Can't ride clipless what's a good platform
Tore my Achilles and shattered my ankle last summer and don't have the motion to ride clipless anymore. Looking for opinions on platforms or combos.
Quoted: 5790 Post(s)
Liked 2,581 Times
Sorry to hear about your bad luck.
MKS has a few nice models to choose from. Probably what's going to matter most to you is width and price.
You might also consider the options to fit to clips. Odds are a toe clip with the strap kept loose will give you some level of retention, yet allow enough movement.
BTW- you might want to ride with the pedal farther back under your foot than normal to lower the load on you Achilles, at least at the beginning.
FB
Chain-L site
FB
Chain-L site
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Eventually I went back to clipless (XTR trail pedals). Shimano 2-bolt SPDs allow me to rotate inward to release, which helps with the range of motion.
Sorry to go off-topic here, but you should get ahold of one of these: Wobble board
Here is what it looks like now:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Wellgo makes a full range of platform pedals, some of which a very svelte. I ordered mine from Blue Sky and love them. https://blueskycycling.com/collectio...-vendor-wellgo
Beware of Amazon "Wellgo" pedals. They may not be.
These are the ones I use. https://blueskycycling.com/collectio...latform-pedals
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Shimano makes a version of their cleats that allow you to clip out in a variety of directions, if you have any sort of motion left, I'd look at those. (It's for their mountain pedals, not road.)
LBKA (formerly punkncat)
Quoted: 2208 Post(s)
Liked 960 Times
Yup, don't have an ankle on the left side. I most often use Eggs as they are easy to get in and out of.
On my fun around bike I use a Shimano MX copy made by Sunlite or the like...they work great.
Yes eggbeaters are also easy to get out of (and are some of the "loosest" retaining pedals out there.) However, I still think you have to clip out left or right, whereas the shimano pedals "supposedly" let you clip out at a variety of angles.
Liked 960 Times
Yes, the cleat has "dots" that indicate the angle of release. You have a shallow or deep release setting according to which way you align it, and can even further facilitate the release by angling the cleat towards the direction you want to come out. I would say the only disadvantage is they can sometimes be too easy to come out of. Since I really can't/don't stand in the saddle under power I don't have concern over it.
Quoted: 4560 Post(s)
Liked 2,802 Times
While deciding on some expensive metal platform pedals, try a set of Stolen Bike Thermalite pedals -- plain, with molded in nibs, not the SP or Throttle. They cost only $15 or so, work great and are tough. Good and grippy too, haven't slipped off even with wet and muddy shoes.
I bought a pair for my old Univega hybridized mountain bike last fall while trying to decide on a "better" set of platforms. But these are so good I'm keeping 'em. After a little break-in ride they're smooth.
I've crashed once and dragged the pedals on tight turns while pedaling a couple of times -- no problems. Just some scuffing of the plastic material, no damage to the axle/spindle.
I mostly wear Merrell cycling shoes or my old low top Montrail walking shoes. Occasionally I'll wear my Herman Survivors hiking boots or thin soled lightweight deck shoes and need to adjust the saddle height a bit to compensate.
And the plain Thermalites come in several colors, if you're into that sorta thing. I got blue to go with my Univega's blue-over-black spatter paint. The Thermalite SP with replaceable steel pins (SP) are black only. They also have the aluminum Throttle models with replaceable steel pins and sealed or unsealed bearings. Great values, tough stuff, made by a company that specializes in BMX.
Quoted: 5888 Post(s)
Liked 3,471 Times
Bikes: '91 Klein Quantum
Quoted: 62 Post(s)
I use pedals that are very similar to this design (can't remember exactly, and I'm not near my bike atm)
Performance Bike: RaceFace Aeffect Mountain Bike Pedals
The point being the peg/spikes that you can adjust and replace, are very grippy. I use pedals like these on my road bike.
Calamari Marionette Ph.D
My preference is a small pedal with a traditional look. MKS Sylvan Touring is a "normal" size and the Sylvan Stream is a more compact version of the same pedal. Add clips and straps if desired. Good bearings, serviceable, good grip.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I've got some of the MKS Touring pedals. Fine if you have a stiff soled shoe, not so comfortable if you are in street shoes for longer distances. I've also got some of the MKS pedals with the point on the ends, that I don't care much for, you need a narrow shoe to fit them comfortably.
I bought some of these to try to rectify those problems for my next set: Wellgo V8 Copy Flat Pedals | Chain Reaction Cycles. Look decent on my desk, but still waiting to be installed.
Occam's Rotor
Liked 2,331 Times
My first post-injury bike shoe (which goes nicely with the above spikey flat pedals) was this:
Five Ten | Impact High Downhill Mountain Bike Shoe | TEAM BLACK
It gives great ankle support and protection, but gets a bit hot in the summer. I now use the low-top version of this on my mtn bike.
Quoted: 4806 Post(s)
Liked 3,930 Times
I don't know your situation but if you cannot ride clipless because you cannot do the rotation to get out, but want the secure foothold and ability to pull up without coming off the pedal, there is another approach. Sadly, that approach is as old as the hills and will mark you as a dinosaur, but it works as well as it did 100 years ago. Toeclips and straps. If you really want to pull up, old-fashioned slotted cleats.
If you go that approach, know that there are modern slotted cleats that work on modern shoes - Exustar track cleats. (Get the $20 cleats, not the $70 cleats. The expensive ones ore for velodrome sprinters, lock to specific pedals and it is expected you are riding to a stop at either your coach to hold you or the velodrom rail. The cheap ones are on the LOOK bolt pattern (three bolt) so you do need "road" shoes to use them. Best part (relative to the old days): installation is easy. So is adjustment. So is replacement. And they are aluminum with deep slots, so all anyone could ask for as a quality connection to your pedals.
If you do want to use toeclips, contact me (either PM when you get the required posts and can or quote this post so I get E-mailed). There are a lot of little tricks that make toeclips work a lot better. It's an almost lost art.
Ben
Ben
Sorry to hear of your issues. Take a look at the offerings of Power Grips. I've got the original diagonal strap and find them easier to use and as secure as traditional clips and straps. But they do require you to pivot your foot but without considerable force. Recently they expanded their lineup with a straight across strap that won't force you to rotate your foot. They attach to just about any standard platform pedal and are even sold as a complete package that includes the pedals.
Hope you heal quickly and completely.
Quoted: 62 Post(s)
Quoted: 608 Post(s)
Liked 352 Times
A nice platform pedal with toe clip is the White Industries pedal with Bruce Gordon Half Clips. The half clip so that it is easier to get your foot on the pedal and just stops if from moving around. The pedal has a nice flat surface with a big flip tap to get the pedal where you need it. It is expensive but you can see and feel the quality. Plus it is made in the US if that is your thing.
Now I don't ride with toe clips so I just use the MKS Sneaker pedal (RMX) and they work just fine. They were inexpensive. I also own and have tried the MKS Grip Kings. They are nice but quite large and they look weird. I put a pair on my wife's bike and she hasn't complained.
For my son's city bike I installed MEC platform pedals with pins. He says he likes them and hasn't taken me up on my offer to use the White Industries (I have two pair just sitting around for some future build).
People have given quite a few choices in this thread, so there is no shortage of decent pedals.
Bikes: 2013 Haro FL Comp 29er MTB.
Quoted: 1470 Post(s)
Liked 45 Times
Pop on pair of Skater shoes and give these a try. I like them for casual riding. I still use speed plays for my road bikes by my FG/SS has these.
Redline Monster PC Pedals | Redline Bicycles
Quoted: 41 Post(s)
Liked 8 Times
MKS GR9. I use these with "clips and straps" and have had good luck with them. I have good retention but can get get out them quickly as need be.
Occam's Rotor
Liked 2,331 Times
After I shattered my ankle, I used Five-Ten shoes with Azonic 420 pedals and Black-ops pedals.
