less housing. I saw they are in Universal Cycles website but were not yet available as of last week. I don't think they retract enough for the Hope vented rotor.
#75
I mentioned the vented rotor, and he said it may be too wide.
