Unsolicited bicycle adjustments
Liked 2,968 Times
Has to be a rarity to be a 'chosen one' to experience a bike part that was unwantedly messed with...
Went out for a still early, yet not front lawn misted with the dew bike ride. Upon stopping for a restroom break near the end using the bike railing to secure the bike, walking back from the RR, I noticed my brake lever equally positioned to the other one. I purposely adjusted my levers to my comfort & that resulted in one brake lever being slightly off to the other one. Looked at the allen head bolt, sure enough, there was witness markings from a tool being used. I always apply a light coat of paint to the heads of select hardware just out of pure preference.
Has anyone ever had something similar happen to them?
No one I know would have been in the particular area, especially with tools as such. Area is a known nice community & well protected.
-Oh Hey!
-Oh Hey!
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
There's an LBS owner's ghost in your neighborhood?
Or did it just slip and you were unaware?
Quoted: 18413 Post(s)
Liked 15,536 Times
Security cam video or it didn't happen.
Often on Fritz
Bikes: Franken-Fritz, Horse-Feathers, Junker
Quoted: 117 Post(s)
Troul, this is a strange thing to have happened. Are you sure there's no other explanation outside of the supernatural? For instance, is it possible that a friend of yours happened across your bike and "helped" you?
Quoted: 18375 Post(s)
Liked 4,510 Times
I have seen things like quick releases that are odd when doing Bike Valet, and wonder if it is good to just orient them properly, or ignore them.
I have to think the changes you noted at a restroom break were from bumping the bike, although, someone might have shifted them slightly with brute force. I doubt a tool was used.
Except for the witness marks on the bolt head, you may all be right.
Some people are like a Slinky ... not really good for anything, but you still can't help but smile when you shove them down the stairs.
Liked 2,968 Times
for me to not be assertive of any changes that would impact stopping abilities or continuous rolling momentum is rare.
-Oh Hey!
-Oh Hey!
Liked 2,968 Times
I have my left hood rotated slightly inward to accommodate my bad shoulder.
"Hey man, you know your hoods are crooked?" is common. But no one has every tried to fix it.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Quoted: 7652 Post(s)
Liked 3,473 Times
The dude that did that has mellowed out some---he used to steal you baby bolts.
Quoted: 4806 Post(s)
Liked 3,928 Times
I've known of people doing the like. I had someone level out my seat, then tell me the corrected it to "right".
Ben
Ben
Quoted: 1364 Post(s)
Liked 1,677 Times
I could see this happening.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I have been tempted to adjust people's seat height.
Or shift them into an easier gear and they grind at 50 rpm.
Often on Fritz
Quoted: 117 Post(s)
Ok... What's the deal here? Are some of you actually saying you'd do this?!?
Sounds like a good way to get an unsolicited u-lock upside your head...
Not by ME, of course! My u-lock is otherwise engaged at the moment. But I'd probably let you know that your impromptu repair had ought to be discussed with me, the owner, first!
The only unsolicited adjustments I'd make would be if a friend was going too fast I would check to make sure his brakes weren't loose. In that case, I would tighten them up, purely in the interest of safety.
Often on Fritz
Quoted: 117 Post(s)
"Hey man! You really endo'd there! Man that rashing looks gnarly!... Oh by the way, I tightened up your brakes while you took a whiz, it looked like you were going kinda fast... No need to thank me! Hey, what're you doing with that rock? There's no WAY that'll fit in your seat bag, it's too..."
*THUNK* *gurgle* *THUD*
another one bites the dust
Quoted: 1572 Post(s)
Liked 643 Times
I'll confess to having done that.
A customer brought his bike in for a tune up. During the tune up process I re-aligned his brake levers. After he tole me he wanted them the way that they were originally, I never did that again.
Early in spring, when the Pedestrian's on Bikes crowd is out, I want to load a super soaker up with chain lube and put those poor chains out of their wailing misery.
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
I would expect a bike shop to do that if I brought my bike in for a tune-up unless I told them not to when I dropped it off.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I'd understand a bike shop doing that, and in 99% of cases I'd suspect it'd be welcomed from the levers being a bit out of place from a crash or handling bumps. I find it incredulous that someone would adjust a bike sitting on a rack unsolicited, though.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Pity the poor obsessive-compulsive bike mechanic.
Poor soul! Going through life facing dilemma's like this:
Quoted: 2281 Post(s)
Liked 1,710 Times
No way. I don't want anyone messing with the way I set up my bike, so I'm not going to mess with anyone else's. If I do see something that looks odd, I might ask about it but otherwise I figure that other people have set up their bikes exactly how they want them. I even once saw a guy with flat bars which were turned around backwards. I did ask about it and he said he prefers them that way.
