Solida Crankset Fasteners
Old 06-26-19, 07:49 PM
velo352
Bikes: Peugeot P8 '85
Quoted: 5 Post(s)
Hi,
I have removed the crankset from my vintage Peugeot and cannot separate the two rings. The front has an Allen key, but the rear turns with it. I do not have a flat head to fit the back side (pictured).
Does anyone know of a way to remove these?
velo352 is offline
Old 06-26-19, 07:59 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
Quoted: 14541 Post(s)
Liked 71 Times in 61 Posts
...there's a special tool for that. ....they're cheap. Looks rusted so you also need penetrating oil.
3alarmer is offline
Old 06-26-19, 09:07 PM
velo352
Quoted: 5 Post(s)
of course there is! thanks
velo352 is offline
Old 06-26-19, 09:38 PM
Slightspeed
Slightspeed's Avatar
Quoted: 490 Post(s)
Liked 69 Times in 50 Posts
I had the same issue today trying to change big rings on a Sugino AT crank set. I knew about the tool, but just never got around to buying one. I've always been able to fake it with a big flat screw driver. These were really stuck, even after a penetrating oil soak. Tonight something slipped and the crank took a big chunk of skin off my thumb joint. I got cleaned up, stopped the bleeding, and went back to the crank and there was a big wad of skin stuck on it. Tomorrow I'm buying the $4 tool. Some of us are slow learners.
Slightspeed is offline
Old 06-26-19, 10:12 PM
3alarmer
3alarmer's Avatar
Bikes: old ones
... Tonight something slipped and the crank took a big chunk of skin off my thumb joint. I got cleaned up, stopped the bleeding, and went back to the crank and there was a big wad of skin stuck on it.
...that's gonna leave a mark.
3alarmer is offline
Old 06-27-19, 06:56 AM
TenGrainBread
TenGrainBread's Avatar
Quoted: 655 Post(s)
Liked 55 Times in 41 Posts
The chainring bolt tool helps but still slips easily depending on the bolt. Was never a good design.
I like the modern chainring bolts that take an Allen on both sides.
TenGrainBread is online now
Old 06-27-19, 09:37 AM
dweenk
dweenk's Avatar
Quoted: 575 Post(s)
Liked 11 Times in 9 Posts
I took a knockout from a metal electric panel and ground it down a bit to fit the slot. It works for me. Before that I used a penny.
"The man who does not read has no advantage over the man who cannot read." –Mark Twain
dweenk is offline
