Gitane Tour De France
Bikes: Gitane Tour De France, parts bin fixie(Death Machine), Diamonback MTB
Quoted: 8 Post(s)
Was gifted a Gitane Tour De France 62cm bike. A bit big for me but I'd rather throw a saddle on a gift horse than look it in the mouth. Great bike. Used it as a trailer hauler for my special needs daughter and she loved it. End of the season the rear derailleur broke. I took it off and found there was a little coil-like spring at the hinge so it would no longer tension the chain. It is a bolt-on type derailleur. I have a derailleur from another old 10 speed. Before I go investing a bunch of time I'm wondering what are the chances the other derailleur will work on the Gitane. Or should I start scouting eBay for one just like the one that broke? As long as the mounting is the same I'm good to go right?
Quoted: 765 Post(s)
Liked 660 Times
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 5888 Post(s)
Liked 3,471 Times
Derailleur Hangers Demystified - Red Clover Components
We'll need pictures but the easiest solution is likely to use a derailleur with a claw. The Gitane TdF is a great bike.
Quoted: 8 Post(s)
@jonwvara is being modest. His website is a go to site when dealing with the drop outs on an older French bike.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
If it has friction shifting, most any derailleur will work as long as you can get it bolted to the frame.
Jon
Jon
Quoted: 8 Post(s)
https://www.ebay.com/itm/Suntour-Cyc...4AAOSwJcxcwLEp
That price though
Is there a more (Ahem) economical alternative?
Liked 3,471 Times
Will get pics later today but this is what it looks like:
That price though
That price though
The eBay price is high. Those derailleurs go on this website for less and there are other alternatives.
Quoted: 1949 Post(s)
Liked 2,010 Times
That price though
That price though
https://www.ebay.com/itm/SunTour-Cyc...QAAOSw4CRc3xj4
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I'd get one of these. to replace that Cyclone. Same great performance.
Looks like a nice bike. How bout some (drive side) full-bike pics?
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
That appears to be a Huret-style dropout, so the RD can swing way too far forward. I'm kind of surprised it worked very well at all, but a guess a strong enough sprung upper pivot overcomes it.
Now, @gugie can braze in a bit of metal to make it into a Campy-style, but not all of us have those skills. I'll bet you could glue something in there to make it work.
Quoted: 765 Post(s)
Liked 660 Times
Nice bike, too. Mine is that same color.
--Ogden Nash
--Ogden Nash
Quoted: 823 Post(s)
Liked 1,395 Times
I used to run a SunTour V-GT Luxe on a Raleigh Competition with Huret dropouts - it shouldn't have worked, but it did, and I wasn't even running a spacer or a tabbed washer. Gitane must have been running low on dropouts that day - I've seen Huret dropouts on comparable Gitanes, including what appeared to be a European market TdF equivalent on Asheville, NC Craigslist a while back - but I've never before seen non-honeycomb Huret dropouts on a U.S. spec TdF with the chromed rear before. I have no doubt they built them, though. Has Chas Colerich come around to see this one to add to his data points?
And I am eat up with envy - blue TdFs are particularly lovely in my eyes ...
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
@icecarver Just so you know- even that derailleur carcass is worth money- the pinch bolt nut and the adjustment screws are parts that get lost or broke and people need spares. The GT cage can be fitted to a non-GT derailleur. The pulleys are pretty pedestrian- but good pulleys are good pulleys...
And also to echo- that is a beautiful blue.
Commence to jigglin’ huh?!?!
Liked 3,471 Times
The easiest fix is to get a derailleur with a claw.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,483 Times
What "broke" on the derailleur?
These are very easy to overhaul.
Quoted: 8 Post(s)
Well when it broke it was obvious that it was no longer providing tension for the chain and looked "collapsed". Walked it home, took off the rear wheel, removed the chain and noticed that it was floppy at the hinge. Slowly took that apart and there is a circular coil spring inside with the ends bent out. One end had broken off. I attempted to bend the broken end out but it wouldn't engage the hinge part. So technically speaking all I need is that spring. Are those available anywhere or is that a unique part?
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
...I'd have to agree. If you're using it as a trailer hauler, and cash outlay is a factor (which it almost always is), you should be able to slap just about anything with a claw hanger on there and have it work fine with your friction shifters. And if you don't have a large gear range on there (which I can't tell from your pictures or description), you might not need a long cage rear derailleur at all. This opens up your range of possible alternatives to a large universe of used rear derailleurs.
If there's a bike co-op within easy driving range of you, they'll have a bin of them on a shelf somewhere. Or you might be lucky enough to live near some guy who runs an old school local shop where they repair and sell old bikes. Those are mostly in college and university towns. I'd grab one for you from the co-op here, but by the time I buy it and mail it to you, you're better off going local if you can. And whatever I grabbed would probably not have a long cage, if that's what you need. those are less frequently encountered.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Liked 1,700 Times
As a lot of people here know the Suntour V-GT Luxe is a much more burly, heavy duty (and consequently heavier) sort of version of the Cyclone. This forum has seen several examples of the first version Cyclones have the main spring break- however, I don't recall seeing a member posting about a V-GT Luxe spring breaking. Is the main spring on those more heavy duty than the Cyclone's spring?
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I actually have some NOS springs (Suntour P/N 926) that I believe are correct for the V-GT, but they won't fit a Cyclone.
@jimmuller may still have the exact measurements for the Cyclone spring, as he was the one trying to drum up interest in having reproductions made.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Helical springs are curious beasts. They are spec'ed for maximum windup, typically 90, 180 or 270 degrees, sometimes 360. Also spec's is right-hand or left-hand coil. Finally, critical dimensions are the thickness of the wire and total length. A helical spring is always torqued in the direction of tightening the coil. That makes the diameter shrink slightly, while the length increases by the wire thickness for every 360 degrees of windup. The increase in length is why the prong on one end is longer than necessary and parallel to the helix axis so that it can move further into the hole as the spring is wound up.
Real cyclists use toe clips.
jimmuller
jimmuller
