Crank Arm Boots for SRAM Red?
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times
Crank Arm Boots for SRAM Red - Solution Found
Anyone know of an aftermarket maker for SRAM Red? I’d like to protect the crank arm tips from chipping and rock strikes.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Not sure if they'll fit Red but SRAM make these; https://www.sram.com/en/sram/models/fc-acc-crbt-a1
Also not sure if they'd fit your cranks but Race Face make these; https://www.raceface.ca/products/era...40058261209221
Quoted: 74 Post(s)
Liked 74 Times
Quoted: 74 Post(s)
Liked 74 Times
The RaceFace boots don’t work. The hole on the outside of the crank doesn’t quite line up. You’d have to remove plastic which means the edge of the boot would be very thin.
Quoted: 74 Post(s)
Liked 74 Times
And I just swapped over the SRAM boots on my XX1 pedals. They are too big and the holes are in the wrong spot. Bummer.
Quoted: 74 Post(s)
Liked 74 Times
Ok, so I found a solution that is workable. The RaceFace boots fit very well to the end of the Red cranks in terms of snugness. The problem is that the hole for the spindles doesn't quite line up. I removed small amount of material from the top end of the outside hole. This allows the spindle to snug up against the crank arm. I've removed so little material that I don't think the boot will be compromised.
On the hex side, the hole is ever so slightly out of alignment. If you use the wrench to push the plastic slightly to the side, that really isn't much of an issue. I suppose you could always remove material on that small hole as well, but it was easy enough to get the wrench in there to tighten the spindle.
