The Shaving Thread Again
Spinmeister
Bikes: Scattante Carbon, Full Ultegra
As I descend farther and farther into cycling I keep thinking about shaving my legs. Not so much for crash repair, that would be nice as I did have some trouble with it over the summer, but I just like the look better. My legs are pretty well developed and every time I put on the shorts and the hair sticks out I think 'thats it, Im shaving'. I still havent done it, I might very shortly though. My legs are definetly on the hairy side, I remember having hairy legs for years now. Anyone else shaving just for the looks? How long did it take you when you first shaved? You use shaving cream I assume right? And how do you, uh hum, reach everywhere? Or rather where do you shave to? My leg hair sticks out all the way up the spandex so Im thinking pretty high.
Go Go Fassa
Shaving your legs just feels better
But it's getting cold now so I don't see a point
You might consider trimming the hair first and then using shaving cream. I usually shave in the shower.
suppercomutter
Bikes: 2000 kona fire mountian, 1988 Schwinn Tempo.
I am a hairy beast. Many people have said I should shave, heck some people said I should braid! I refuse to shave, other than my face.
Ink-Stained Wretch
shaving your hairy ass legs:
items needed:
sheers/electric razor (first time only)
good razor (im a mach 3 fan)
shaving cream/gel/whatever
soap
first time you shave, use the sheers to cut the hair down as short as you can so your razor actually works (I didnt realize this the first time until my second leg). I prefer to then clean my legs with cold water and soap (though you don't have to). Then put on shaving cream (not all at once though). Then shave, first with the growth of ur hair (generally down). Clean your legs if you've cut yourself, then re-lather and shave against the growth (up). Clean again and get ready for one funky ass feeling of putting pants on.
little notes:
if you get a lot of razor burn in certain spots, only shave with the growth of your hair for a bit, it tends to get better with time
dont bend over for too long, first time I tried to shave the backs of my thighs I nearly blacked out (oops)
make sure you soap ur legs at the end!!
moisturizer helps now
items needed:
soap
little notes:
Spinmeister
Getting cold!?!?! Here in AZ it was 98 degrees F today. Where the *&$% is fall? They are even saying we might be up over 100 degrees again next weekend. Just great. Needless to say I hardly need any 'fur' to keep warm! Thanks pinky, thats exactly what I was looking for. Didnt even think of trimming it down first.
Go Go Fassa
Of course your fur isn't an insulator
but there's no point in shaving if you're only going to be wearing tights/leg warmers and not showin any leg
Bikes: Trek 1000, Giant TCR Composite 2
What about arms though? I'm considering shaving more and more but I worry I'll look lop-sided with so much hair on my head and arms.
keep moving forward...
Bikes: 2009 Motobecane Fantom CX
go from top to bottom. just take your time, the first go round is long, but the maintenance after isn't too bad.
You do triathlon so no reason not to shave your arms and everything in between, if you did not swim I would skip the arms since then people will think you are a swimmer
LIke pinky said get the weed wacker out first need to cut down the formest before you can clear the land
I would suggest putting some lotion or specific anti-razor burn lotion on your legs afterwards. At first you will get razor burn and it will itch pretty badly first few days.
Shave 'em! Take it from an AZ native, it never gets THAT cold in the Grand Canyon State. I do it just for looks and will never go back to my hairy Italian legs again.
I'm 148 lbs of legs and lungs.
"The bicycle has a soul. If you are able to love it as it deserves, it will give you emotions you will never forget." -Mario Cipollini
XLR8R Passing!
Bikes: Orbea XLR8R
After a crash many years ago I also decided to go withour hair. For me I used an electric razor with a sideburn cutter to remove the initial har. I then used a disposable razor and cream to complete the job.
Now I use an electric razor on the legs and arms for a quick touch up in the morning and evening. Once a week I stand in the shower with a disposable razor and cream for a closer shave. Several years ago I moved onto shaving my chest also so it may be an indication I am out of control. All I know is my wife and I compete for the best legs contest.
I shaved a couple times I got WICKED Razor burn tho, look like a 15 year old zitty face all over my legs... Needless to say IT SUCKED.... any ideas on how to not get that? or is that with just the more you do it the less it will happen.
The first time you will get that Nofx, you have virgin skin there.. It took me about a week for my skin to actual return to normal. But I have to shave atleast every other day at min to keep from looking and feeling bad. So alot of times I do it daily. Try different creams, also I find the mach 3 razor does the best job and causes the least irritation, also there is creams for it also.
Back in the Sooner State
XLR8R Passing!
Bikes: Orbea XLR8R
The Cycle of Life
Bikes: Trek 520, Eclipse Carbon, Eclipse Al, Unknown Fixie.
how about using Nair for men?? wouldn't that be better than shaving?
But not me
For those cyclists who shave their legs,all the power to you.
But not me. Frankly,I like having long hairy legs and so do most of the women I meet.
Regards.
Regards.
Basicaly nair uses a chemical to burn the hair off you're body, some have problem with it causing irritating their skin so can not use it. I actualy tried it once did not work very well for me personaly.
Regards.
Regards.
Regards.
Location: Originaly Liverpool, currently Greensboro, NC
Bikes: LeMond-Nevada City
My fiancee said if I shave my legs, I'll be sleeping on the couch
I dont think they look to bad, does it really make you go faster ?
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
IMHO, there's no performance advantage on the bike, but there are many discussions out there that talk about how it makes you look like you're in 'the club'. That is, the good cyclist club. Other cyclists will know you're serious about riding, and will generally feel more confident with you riding close to them when on a group ride. Odds are you're experienced if you'll take the addiction tha far.
