Please Recommend a general utility trailer
I have this MTB with quick release tires. Could someone recommend a trailer for it? I'd be using it for runs to the recycling center and grocery mostly. Also, how do you attach trailers to the bike? Thanks.
Share the road.
I bought a kiddie carrier for $40 bucks at a garage sale for hauling huge loads before I got my Dummy.
Bikes: Motobecane Century Pro Ti Disc
Quoted: 69 Post(s)
I am really liking my Avenir cargo trailer. It comes with a chain stay clamp style hitch which I replaced with a Michelin Avenir axle mount hitch. It is made of aluminum tubing with additional cross supports to support the floor, 20" wheels, removable canvas liner and weighs in right at 20 pounds.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
https://www.motherearthnews.com/Do-It...e-Trailer.aspx
https://www.motherearthnews.com/multi...id=67956&seq=1
https://www.motherearthnews.com/multi...id=67956&seq=2
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
i received a Burley Flatbed as a gift and it's great.. very light, and the hitch system is super easy. you install a hitch thru the axle of your rear wheel, and then the trailer connects to the hitch in like 5 seconds. downside is it's expensive
Being Modular, Bikes at Work trailers can be 6 foot long , or shorter..
and will carry many plastic carrier bins. stacked , also.
a buddy carries his 88 key stage keyboard to Gigs with His.
I have a Late CoOp made Burly flat bed, with 406 20" wheels,
Hubs, standard, front QR so pop off & tongue folds down, to stow in the closet.
2 wheel trailers tend to attach to the left rear axle end, so that is the trailer centerline
to the left of the bike centerline.
Thanks for all of the suggestions.
Has anyone heard of Wandertec trailers? They look pretty well made and designed: https://www.biketrailershop.com/wande...ers-c-284.html
I have a cargo trailer made by (or at least for) Aosom. They've recently updated it to a slightly newer model which looks really nice, and it's priced right.
https://www.aosom.com/d-2058/New-Blac...o-Trailer.html
It looks to be just about as sturdy, though mine has a solid metal bottom, rather than plastic, and mine holds 180lbs rather than 110.
If you look at the pics, you'll see one of the coupler. If you look at this Amazon item, it's the exact same coupler: https://www.amazon.com/gp/product/B00...ls_o06_s00_i00
Attach the angled metal bracket to your quick release/rear axle nut, then slide the trailer part over it and insert the d-pin. It takes less than 5 seconds to attach and unattach the trailer.
Note: Do NOT attach it like the picture on Amazon! Always attach it with the quick-release lever on the DRIVE SIDE of the bike. Putting the quick release lever on the same side as the trailer will cause it to loosen up and possibly drop the trailer and your rear wheel.
I have this one and am very pleased with it:
Bikes: 85 botteccia, 85 mcmahn tiatainium, 90 something trek clyde, early 70s schwinn tandem single speed, early 90s gary fisher aquila (the daily rider now!)
Quoted: 11 Post(s)
Liked 18 Times
lots of trailers out there used, try craigslist.
No longer here
Bikes: Terratrike Tour, recumbent tadpole tricycle.
Liked 6 Times
Bought a Burley flatbed, as well, it was on sale at Bike Shop Hub. I would have liked the wheels to be 20" the same size as my front wheels, so I wouldn't have to carry a 16" spare tube along with the 20" and 26" spare tubes, but really, I'm not complaining. It's a great little trailer.
What do you call a cyclist who sells potpourri on the road? A pedaling petal-peddler.
www.redbiketrailer.com made in USA with recycled materials
Bikes: 1978 nishiki 2011 Kona Dr.Good 1996 trek 830, 1996 Iron Horse MT400, 89 Specialized Hardrock,
Can they (Easy Peasy's tires) be bought elsewhere?
