27 inch vs 700c Wheelset of High Quality Comparison
Hello everyone.
I was wondering which wheelset would have better rolling ability if:
- same spoke brand and quality
- same rims and spoke count
- same hub set
- same bearings
- same tires
etc. Basically, everything between the two wheelsets would be identical in terms of quality and finish. My question is, which,in theory, would have better rolling ability and speed?
I see the comparison between 29 vs 650b/27.5 vs 26 inch in MTB culture where many feel that a better wheel set provides better rolling ability.
I wonder what would be the case for 700c vs 27inch (assuming again that they both have the highest quality of identical parts to them). Set aside risk factors or availability.
Totally open ended and I am aware there are various factors at play. Cheers!
- same hub set
- same bearings
- same tires
Realistically and measurably no difference, why do you ask?
Quoted: 237 Post(s)
Liked 83 Times
700c is basically for access to good tires. If you're just going to run 32mm Paselas there's no particular reason to convert. The difference in diameter is only 8mm.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
It's sorta relevant in terms of the 700c conversion conundrum: being able to (a) still acquire tires in the width you want and (b) also to use a vintage brake like the originals.
Gearing will also be marginally higher for 27” for a given setup. Just brainstorming differences;!that has nothing to do with the speed of the wheels themselves.
You can still find plenty of decent 27” tires but afaik you can’t find what most would consider truly fast tires. So if speed is a big concern you probably will go with 700c regardless of which wheel size is faster on paper.
Bianchi Goddess
Quoted: 2912 Post(s)
Liked 2,837 Times
I agree with Kuromori, if all things equal with the wheel the only difference is the tire. If you shod both with a good basic tire like say a Panaracer Pasela which is great for most all riding then there is no noticeable difference. The big difference would be if you put some super fancy tire$ on the 700c wheels you might feel a difference in the handling and overall ride quality.
However there is simply a better selection of higher quality 700 wheels and rims simply because the industry turned that way in the mid to late '80s. More and more 'racing' bikes came with 700c wheels and when hybrids were introduced they also had 700c wheels. As lower end "10 speeds" left the market place the OEM market for 27" wheels dried up so did the aftermarket eventually.
Does anyone even make a high quality 27" rim these days?
Sugar "Kane" Kowalczyk
The engineering side says, a wheel (tire plus rim) with a larger diameter will roll more smoothly over a normal road surface, especially in this case where we stipulate everything else is the same. That's not the imagination of Road Fan the engineer, but I read it in Archibald Sharp's book on bicycle engineering where he collected everything that was already known as of about 1897. But the difference in diameter is 8 mm, so the difference in radius is only 4 mm, less than 1/4 inch. Practically it won't make a difference, in my opinion. And if the 32 mm tire on the 700 is very high quality and the one on the 630 is your generic 27 x 1 1/4 tire available today, the 700 could even have better performance.
I think the real issue is that the 27" rims that came on the types of sport-touring bikes that I like were always single-walled without eyelets. I would never buy a new rim or wheel with a single wall today.
Besides the CR-18, Sun sells the M13 in 27", and if you peel the sticker off if looks just like the old Rigida. Perfect replacement for a 70's Motobecane Grand Touring/Jubilee etc.
Quoted: 1136 Post(s)
Liked 649 Times
There will be no discernable difference between 700c and 27" on the road. It matters more for offroad because wheel diameter affects handling over rough terrain more than pavement or gravel.
mycocyclist
Quoted: 901 Post(s)
Liked 802 Times
African or European swallow?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
The biggest difference is that if you buy tires for the wrong one you will be annoyed and frustrated
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
Commence to jigglin’ huh?!?!
Liked 1,678 Times
Most of my bikes are still rolling with 27" wheels- mostly because that's what they came with, and I happen to have some pretty nice 27" wheels.
For a long time I didn't really understand the advantage of 700C. The advantage is more options for tires- while I was absolutely fine with either Paselas, TG/PT Paselas or Sand Canyon tires- More or less because I didn't have any other point of reference- I didn't know what I was missing.
Getting a set of the Compass tires was more awesome than the cushiest tires (Specialized Expedition) tires I'd experienced.
While I do have a whole lot of nice 27" wheels, I think I may, at some time- or little by little- switch the fleet over to 700C.
Friendship is Magic
Bikes: old ones
Quoted: 26254 Post(s)
Liked 10,234 Times
...people smirk and belittle me when I say this, but the Sun CR-18's in 27" build up a perfectly acceptable wheel if you put Pasela tyres on them. One of the issues I see a lot is that they end up clad with some god awful, heavy assed tyre.
aged to perfection
Quoted: 819 Post(s)
Liked 1,220 Times
700c (ETRTO / ISO 622) wheel is marginally quicker and as several have pointed out you have a much wider tire selection.
27 is a leftover standard from the 50s/60s for US made "10 speed" bikes (Schwinn Varsity etc).
For me the 27 is a dead standard because the range of brake adjustment on most bikes is set up for 700 size rims.
I do have a Mark 1 white Raleigh Pro that has huge clearance with the brake blocks at the bottom of the slots. I suspect these Raleighs (like the international / competition etc) were set up to accommodate 27 size wheels.
700 for me. It's not a close thing.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
The Synergy and Twin Hollow are completely gone from their main product page, so I wonder if they are discontinued and selling whatever leftover stock they have.
More generally, there is no technical reason why a rim with a 630mm BSD would roll any better or worse than a rim with 622mm BSD, if they had the same construction otherwise. 27" simply lost the "format war" in the long run, as it were.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 682 Post(s)
Liked 364 Times
I ascribe to the notion that wheel size aught to be optimized for the frame size so you can keep frame geometry the same. 700c wheels on a 46cm road bike is dumb, and you can see how the frame has to be butchered to accommodate it with stubby head tubes that won't let the minimal insuring mark on a string stem get covered, and then look at a 67cm bikes seat stays and how a larger wheel could take advantage of all that space.
Japanese bikes in the 80's saw the scaling of top tube length match the frame size, when will we see wheel sizes scaled to match bike frames? We already have so many sizes in use how hard would it be to mate frame and wheel size?
Is it a dead standard? Sure, but not long dead, and if an older bike was set up for it in most cases best to keep the original size.
Quoted: 18321 Post(s)
Liked 4,490 Times
Velo Orange also has a narrow 27" rim.
https://velo-orange.com/products/vo-pbp-27inch-rims
I can't say if it is any better than the narrow Rigida or Wolber or similar rims from yester-year.
It looks like it is only offered in 36h.
There also appears to be a Sun CR18 in both 32h and 36h.
https://www.amazon.com/SunRingle-Sun.../dp/B0028N0Z2A
But, as others have mentioned, the selection of rims is very limited.
The selection of tires, especially narrower sizes are also very limited. I think I found a 27x1 Panaracer.
There is also a wider 27x1 1/4 Gatorskin.
In theory, your contact patch would be slightly better for 27", but I have no idea how much overall difference that would make. Probably minimal considering that one is missing out on all the high-end tires. Vittoria Corsa Speed? Various tubeless? Tubulars? Open Tubulars, etc.
Quoted: 1370 Post(s)
Liked 1,743 Times
All things being absolutely equal, other that the defined difference, 27" vs 700c, the 700c will, without doubt, offer a more lively ride quality. Why? Simply because the 27" set will have a greater diameter than the 700c set. The further the rolling weight is away from the axle, the greater the negative impact on ride feel. Want to prove it, easily, to yourself..?
Get a wheel, any wheel. Hold it, snugly, by the axle and tip the wheel this from side to side. Very little, if any, resistance, right? Now, holding the axle tight, give the wheel a gentle spin and try tipping it side to side. Feel the resistance? You bet you do. Now, spin the wheel faster and try tipping it again. Even more resistance!
So, the larger diameter will negatively impact ride feel. Heavy rims, tires, inner tubes and the like will also negatively impact the ride feel.
Of course, I am old and might well be wrong
Btw does anyone know the history of 27” wheels? That was the standard for sport and touring when I started riding. Anyone who cared mostly about speed rode 700c tubulars, at least until around 1980 or so when we started seeing low profile high pressure 700c clinchers. But I don’t know when 27” wheels became common, or what the standard was before that.
