It's been asked a million times but what's a good degreaser, main for chain.
Quoted: 34 Post(s)
Thanks,
Marty
Thanks,
Marty
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
Gas is the best, but smelly. Mineral spirits is probably the best overall. I just lean my bike against a post and work the chain with a chippy brush and a jelly jar of cleaner, moving the chain around with the crank. You can put an old towel underneath to catch dripping crud. Wipe the chain when done cleaning and relube with 3-in-1.
Quoted: 5791 Post(s)
Liked 2,581 Times
The right degreaser is chosen according to what's used to lubricate the chain. Petroleum oils are best dissolved with petroleum solvents such as mineral spirits (the real, not the so-called green stuff), kerosene, diesel fuel, or the like. However if using something that doesn't dry completely you need to do a final rinse with something that does.
Other chain lubes, such as waxes or White Lightening, may not be broken down effectively with common solvents and might need something like MEK, which is nasty stuff to be used outdoors only (IMO).
So-called dry lubes that use a light solvent to deposit teflon or whatever, can usually be washed off effectively with water and detergent, but again, proper rinsing and drying are critical before applying fresh lube.
So, there's no one answer, except to say that the right one is the one that works for your specific application.
FB
Chain-L site
FB
Chain-L site
Emondafied
Bikes: See sig
Quoted: 63 Post(s)
I remove the chain and put it in a sealed container. Then I add a 50/50 combo of something like Simple Green and boiling water. The heat dissolves the grease.
Shake the container vigorously, rinse, wipe dry, then apply your preferred lubricant.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
Quoted: 45 Post(s)
Liked 6 Times
I use simple green bike degreaser. for "lube" i use rock n roll gold. the simple green bike greaser is multipurpose and works well to clean my whole bike. wet whole bike, spray on (its a foam), wait 10 mins, scrub cassette and rings, rinse, dry, apply chain lube, wipe off excess.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
I usually use engine degreaser in an spray can from Walmart, but last time I cleaned my chain I was out of it so I just let the chain soak in the kitchen sink with a strong solution of Dawn detergent and warm water. After it sat for awhile I took a stiff brush to it. It worked. Not as easily as a can of degreaser though.
Bikes: BH RC1, Bianchi Volpe, Orbea Avant
I use Simple Green. It's inexpensive from Costco, they claim it's not all that harmful to the environment, and it works well.
Quoted: 99 Post(s)
I put mine in heavy duty citrus degreaser, comes out looking as clean as day 1. You can buy at any home depot and is dirty cheap.
After I take it off, I wash with water and dry it with a rag, leave in the sun for 30 mins while I clean the bike.
From there, I've a small bucket with Pro link lube where I submerge the chain for a few hours so the oil goes inside the links, take it off passing through a rag to remove the excess and is all ready for the morning ride.
Bikes: 2009 caad 9
Quoted: 44 Post(s)
I was pretty pleased with Remoil in the aerosol can. Yes, I know it's made for guns...but my stuff was DIRTY and when I was done, it shined like new.
Thread Killer
Liked 1,712 Times
Yeah, definitely outside. The high pressure blast is what makes it boss! So easy to use, and yep, quick.
Bikes: 2014 Cervelo R5 Dura Ace,2014 Specialized S-Works Roubaix
kerosene. failing that wd40, both cut the grease but don't have any water component. wipe off and follow with a lube.
Bikes: 2 TiSports and a Ho Ko E Koo
Quoted: 54 Post(s)
I use Super Clean, formally known as CasterOil Super Clean. It's much more alkaline then Simple green so it works much better. I remove my chain, put it in a plastic jug with a mouth large enough that I can get the kinked chain out of once finished. I shake it for a while, then I add almost boiling water and shake some more. Then I repeat with Dawn dish soap or Simple Green to neutralize the PH and a little extra cleaning. Then I rinse well with water. I have an air compressor so I blow out all the water in the chain, then I dry the chain with a hair dryer. I also floss the cassette with a rag and clean the crank set and dérailleurs. I replace the chain on the bike and lube each link with a drop of Pro Link.
Quoted: 6556 Post(s)
Liked 58 Times
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
I am pretty surprised...well not really. Best degreaser for a chain? Buy a gallon of no odor mineral spirits at Home Depot.
Easy way? Bike in floor stand...plastic sheet or news paper under the bike...copious mineral spirits on paper towel...pedal backwards while grasping the chain. Will clean it nicely. Let dry for a minute and reapply White Lightening Clean ride...my lube of choice.
More thorough? Remove the chain and place it in a pickle jar...3/4 filled with mineral spirits with chain and master link inside. Shake and it will become very clean. I will say this is 2 edged sword. I have been at this bike stuff for decades. Completely stripping the inside of the chain generally doesn't pay big dividends unless the you have ridden through a lot of dirt/water/salt etc. Once in while not a bad thing but I can ride a year without doing it...just exterior clean. For normal riding...I wipe the chain with a dry paper towel, relube and go. I get great chain life with above.
Quoted: 4236 Post(s)
Liked 2,949 Times
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Quoted: 1186 Post(s)
Liked 289 Times
Dangerous how? Do you clean your chain while smoking? You could wear gloves if you were worried about absorbing through skin. Or just spray on a little R&R Gold and skip the cleaning altogether.
South Carolina Ed
Quoted: 344 Post(s)
Liked 291 Times
Silly alarmist. Just don't do it indoors and be away from any ignition sources. I've done hundreds of times with complete success.
